Hello,
Love GameEx, especially the simpler Arcade version with the wheel.
But the new version now crashes on my windoze10 pc.
I just start it and can let it sit there (do nothing or press nothing) and it will in 10 minutes or so crash.
Please,   I don't want to use another frontend!
Thanks.
Kaptainsteve
Hi, we will need more info. Please attach copies of your gameex.ini and log.txt files in your reply to this thread. Instructions on where to find these are in the GameEx How to ask for help link in my signature. Thanks.
17:13:40.7  4/17/2017:  Opening Configuration File
17:13:40.7  4/17/2017:  GameEx Arcade Edition: Version 14.77: Starting Log
17:13:40.8  4/17/2017:  Windows 10 Home 64-bit
17:13:40.8  4/17/2017:  Aero running
17:13:40.8  4/17/2017:  Initializing Vista/Windows 7 volume control
17:13:40.8  4/17/2017:  Getting CPU and RAM info
17:13:40.8  4/17/2017:  Pentium(R) Dual-Core CPU E5800 @ 3.20GHz, 4061MB
17:13:40.8  4/17/2017:  3.19Ghz - 2 Cores or CPU's
17:13:40.8  4/17/2017:  Running Randomize()
17:13:40.8  4/17/2017:  Loading PlugIns
17:13:40.8  4/17/2017:  Checking for applications to Launch On Startup
17:13:40.8  4/17/2017:  Setting default net connection limit to 15
17:13:40.8  4/17/2017:  Running Misc startup tasks
17:13:40.8  4/17/2017:  Setting Menu types
17:13:40.8  4/17/2017:  Getting Configuration Values
17:13:40.8  4/17/2017:  Using Theme: Default - Default
17:13:40.8  4/17/2017:  Checking for alternate Image Directory for Theme: Default - Default
17:13:40.9  4/17/2017:  Launching HideOS.exe
17:13:40.9  4/17/2017:  Initialising Video/MNG DLL's
17:13:40.9  4/17/2017:  GameEx will check for media insertion (may affect performance)
17:13:40.9  4/17/2017:  Hiding Taskbar
17:13:40.9  4/17/2017:  Is Media Center running?
17:13:40.9  4/17/2017:  Checking/Creating LCD Registry values
17:13:40.9  4/17/2017:  Check Media Center Exit/Start Mode
17:13:40.9  4/17/2017:  Media Center Mode 2
17:13:40.9  4/17/2017:  Video previews on. Warning: Only recommended on modern systems
17:13:40.9  4/17/2017:  Custom Game Device Input enabled: Getting custom codes
17:13:40.9  4/17/2017:  Snap Delay set to: 7
17:13:40.9  4/17/2017:  Get other settings
17:13:40.9  4/17/2017:  Set: Find emulator artwork on best match basis
17:13:40.9  4/17/2017:  Start work for Form
17:13:40.9  4/17/2017:  Getting Original Screen Size
17:13:40.9  4/17/2017:  Opening Database Connection
17:13:41.0  4/17/2017:  Initializing Component
17:13:41.0  4/17/2017:  MAME Path is: C:\Mame
17:13:41.0  4/17/2017:  MAME EXE file is: mame64.exe
17:13:41.0  4/17/2017:  ROM Path is: C:\roms\mame
17:13:41.0  4/17/2017:  Catver.ini is located at: C:\GameEx Arcade Edition\DATA\catver.ini
17:13:41.0  4/17/2017:  controls.ini is located at: C:\GameEx Arcade Edition\DATA\controls.ini
17:13:41.1  4/17/2017:  History.dat is located at: C:\GameEx Arcade Edition\DATA\history.dat
17:13:41.1  4/17/2017:  nplayers.ini is located at: C:\GameEx Arcade Edition\DATA\nplayers.ini
17:13:41.1  4/17/2017:  command.dat is located at: C:\GameEx Arcade Edition\DATA\command.dat
17:13:41.1  4/17/2017:  MAMEinfo.dat is located at: C:\GameEx Arcade Edition\DATA\mameinfo.dat
17:13:41.1  4/17/2017:  Snap Path is: C:\snap\mame
17:13:41.1  4/17/2017:  Database Snap Path: Not Found
17:13:41.1  4/17/2017:  Background Snap Path: Not Found
17:13:41.1  4/17/2017:  AVI Snap Path is: C:\videos\mame
17:13:41.1  4/17/2017:  Video theme Path: Not Found
17:13:41.2  4/17/2017:  Flyer Path is: C:\flyers\mame
17:13:41.2  4/17/2017:  Cabinet Path is: C:\cabinets\mame
17:13:41.2  4/17/2017:  Cabinet 3D Path: Not Found
17:13:41.2  4/17/2017:  Title Path is: C:\titles\mame
17:13:41.2  4/17/2017:  Title Path is: C:\logos\mame
17:13:41.2  4/17/2017:  PCB Path: Not Found
17:13:41.2  4/17/2017:  Artwork Preview Path: Not Found
17:13:41.2  4/17/2017:  Panel Path: Not Found
17:13:41.2  4/17/2017:  Manual Path is: C:\Manuals\Mame
17:13:41.2  4/17/2017:  Icon Path is: C:\icons\mame
17:13:41.2  4/17/2017:  Marquee Path is: C:\marquees\mame
17:13:41.2  4/17/2017:  Applying Language/Text
17:13:41.2  4/17/2017:  Text/Language: English
17:13:41.2  4/17/2017:  Loading Language/Text
17:13:41.2  4/17/2017:  Using Version 3 Themes Animations
17:13:41.2  4/17/2017:  Retrieving resolution setting
17:13:41.2  4/17/2017:  Using General Font: HandelGothic BT
17:13:41.2  4/17/2017:  Using Title Font: HandelGothic BT
17:13:41.2  4/17/2017:  GameEx will try to reduce CPU usage
17:13:41.3  4/17/2017:  Initialising Direct3D
17:13:41.4  4/17/2017:  Setting Resolution to 1920x1080 32 bit color
17:13:41.4  4/17/2017:  Creating Surfaces
17:13:41.6  4/17/2017:  Creating Primary Surface - Full Screen Mode
17:13:41.6  4/17/2017:  Creating Back Buffer
17:13:41.6  4/17/2017:  Loading graphic Surfaces
17:13:41.6  4/17/2017:  Display is running at: 1920x1080 32bit color, 60hz
17:13:41.6  4/17/2017:  Adapter: Intel(R) G41 Express Chipset (Microsoft Corporation - WDDM 1.1)
17:13:41.6  4/17/2017:  Max texture size: 4096x4096
17:13:41.6  4/17/2017:  Available texture memory: 1672MB
17:13:41.6  4/17/2017:  Initialising Bass Audio Library
17:13:41.7  4/17/2017:  Creating Surfaces Misc and Dialogs
17:13:41.9  4/17/2017:  Creating Surfaces Volume
17:13:41.9  4/17/2017:  Creating Surfaces Arrows
17:13:41.9  4/17/2017:  Creating Surfaces GameEXlogo Text
17:13:41.9  4/17/2017:  Creating Surfaces Toolbar
17:13:42.1  4/17/2017:  Creating Surfaces Toolbar Controls
17:13:42.2  4/17/2017:  Creating Surfaces Backgrounds
17:13:42.2  4/17/2017:  Creating Surfaces GameEx Logo
17:13:42.2  4/17/2017:  Creating Surface Unselected
17:13:42.3  4/17/2017:  Creating Surfaces Snaps
17:13:42.3  4/17/2017:  Creating Surfaces Menu and List Bars
17:13:42.7  4/17/2017:  Creating Fonts
17:13:42.7  4/17/2017:  Creating Game Font
17:13:43.3  4/17/2017:  Creating Game Font Faded
17:13:44.2  4/17/2017:  Creating Title Font
17:13:44.3  4/17/2017:  Restoring Title Font From Cache
17:13:44.4  4/17/2017:  Creating Font Black
17:13:44.4  4/17/2017:  Creating Font Black Small
17:13:44.5  4/17/2017:  Fonts Created Succesfully
17:13:45.2  4/17/2017:  24MB Video Memory Used
17:13:45.2  4/17/2017:  Initial Emulator Load
17:13:45.3  4/17/2017:  Loading Custom Emulators
17:13:45.3  4/17/2017:  Checking if Steam enabled
17:13:45.3  4/17/2017:  Cannot find steam path
17:13:45.3  4/17/2017:  Checking if Origin enabled
17:13:45.3  4/17/2017:  Cannot find origin executable
17:13:45.3  4/17/2017:  Checking if Uplay enabled
17:13:45.3  4/17/2017:  Cannot find UPlay executable
17:13:45.3  4/17/2017:  gamebase support enabled.
17:13:45.3  4/17/2017:  ERROR: Could not find gamebase path or gblanucher.exe
17:13:45.3  4/17/2017:  gamebase support disabled.
17:14:05.4  4/17/2017:  Attempting to load game list
17:14:07.9  4/17/2017:  MAME CMD options: -nowindow -joy -skip_gameinfo
17:14:10.2  4/17/2017:  Initialising DirectInput for Gamepad support
17:14:10.4  4/17/2017:  Using Device Xin-Mo Dual Arcade
17:14:10.6  4/17/2017:  Loading Start Page
17:14:10.6  4/17/2017:  Initializing MCE Remote
17:14:10.6  4/17/2017:  Initialization OK! Starting GameEx!
17:14:10.6  4/17/2017:  Testing Main Loop Once: Processing Frame
17:14:11.1  4/17/2017:  Testing Main Loop Once: Main Loop ran successfully
17:18:14.0  4/17/2017:  Starting Attract Mode
17:18:14.0  4/17/2017:  Reading MAME hall of fame
17:18:14.3  4/17/2017:  Shutting down display
17:18:14.6  4/17/2017:  Setting Up RawInput Hook
17:18:14.6  4/17/2017:  Launching RawInputHook.exe
17:18:16.0  4/17/2017:  Running: cmd.exe /c C: C:\Mame\mame64.exe trivialp -rompath C:\roms\mame -nowindow -joy -skip_gameinfo -volume -32 -bezel -artpath artworkgameex
17:20:18.0  4/17/2017:  Running: cmd.exe /c C: C:\Mame\mame64.exe pc_radrc -rompath C:\roms\mame -nowindow -joy -skip_gameinfo -volume -32 -bezel -artpath artworkgameex
17:22:19.9  4/17/2017:  Running: cmd.exe /c C: C:\Mame\mame64.exe harddriv -rompath C:\roms\mame -nowindow -joy -skip_gameinfo -volume -32 -bezel -artpath artworkgameex
17:24:21.8  4/17/2017:  Running: cmd.exe /c C: C:\Mame\mame64.exe mrdu -rompath C:\roms\mame -nowindow -joy -skip_gameinfo -volume -32 -bezel -artpath artworkgameex
17:26:23.8  4/17/2017:  Running: cmd.exe /c C: C:\Mame\mame64.exe hellfire -rompath C:\roms\mame -nowindow -joy -skip_gameinfo -volume -32 -bezel -artpath artworkgameex
17:28:25.7  4/17/2017:  Running: cmd.exe /c C: C:\Mame\mame64.exe gunnail -rompath C:\roms\mame -nowindow -joy -skip_gameinfo -volume -32 -bezel -artpath artworkgameex
17:30:27.5  4/17/2017:  Running: cmd.exe /c C: C:\Mame\mame64.exe aliens -rompath C:\roms\mame -nowindow -joy -skip_gameinfo -volume -32 -bezel -artpath artworkgameex
17:32:29.4  4/17/2017:  Running: cmd.exe /c C: C:\Mame\mame64.exe todruaga -rompath C:\roms\mame -nowindow -joy -skip_gameinfo -volume -32 -bezel -artpath artworkgameex
17:34:31.4  4/17/2017:  Running: cmd.exe /c C: C:\Mame\mame64.exe fghthist -rompath C:\roms\mame -nowindow -joy -skip_gameinfo -volume -32 -bezel -artpath artworkgameex
17:36:33.3  4/17/2017:  Running: cmd.exe /c C: C:\Mame\mame64.exe azurian -rompath C:\roms\mame -nowindow -joy -skip_gameinfo -volume -32 -bezel -artpath artworkgameex
17:38:35.2  4/17/2017:  Running: cmd.exe /c C: C:\Mame\mame64.exe baraduke -rompath C:\roms\mame -nowindow -joy -skip_gameinfo -volume -32 -bezel -artpath artworkgameex
17:40:37.1  4/17/2017:  Running: cmd.exe /c C: C:\Mame\mame64.exe secretag -rompath C:\roms\mame -nowindow -joy -skip_gameinfo -volume -32 -bezel -artpath artworkgameex
17:42:39.1  4/17/2017:  Running: cmd.exe /c C: C:\Mame\mame64.exe strider -rompath C:\roms\mame -nowindow -joy -skip_gameinfo -volume -32 -bezel -artpath artworkgameex
17:43:31.3  4/17/2017:  Shutting down RawInput Hook
17:43:33.9  4/17/2017:  Returning From Attract Mode
I've abandoned the whole issue.
I think from what is said above the display driver is a mismatch for the pc and/or version of windows.
So, I'm going back to Windows7, instead of 10.
7 is what the PC came with and this might help synch everything back up. the drivers, hardware and software.
We'll see,,,
Thanks.
Kaptainsteve
Would be nice to know what is showing in the Event Viewer if anything but whatevs.
