cnells2000 Posted March 4, 2017 Posted March 4, 2017 i havent done anything different. but it stays stuck on please wait screen for hours...plz help GameEx.ini log.txt
Draco1962 Posted March 4, 2017 Posted March 4, 2017 The log file looks like a normal exit. Not much to go on. Does it go to "Please Wait" when you first open GameEx or after performing an action? When was the last reboot of the PC? Anything showing in Event Viewer? Are you using a Touch screen? If not, you should disable it via Setup Wizard. 2
cnells2000 Posted March 5, 2017 Author Posted March 5, 2017 I don't know what happened .....so I just uninstalled gameex and re installed it again. Same black screen....just plays the intro sound and stays on a black screen....smh Sent from my SM-J320P using Tapatalk
cnells2000 Posted March 5, 2017 Author Posted March 5, 2017 It says please wait really fast, then shows the black screen forever. It's not touch screen and I cut it on after two days and now this.... Sent from my SM-J320P using Tapatalk
Draco1962 Posted March 5, 2017 Posted March 5, 2017 Did you disable Touchscreen as was previously suggested? When was the last reboot of the PC? Anything showing in Event Viewer? 1
cnells2000 Posted March 5, 2017 Author Posted March 5, 2017 Omg. After I uninstalled it, I disabled touchscreen and everything worked.....wow thanks draco. How did it get enabled? I didn't change it Sent from my SM-J320P using Tapatalk
tthurman Posted March 5, 2017 Posted March 5, 2017 It's enabled by default, and for some reason or another it can cause issues for some.
Draco1962 Posted March 5, 2017 Posted March 5, 2017 I occasionally have these little flashes of insight that prove to be right, but a broken clock is also right twice a day... 1
DazzleHP Posted March 7, 2017 Posted March 7, 2017 On 05/03/2017 at 3:34 PM, cnells2000 said: How did it get enabled? I didn't change it By your own admission, you re-installed from scratch, so everything went to default - touchscreen is enabled by default It's easy to miss something when you wipe, we've all been there
