Hi guys,
I can't get Sega model 2 emulation to work. When using integrated model 2 support, GameEx launches the emulator (newest emulator version 1.1a) but won't start the specified rom. When checking runitgame.bat I noticed the command line being
emulator_multicpu.exe hotd -nocheat -video ddraw
This command line is not working outside of GameEx either. When modifying the command line to
everything works as expected.
I checked with different roms in different locations so I'm pretty sure that this is not a rom path or roms issue.
I'd appreciate if anybody could give me a push in the right direction on why this isn't working for me. Probably something on my end since I didn't see threads on this. Or, alternatively, is there a way to modify the command line that GameEx generates?
Thanks a lot!
GameEx.ini
EMULATOR.INI
You can modify the command line via the Setup Wizard or finding the entry in the gamex.ini file and editing it there using Notepad.
Thanks Draco, but...
in gameex.ini I can only find the entries
UseModel2=True
Model2PATH=C:\Emulators\Model2
which are also modifiable in the Setup wizard. I can't find an entry for the command line (?). Am I missing something?
... and that was it. I deactivated the Hi-Score Snapper and everything goes smoothly!
Thanks a lot Tom. I really appreciate it! This topic can be closed.
(PS: So if there would be an update to the Hi-Score Snapper plugin that`d really be great since I'm using this plugin a lot *hint hint* :-))
smario
