This is the new project that I'm almost finished.
I lack the decoration.
I also want to try Gamex in this project to see such.
I did some tests with GamexEvolution recently that I liked enough.
A year ago, I also testing Gamex, but it made me complicated.
Este es el nuevo proyecto que ya casi tengo terminado.
Me falta la decoración.
También quiero probar Gamex en este proyecto a ver que tal.
Hice unas pruebas con GamexEvolution hace poco que me gustaron bastante.
Hace un año hice pruebas también con Gamex, pero se me hizo complicado.
Apologies, but can't sit on this. I like the naomi-esque design and the 80s colours. I do have to be honest though and say that that thing really does need a bezel around the monitor. That wouldn't be too hard to do and will make it more 'cab-like'
I guess this is a fine example  of "to each his own", because if that was my cab, I'd have LED strips running down the back of the framing that unit that would create a back lighting effect bleeding around those voids where the bezel would be.
<edit>I got distracted, which delayed my post, my reply was to stigzler's comment.
Even if it is a sheet of "smoked" acrylic from behind the CP up to behind the header bar with a cut-out for the display.
  On 10/18/2016 at 5:49 PM, PcTeknic said:
Thank you.
I like it like that.
lol. Short and to the point...
That is why i asked if you wanted feedback or not + couldn't quite interpret your answer. Some people want honest opinion/feedback, others just positive strokes only - I'm cool with both, just struggle when it's not clear.
Hey, if you like it like that then all's good, man! Enjoy your rig.
Forgive me if I misspoke.
Any comment is welcome.
I'll try to explain myself better.
This design I like it and it must be so, because you can sell without pc, no screen, no .... you stay waiting for what the person wants to buy it to market.
Maybe whoever buys only wants the cabinet to put your pc and your screen.
Maybe whoever buys prefer a TV to also connect a console.
So the furniture is free.
Perdona si me he expresado mal.
Todo comentario es bien recibido.
A ver si me explico mejor.
Este diseño me gusta así y es necesario que sea así, porque se puede vender sin pc, sin pantalla, sin.... quedas a la espera de lo que la persona que lo compre quiera poner.
A lo mejor quien lo compra solo quiere el mueble para poner su pc y su pantalla.
A lo mejor quien lo compra prefiere un TV para poder conectar también una consola.
Por eso el mueble queda libre.
  • Draco1962 changed the title to [CABINET] Custom Naomi Regulable
