This is the error that I get when trying to start a game (winkawaks) using GameEX.  Outside of GameEX the application starts and runs with no problems.  Have all the latest DirectX drivers, Running Windows 10 64bit Pro.  Have searched these forums and googled to no fix, please help.
Thanks Neil
Hi Neal, would you mind providing us with a copy of your gameex.ini and log.txt files for review?
Click on the GameEx How to ask for help link in my signature for instructions on how to locate and submit them for us to review.  Thanks!
Suggestion:
In the display settings within the GameEx Configuration Wizard change whatever setting you have under Window/Fullscreen just to see if it has any impact.  You may also need to toggle the setting under Fullscreen windowed too depending on whether or not this has any effect.
You might want to check into this or dig into a search on it.
I believe; and somebody please correct me if I'm just way off here, that what you may be experiencing is possibly the byproduct of legacy DirectX api support, and some conflict with the GameEx code since Directdraw was sunset sometime ago.  That's my best guess anyway, especially since it works outside of GameEx.
