hi .
i have this problem.
the emulator demul correctly start outside gameex (for ex. hokuto no ken works perfectly).
in game ex.. i see the game and the relative animation.. when i start the game appear the desktop and after few second return to game ex.
what is the problem? thanks
GameEx.ini
Are you using MAME set? If yes, why are your roms rar'd? Don't you typically just feed it the zip?
Just a guess, I don't use this emulator. But I don't think GameEx would typically need to extract this file to play it if you're just using zipped MAME ROMs.
hi and thanks for reply. i don t use meme set but the roms are in a separate folder under demul \roms.
the rom are zipped. what do i have to change in gameex.ini?
hanks
You probably need to go through your ROM set and make sure that nothing is in a .rar package. If so, then you will need to unrar them and put them in .zip packages. If using 7zip, make sure that 7zip is enabled for each emulator using ROMs that are in .7z format.
I think he is referrring to what is showing in this part of your log.txt file:
22:32:27.9  13/02/2016:  Extracting: D:\Emulators\DEmul\roms\Naomi-Naomi2-Atomswave-Hikaru-Gaelco\fotns.rar22:32:28.2  13/02/2016:  Running: cmd.exe /c D: DEmul.exe -run=awave -rom=fotns
i ve seen the gameex.ini ... but i found nothing related to what you said... all the files in the folder games are in zip formatg
[Emulator_20]
TVAdPath=
lastgame=
BakSnapPath=
CDCheckFile=
CDCheck=False
RandomMostPlayed=True
ShowMostPlayed=True
PlayInScreenSaver=False
GamesIn7Zips=True
PCGame=False
SelectionMusicFolder=
PlaySelectionMusic=False
DontShowInfo=
PlayMusic=False
CustomBackground=
ExcludedFiles=
LaunchAfter=
LaunchBefore=
OLDatZip=
AlsoLaunch=
Debug=False
ShowDesktop=True
RemoveBrackets=True
Capitals=False
ReplaceUnder=True
ReplaceDash=False
SendKeys=
WaitBeforeKeys=
MapKeys=True
WorkingPath=D:\Emulators\DEmul
ControlPanelPath=
ManualPath=
CartPath=
BoxPath=
TitlePath=D:\Assets\Sega_Naomi\Title
SnapPath=D:\Assets\Sammy_Atomiswave\Snap
RomPath=D:\Emulators\DEmul\roms\Naomi-Naomi2-Atomswave-Hikaru-Gaelco
MapFile=D:\GameEx\MAP FILES\[Arcade] Arcade (Atomiswave).map
ConfigFile=[Mapping Off] Exit (Process Close)
Database=[Arcade] Sammy Atomiswave
RomFilter=
Command=DEmul.exe -run=awave -rom=[ROM]
StartPageLogo=Naomi
StartPageName=[Arcade] Sega Atomiswave (DEmul)
TitleText=Sega Atomswave
Info=Sega Naomi emulator
Website=http://DEmul.emulation64.com/
RequiredFiles=Naomi / Namoi 2 arcade system BIOS packs (naomi.zip, naomi2.zip)
DownloadUrl=http://www.gamesdbase.com/setupwizard/emulators/download/DEmul.7z
Rating=
Version=0.5.7
Emulator=DEmul
Category=Arcade
System=Sega Naomi
VideoSnapPath=D:\Assets\Sammy_Atomiswave\Video_MP4_HI_QUAL
Databasesnappath=
CustomArtName1=Advert
CustomArtPath1=D:\Assets\Sega_Naomi\Advert
CustomArtName2=
CustomArtPath2=
CustomArtName3=
CustomArtPath3=
CustomArtName4=
CustomArtPath4=
CustomArtName5=
CustomArtPath5=
UseDbName=False
GamesIn7zips=True
which should be
GamesIn7zips=False
Also your log showed it extracted a RAR file.
The games should be zipped the same way they are for MAME, which is why people generally use ROMs based off a MAME set.
I'm sure I know the answer, but can get it to run using that command line outside of GameEx?
hi and thanks. i ve tried some changes in gameex config but nothing
this command line
cmd.exe /c D:\emulators\demul\DEmul.exe -run=awave -rom=capsnk
outside gameex doesent work
Ok, so are your games still in RAR files?
capsnk.rar ?
You'll need to concentrate on making it run outside of GameEx first or else you're adding an extra layer of complication.
ok. all the games are in zip format. there are no rar files in the folders. if i run with double click demul and select via mouse the start of one amomiswave game works perfectly.
via command line doesent work
thanks for reply. i resolved.
the correct string:
DEmul.exe -run=atomiswave -rom=[ROM]
the uncorrect string
thanks
i use demu 0.5.8.2 .. do i have to use 0.7?
i think it depends on your graphics-card and what directX it supports. As far as i know, the 0.7 version is directX 11 only, if your graphics card supports directX 11 you should go with 0.7 (faster than 0.5.8 ;) ) , if it does NOT support directX 11, go with 0.5.8.2 :) .
