multiple launch before/launch after paths and exe's pbx setup
hi , can there be 2 launch before table /launch after table working paths and executables commands in pbx setup ?
thx in advance
Have you tried something like ccleaner to see if perhaps it finds some leftovers of your codec pack? In my experience the registry cleaner works well.
Might be worth a shot.
Please provide your ini and log
thx in advance
Not sure I understand what you are asking. If you run an AHK script or a batch file, you can stack multiple commands within. There is no need to have multiple paths for launch before or after for integrated or other system entries.
Well, describe what programs or processes you are trying to launch before and/or after as clearly and detailed as possible along with the intended result. I am sure that someone has either done it before and will have a quick solution or will know how to get you where you are wanting to go.
iam running now a close futuredmd and run futuredmd as start/close programs , i would like ledclear.bat to be executed when exiting vp10 table to pbxmenu , because i have problem that vp10 or pbx doesn't close dof/lights after exiting , vp9 table exit fine in pbx with dof cutting but vp10 tables not lights stay lit
