hi so i have pinballx and have it running visuall pinball tables and future pinball tables with all art work ect...
ive recently bought pinball fx2 on steam and some tables how do i add pinball fx2 to pinballx
last time i tried i clicked enable pinball fx2 in the pinballx settings and filled in required stuff
but it auto listed tables and could never figure this out i no i have blade table and that was one it listed so i added it but never worked i use to get steam client needs to be running?
Hi leedavid2606, and welcome to the PinballX forums.
You had accidentally posted in the GameEx section, so I moved it over PBX general so your topic would be seen by the correct group.
For me, I just completed the entry's for in the FX2 setup, and it took right off. I do have to be logged into Steam for this to work for me though, as I use the SteamGuard App. If you're not already logged into Steam, you may want to give that a shot, and see where that gets you.
Otherwise, please provide your PinballX ini, and log so we can take a look at your setup, and possibly make suggestions.
ive clicked on enable fx2 in pinballx setup
but when i go into game manager in pinballx and select fx2 it doesnt list any tables just a white screen
im logged into steam
You also may want to review this thread. You will likely need to enter the data required using Game List Manager as the tables do not autoload without the Pinball FX2.xml file that is generated.
