[RESOLVED] -listinfo.dat hanging at 25% reading with GamEx 14.40
Hi, Just downloaded and purchased GameEx 14.40, and regardless of which version of Mame I am trying to use (official 166, 166UI, both 32- and 64-bit versions, GameEx hangs with reading listinfo.dat at 25%. It appears to be trying to create this file and a 0-byte file is sitting in the root directory. Have tried renaming that file, removing it, etc. and no matter what I do, as soon as GameEx goes to update the game list, it hangs. I see that this behavior has occurred with previous versions of Mame and required a GameEx app fix.
In any case, I also tried to use the Setup Wizard, downloaded Mame 163 from within from GameEx FTP (I think) and same behavior.
Interestingly, from the command line Mame works, so it isn't a bad version of Mame.
Thanks for any help,
Jay
Hi Jay - you need to help us help you by providing us with your gameex.ini and log.txt files whenever reporting an issue. Click on the GameEx How to Ask for Help link in my sig for instructions on how to provide these to us.
Hey erlo, I just got done reloading my GameEx setup in the last two days, including setting up Mame again.
I also noticed that GameEx took awhile to complete it's Mame initialization. Like you, I closed out GameEx a few times thinking it was hanging (even though the task manager reflected that it was still running). At one point, I just started the Mame initialization again and walked away from the PC for about 10 minutes (leaving focus on GameEx; ie, I didn't use the PC for anything else), and when I came back, GameEx had continued on. Once it was done, it was set up.
How much time have you given GameEx to do it's thing?
Also, as Draco said, if you do just try waiting and continue to have problems, please post your files.
GameEx Support File Data
15:02:05.8 10/19/2015: Opening Configuration File
15:02:05.8 10/19/2015: GameEx: Version 14.40: Starting Log
15:02:05.9 10/19/2015: Windows 7 Home Premium Service Pack 1 64-bit
15:02:05.9 10/19/2015: Aero running
15:02:05.9 10/19/2015: Initializing Vista/Windows 7 volume control
15:02:05.9 10/19/2015: Getting CPU and RAM info
15:02:05.9 10/19/2015: Intel® Core i7-2600K CPU @ 3.40GHz, 8163MB
15:02:05.9 10/19/2015: 3.39Ghz - 8 Cores or CPU's
15:02:05.9 10/19/2015: Running Randomize()
15:02:05.9 10/19/2015: Loading PlugIns
15:02:05.9 10/19/2015: Checking for applications to Launch On Startup
15:02:05.9 10/19/2015: Setting default net connection limit to 15
15:02:05.9 10/19/2015: Running Misc startup tasks
15:02:05.9 10/19/2015: Setting Menu types
15:02:05.9 10/19/2015: Getting Configuration Values
15:02:05.9 10/19/2015: Using Theme: Default - Media Center
15:02:05.9 10/19/2015: Checking for alternate Image Directory for Theme: Default - Media Center
15:02:05.9 10/19/2015: Using Images from theme: Default - Media Center V1\MEDIA\
15:02:05.9 10/19/2015: Launching HideOS.exe
15:02:05.9 10/19/2015: Initialising Video/MNG DLL's
15:02:05.9 10/19/2015: GameEx will check for media insertion (may affect performance)
15:02:05.9 10/19/2015: Hiding Taskbar
15:02:05.9 10/19/2015: Is Media Center running?
15:02:05.9 10/19/2015: Checking/Creating LCD Registry values
15:02:05.9 10/19/2015: Check Media Center Exit/Start Mode
15:02:05.9 10/19/2015: Media Center Mode 2
15:02:05.9 10/19/2015: Video previews on. Warning: Only recommended on modern systems
15:02:05.9 10/19/2015: Snap Delay set to: 4
15:02:05.9 10/19/2015: Get other settings
15:02:05.9 10/19/2015: Desktop set to Hide ICONS and set Background to Black
15:02:05.9 10/19/2015: Set: Find emulator artwork on best match basis
15:02:05.9 10/19/2015: Start work for Form
15:02:05.9 10/19/2015: Getting Original Screen Size
15:02:05.9 10/19/2015: Opening Database Connection
15:02:06.0 10/19/2015: Initializing Component
15:02:06.1 10/19/2015: MAME Path is: C:\GameEx
15:02:06.1 10/19/2015: MAME EXE file is: Mame Mapping Magician.exe
15:02:06.1 10/19/2015: ROM Paths are: C:\GameEx\DEMO;C:\GameEx\DEMO\MAME
15:02:06.1 10/19/2015: Catver.ini is located at: C:\GameEx\DATA\catver.ini
15:02:06.1 10/19/2015: controls.ini is located at: C:\GameEx\DATA\controls.ini
15:02:06.1 10/19/2015: History.dat is located at: C:\GameEx\DATA\history.dat
15:02:06.1 10/19/2015: nplayers.ini is located at: C:\GameEx\DATA\nplayers.ini
15:02:06.1 10/19/2015: command.dat is located at: C:\GameEx\DATA\command.dat
15:02:06.1 10/19/2015: MAMEinfo.dat is located at: C:\GameEx\DATA\mameinfo.dat
15:02:06.1 10/19/2015: Loading Controls.ini map file
15:02:06.1 10/19/2015: Snap Path is: C:\GameEx\DEMO\MAME\snaps
15:02:06.1 10/19/2015: Database Snap Path: Not Found
15:02:06.1 10/19/2015: Background Snap Path: Not Found
15:02:06.1 10/19/2015: AVI Snap Path is: C:\GameEx\DEMO\MAME\video
15:02:06.1 10/19/2015: Flyer Path is: C:\GameEx\DEMO\MAME\flyers
15:02:06.1 10/19/2015: Cabinet Path is: C:\GameEx\DEMO\MAME\cabinets
15:02:06.1 10/19/2015: Cabinet 3D Path is: C:\GameEx\DEMO\MAME\cabinets3d
15:02:06.1 10/19/2015: Title Path is: C:\GameEx\DEMO\MAME\titles
15:02:06.1 10/19/2015: PCB Path: Not Found
15:02:06.1 10/19/2015: Artwork Preview Path: Not Found
15:02:06.1 10/19/2015: Panel Path is: C:\GameEx\DEMO\MAME\cpanel
15:02:06.1 10/19/2015: Manual Path is: C:\GameEx\DEMO\MAME\manual
15:02:06.1 10/19/2015: Icon Path is: C:\GameEx\DEMO\MAME\icons
15:02:06.1 10/19/2015: Marquee Path is: C:\GameEx\DEMO\MAME\marquees
15:02:06.1 10/19/2015: Applying Language/Text
15:02:06.1 10/19/2015: Text/Language: English
15:02:06.1 10/19/2015: Loading Language/Text
15:02:06.2 10/19/2015: Using Version 3 Themes Animations
15:02:06.2 10/19/2015: Retrieving resolution setting
15:02:06.2 10/19/2015: Using General Font: Trebuchet MS
15:02:06.2 10/19/2015: Using Title Font: Trebuchet MS
15:02:06.2 10/19/2015: GameEx will try to reduce CPU usage
15:02:06.2 10/19/2015: Initialising Direct3D
15:02:06.3 10/19/2015: Setting Resolution to 1680x1050 32 bit color
15:02:06.3 10/19/2015: Creating Surfaces
15:02:06.7 10/19/2015: Creating Primary Surface - Full Screen Mode
15:02:06.7 10/19/2015: Creating Back Buffer
15:02:06.7 10/19/2015: Loading graphic Surfaces
15:02:06.7 10/19/2015: Display is running at: 1680x1050 32bit color, 60hz
15:02:06.7 10/19/2015: Adapter: AMD Radeon HD 6450
15:02:06.7 10/19/2015: Max texture size: 16384x16384
15:02:06.7 10/19/2015: Available texture memory: 717MB
15:02:06.7 10/19/2015: Initialising Bass Audio Library
15:02:06.7 10/19/2015: Creating Surfaces Misc and Dialogs
15:02:06.9 10/19/2015: Creating Surfaces Volume
15:02:06.9 10/19/2015: Creating Surfaces Arrows
15:02:06.9 10/19/2015: Creating Surfaces GameEXlogo Text
15:02:06.9 10/19/2015: Creating Surfaces Toolbar
15:02:06.9 10/19/2015: Creating Surfaces Toolbar Controls
15:02:06.9 10/19/2015: Creating Surfaces Backgrounds
15:02:07.0 10/19/2015: Creating Surfaces GameEx Logo
15:02:07.0 10/19/2015: Creating Surface Unselected
15:02:07.0 10/19/2015: Creating Surfaces Snaps
15:02:07.0 10/19/2015: Creating Surfaces Menu and List Bars
15:02:07.2 10/19/2015: Creating Fonts
15:02:07.2 10/19/2015: Creating Game Font
15:02:07.2 10/19/2015: Creating Game Font Faded
15:02:07.3 10/19/2015: Creating Title Font
15:02:07.3 10/19/2015: Restoring Title Font From Cache
15:02:07.3 10/19/2015: Creating Font Black
15:02:07.3 10/19/2015: Creating Font Black Small
15:02:07.4 10/19/2015: Fonts Created Succesfully
15:02:07.6 10/19/2015: 6MB Video Memory Used
15:02:07.6 10/19/2015: Initial Emulator Load
15:02:07.6 10/19/2015: Loading Custom Emulators
15:02:07.7 10/19/2015: Loading Emulator 1: Atari 5200
15:02:07.7 10/19/2015: Loading Emulator 2: Nintendo SNES
15:02:07.7 10/19/2015: Loading Emulator 3: Nintendo N64
15:02:07.8 10/19/2015: Attempting to load game list
15:02:07.8 10/19/2015: Running: Mame Mapping Magician.exe -help
15:02:12.1 10/19/2015: Running: C: C:\GameEx\Mame Mapping Magician.exe -help > C:\GameEx\help.txt
15:02:12.2 10/19/2015: 32 bit MAME version detected on 64 bit windows
15:02:12.2 10/19/2015: MAME CMD options: -nowindow -joy -skip_gameinfo
15:02:12.2 10/19/2015: Initialising DirectInput for Gamepad support
15:02:12.3 10/19/2015: Unable to create a joystick device
15:02:12.3 10/19/2015: Loading Start Page
15:02:12.3 10/19/2015: Initializing MCE Remote
15:02:12.3 10/19/2015: Playing intro sound file
15:02:12.4 10/19/2015: Initialization OK! Starting GameEx!
15:02:12.4 10/19/2015: Testing Main Loop Once: Processing Frame
15:02:12.5 10/19/2015: Testing Main Loop Once: Main Loop ran successfully
15:02:17.3 10/19/2015: Validating: Emulator_1: Snap Path: C:\GameEx\DEMO\5200\video
15:02:17.3 10/19/2015: Validating: Emulator_1: Database: [Console] Atari 5200
15:02:17.3 10/19/2015: Validating: Emulator_1: Title Snap Path: C:\GameEx\DEMO\5200\titles
15:02:17.3 10/19/2015: Validating: Emulator_1: Box Art Path: C:\GameEx\DEMO\5200\boxart
15:02:17.3 10/19/2015: Validating: Emulator_1: Cart Art Path: C:\GameEx\DEMO\5200\cart
15:02:17.3 10/19/2015: Validating: Emulator_1: Manual Path: C:\GameEx\DEMO\5200\manual
15:02:17.3 10/19/2015: Validating: Emulator_2: Snap Path: C:\GameEx\DEMO\SNES\video
15:02:17.3 10/19/2015: Validating: Emulator_2: Database: [Console] Nintendo SNES
15:02:17.3 10/19/2015: Validating: Emulator_2: Title Snap Path: C:\GameEx\DEMO\SNES\titles
15:02:17.3 10/19/2015: Validating: Emulator_2: Box Art Path: C:\GameEx\DEMO\SNES\boxart
15:02:17.3 10/19/2015: Validating: Emulator_2: Cart Art Path: C:\GameEx\DEMO\SNES\cart
15:02:17.3 10/19/2015: Validating: Emulator_2: Manual Path: C:\GameEx\DEMO\SNES\manual
15:02:17.3 10/19/2015: Validating: Emulator_3: Snap Path: C:\GameEx\DEMO\N64\video
15:02:17.3 10/19/2015: Validating: Emulator_3: Database: [Console] Nintendo N64
15:02:17.3 10/19/2015: Validating: Emulator_3: Title Snap Path: C:\GameEx\DEMO\N64\titles
15:02:17.3 10/19/2015: Validating: Emulator_3: Box Art Path: C:\GameEx\DEMO\N64\boxart
15:02:17.3 10/19/2015: Validating: Emulator_3: Cart Art Path: C:\GameEx\DEMO\N64\cart
15:02:17.3 10/19/2015: Validating: Emulator_3: Manual Path: C:\GameEx\DEMO\N64\manual
15:02:17.4 10/19/2015: Restoring Emulator from Cache: 1
15:02:17.4 10/19/2015: Restoring Emulator Database From Cache: 1
15:02:17.5 10/19/2015: Restoring Emulator from Cache: 2
15:02:17.6 10/19/2015: Restoring Emulator Database From Cache: 2
15:02:17.7 10/19/2015: Restoring Emulator from Cache: 3
15:02:17.7 10/19/2015: Restoring Emulator Database From Cache: 3
15:02:31.7 10/19/2015: Writing Game List to disk
15:02:31.7 10/19/2015: Updating MAME Game List
15:02:31.7 10/19/2015: Running: C: C:\GameEx\Mame Mapping Magician.exe -listxml > C:\GameEx\listinfo.dat
15:02:31.7 10/19/2015: Opening Listinfo.dat
15:02:33.2 10/19/2015: Reading ListInfo.dat
[gameexonline]
streamquality=0
Privacy=0
EnableBackground=True
[general]
Xresolution=800
Yresolution=600
DisplayOnSecondary=False
mamepath=C:\GameEx
mameexe=Mame Mapping Magician.exe
rompath=C:\GameEx\DEMO;C:\GameEx\DEMO\MAME
StartWait=False
USeAdvanceMame=False
AdvanceMAMEEXE=advmame.exe
AdvanceMAMEPATH=C:\Emulators\AdvanceMAME
ADVANCEMAMEOptions=-device_video_output fullscreen -quiet -dir_rom "C:\Emulators\Mame32\roms"
UseZinc=False
ZincEXE=zinc.exe
ZincPATH=C:\Emulators\ZiNc
ZincOptions=--renderer=.\renderer.znc
Font=Trebuchet MS
TitleText=MAME Games
OnlyWorking=True
AllowImperfect=True
VerifyRoms=True
OnlyRoms=False
NoGameInfo=False
GameFilter=Japan;Korea;Asia;Hispanic;Bootleg;French;German;Hack;Prototype;Hardware;Spanish;(Easy;(harder
GameFilterOn=True
NoAdult=True
NoClones=False
MameOptions=-nowindow -joy -skip_gameinfo
ArcadeMode=False
UseLargeFonts=True
snappath=C:\GameEx\DEMO\MAME\snaps
avisnappath=C:\GameEx\DEMO\MAME\video
AVIFrameSkip=0
flyerpath=C:\GameEx\DEMO\MAME\flyers
cabinetpath=C:\GameEx\DEMO\MAME\cabinets
CatverLocation=\DATA\catver.ini
nplayerslocation=\DATA\nplayers.ini
HistoryLocation=\DATA\history.dat
InfoLocation=\DATA\mameinfo.dat
CommandLocation=\DATA\command.dat
ShowGameInfoPage=True
EnableStartPage=True
ShowStartPageFirst=True
skipintro=False
AntiAliasFonts=True
OutlineFonts=False
DisplayBackgroundImage=True
SnapBrightness=120
MusicPlayList=C:\Music
MusicVolume=100
MediaCenterMode=2
PlayIntroSound=True
AttractModeTimer=4
AttractModeAudio=2
UsingArcadeVGA=False
StretchResToX=640
StretchResToY=288
TryToStretchto256=False
NoWaitVSync=False
Sleep=True
HideUpdateList=False
DisableExit=False
HideShutDown=False
StartUpVideo=C:\Video
LaunchOnStart=
LaunchOnStartNoWait=
LaunchOnExit=
LaunchOnExitNoWait=
FontSize=0
VectorResX=632
VectorResY=264
AlwaysStretch=410x256
DisableEscape=False
DisableRemoveGame=False
theme=Default - Media Center
Language=English
flatstartpage=False
DontSwitchRes=True
SnapDelay=4
AllowWindowResize=True
ShowLoadingScreen=True
Use16BitColour=False
Widescreen=False
DisableMAME=False
ShellBeforeLaunch=
ShellOnExit=
EnableJukeBox=True
jukeboxplaylist=Live! (CD1)
EnableMediaControls=True
ShufflePlayLists=True
LoadPlayListAtStartup=False
LoadPlayListThread=False
DownloadArt=True
TitleFont=Trebuchet MS
DialogTextWhite=False
TimeFormat=True
HideToolBar=3
DoNotFilterROMS=pacman;splatter
MAMEAudioMode=1
DisplayTitle=True
AVIAudio=True
marqueepath=C:\GameEx\DEMO\MAME\marquees
panelpath=C:\GameEx\DEMO\MAME\cpanel
titlepath=C:\GameEx\DEMO\MAME\titles
iconpath=C:\GameEx\DEMO\MAME\icons
CPEnabled=True
CPPATH=\DATA\controls.ini
ShowVector=True
ShowNeoGeo=True
ShowOriginal=True
ShowAdult=True
ShowCPS=True
ShowVertical=True
ShowHorizontal=True
EnableFavorites=True
ShowMulti=True
ShowAllMAME=True
ShowLastGame=True
ShowRandomGame=True
ShowListNumbers=True
AlphaBlendVideos=True
EnableSound=True
MediaCenterOpenCheck=true
UseSharp=True
CreateImageOnThread=False
HideCreateSnaps=False
HideLogoff=False
HideStandBy=False
DisableMouse=False
ShowVideos=True
VideoPath=
EnableAlphaPage=True
EnableJoystick=True
EnableSlikStik=False
KeyboardDirectInput=False
NoMahjong=True
VIDEOFFDSHOW=0
JoystickDevice=
EnableCustomInput=False
EnableCustomJoyInput=False
AttractVideosEnabled=True
attractvideosratio=-1
attractvideospath=C:\GameEx\DEMO\Videos
AtractModeNewGameTimer=2
AdvancedGFX=True
HideZinc=False
TransitionType=0
Bypass=True
DontBlitWait=False
ShowMostPlayed=True
excludedmameroms=
DeadZoneX=0
DeadZoneY=0
jukeboxmode=0
enableambiance=False
HIDEDESKTOP=True
UseSnapBestMatch=true
IngameVK=121|122
EnableThemePicker=True
DisablePleaseWaitAnimation=False
EnableRipCD=True
DumbyValue=
DVDPath=G:\
AttractOnlyFavs=False
rotateplus90=False
ShowButtons=True
DisplayTitleText=True
PlayExitSaverSound=False
ShowAtari=True
ShowGolden=True
ShowHorizVert=0
UseModel2=False
Model2PATH=C:\Emulators\Model2
ShowModel2=True
ShowLightGun=True
EnableBezel=True
autoupdate=1
NoMAMEOnStartPage=False
HideRestart=False
EnableStartScreenSaver=True
SortMAMEThE=True
SortEmuThE=True
ShowMCEEXport=True
NoRotationRestrictions=False
MakeToolbarTextWhite=False
ExitGameAfter=0
ShowTrackball=True
ShowSpinner=True
LoadEmusOnThread=True
LoadRadioOnThread=False
StartPageAni=True
EmusAttractMode=False
MuteEmuAttractMode=False
Show4Player=True
CabControlFriendly=False
manualpath=C:\GameEx\DEMO\MAME\manual
HideShowTaskbar=True
CustomMAMEFolderPath=C:\Emulators\Mame32\CustomFolders
MAMEFavoritesini=C:\Emulators\Mame32\Folders\Favorites.ini
MenuFontSameSize=False
PreviewVideos=2
ShowStatistics=True
DisableMouseWheel=False
ErrorReporting=0
ReduceCPU=True
ShowNotPlayed=True
ShowOnlineLists=True
ScreensaverMode=0
AttractText=Touch screen to start...
GlaunchEnabled=False
PCBPath=C:\Emulators\Mame32\pcb
ArtworkPath=C:\Emulators\Mame32\artworkpreview
LoadJukeTracksOnStartup=True
EnableLetterSelect=True
JukeQueueMode=0
EnableBezelAttract=True
ForceDailyReboot=-1
EnableSearch=True
FixToEmuList=0
ShowLastPlayed=True
TwoThreeRes=
EnableTouchScreen=True
EnableMediaCheck=True
EnableOtherSystems=True
ForceShutdown=False
EnableHiScore=True
DisplayImageList=False
SortEmulators=True
ShowAllGames=True
InactivityTimer=0
EnableAdvCustomInput=False
HideHibernate=False
EnableKeyboardShutdown=False
AutoRotateMAME=False
EnableLaunchDialog=True
lastmusicpath=C:\Users\ThomasSpeirs\Music
looplist=False
TrackballSupport=False
EnableVisualizations=True
EnableVideoThumbs=False
cabinet3dpath=C:\GameEx\DEMO\MAME\cabinets3d
EnableClientServerMAME=False
ClientServerMAMEPath=C:\Emulators\ClientServerMAME
ClientServerMAMEEXE=vmame.exe
OnQueueEndMode=0
MAMERemoveDupes=2
CommnadLocation=\DATA\command.dat
AutoDownloadDescriptions=True
GameExtenderCustomImageMAMEPath=C:\Emulators\Mame32\marquees
Enablepopupdescriptions=True
SetPalRes=False
PalRes=800x600x32x60
SetNTCSRes=True
NTSCRes=800x600x32x60
SetNTSCRes=False
SetTwoThreeRes=False
AmbianceFolder=C:\ArcadeAmbiance
EnableEscapeKeyExit=True
DisableChangeView=False
EnabledConfigurationApp=True
resumelastatstartup=False
HelpText=
ShowHistoryAndMAMEInfo=True
baksnappath=C:\Emulators\Mame32\backgroundsnap
TVVideoPath=
othervideopath=C:\GameEx\DEMO\Videos;C:\Video;[myvideos]
ChangeMonitorFrequency=False
ChangeMonitorResolution=False
NoCasino=True
EnableDownloadService=True
ShowCHD=True
Databasesnappath=C:\Emulators\Mame32\databasesnap
ArcadeMonitorType=0
EnableHighestRated=True
SeekPreviewVideo=0
demoinstalledversion=1
[daphne]
UseDaphne=False
DaphnePath=C:\Emulators\Daphne
DaphneExe=Daphne.exe
DaphneSnap=C:\Emulators\Daphne\images
DaphneOptions=vldp -fullscreen -x 640 -y 480 -nohwaccel
Enabled_1=True
ROMName_1=astron
GameName_1=Astron Belt
GameOptions_1=-framefile "R:\ARCADE\Daphne\vldp\astron\astron.txt"
Enabled_2=True
ROMName_2=badlands
GameName_2=Badlands
GameOptions_2=-framefile "R:\ARCADE\Daphne\vldp\badlands\badlands.txt"
Enabled_3=True
ROMName_3=bega
GameName_3=Bega's Battle
GameOptions_3=-framefile "R:\ARCADE\Daphne\vldp\bega\bega.txt"
Enabled_4=True
ROMName_4=cliff
GameName_4=Cliff Hanger
GameOptions_4=-framefile "R:\ARCADE\Daphne\vldp\cliff\cliff.txt"
Enabled_5=True
ROMName_5=cobraab
GameName_5=Cobra Command
GameOptions_5=-framefile "R:\ARCADE\Daphne\vldp\cobra\cobra.txt
Enabled_6=True
ROMName_6=lair
GameName_6=Dragon's Lair
GameOptions_6=-framefile "R:\ARCADE\Daphne\lair_HD\lair_hd.txt"
Enabled_7=True
ROMName_7=lair2
GameName_7=Dragon's Lair II Timewarp
GameOptions_7=-framefile "R:\ARCADE\Daphne\vldp\lair2\lair2.txt"
Enabled_8=True
ROMName_8=esh
GameName_8=Esh's Aurunmilla
GameOptions_8=-framefile "R:\ARCADE\Daphne\vldp\esh\esh.txt"
Enabled_9=False
ROMName_9=firefox
GameName_9=Firefox
GameOptions_9=-framefile "R:\ARCADE\Daphne\vldp\FireFox\firefox.txt"
Enabled_10=False
ROMName_10=ffr
GameName_10=Freedom Fighter
GameOptions_10=-framefile "C:\Roms\Laserdisc\Freedom Fighter\ffr.txt"
Enabled_11=True
ROMName_11=galaxy
GameName_11=Galaxy Ranger
GameOptions_11=-framefile "R:\ARCADE\Daphne\vldp\galaxyr\galaxyr.txt"
Enabled_12=False
ROMName_12=gtg
GameName_12=Goal to Go
GameOptions_12=-framefile "C:\Roms\Laserdisc\Goal to Go\gtg.txt"
Enabled_13=True
ROMName_13=interstellar
GameName_13=Interstellar
GameOptions_13=-framefile "R:\ARCADE\Daphne\vldp\interstellar\interstellar.txt"
Enabled_14=True
ROMName_14=gpworld
GameName_14=GP World
GameOptions_14=-framefile "R:\ARCADE\Daphne\vldp\gpworld\gpworld.txt"
Enabled_15=True
ROMName_15=mach3
GameName_15=Mach 3
GameOptions_15=-framefile "R:\ARCADE\Daphne\vldp\mach3\mach3.txt"
Enabled_16=True
ROMName_16=roadblaster
GameName_16=Road Blaster
GameOptions_16=-framefile "R:\ARCADE\Daphne\vldp\rb\rb.txt"
Enabled_17=True
ROMName_17=ace
GameName_17=Space Ace
GameOptions_17=-framefile "R:\ARCADE\Daphne\Space Ace HD\ace_hd.txt"
Enabled_18=True
ROMName_18=sdq
GameName_18=Super Don Quix-ote
GameOptions_18=-framefile "R:\ARCADE\Daphne\vldp\sdq\sdq.txt"
Enabled_19=False
ROMName_19=tq
GameName_19=Thayer's Quest
GameOptions_19=-framefile "R:\ARCADE\Daphne\vldp\tq\tq.txt"
Enabled_20=True
ROMName_20=uvt
GameName_20=Us vs Them
GameOptions_20=-framefile "R:\ARCADE\Daphne\vldp\uvt\uvt.txt"
UseGamepad=False
DaphneFlyer=C:\Emulators\Daphne\flyers
DaphneCabinet=C:\Emulators\Daphne\cabinets
DaphneTitle=C:\Emulators\Daphne\titles
DaphneMarquee=C:\Emulators\Daphne\marquees
DaphnePanel=C:\Emulators\Daphne\cpanel
LaunchBefore=
LaunchAfter=
DaphneCustomGameExtenderCustomArtPath=C:\Emulators\Daphne\marquees
DaphneBakSNAP=C:\Emulators\Daphne\backgroundimages
[dvd]
EnableDVD=True
CODEC=0
DVDFFDSHOW=0
EnableDVDDisk=True
DVDPath=C:\DVD
UseVMR9=True
EnableExternalPlayer=False
Use VMR9=False
CMD=""C:\Program Files (x86)\Corel\DVD9\WinDVD.exe" "[dvd]""
[pictures]
PicturesEnabled=True
paths=C:\GameEx\DEMO\Pictures;C:\Pictures;[mypictures]
UseAlphaBlend=True
SlideDuration=12
[news]
URL_1=http://rss.news.yahoo.com/rss/topstories
URL_2=
URL_3=http://rss.news.yahoo.com/rss/tech
URL_4=http://slashdot.org/index.rss
URL_5=
URL_6=http://www.emulator-zone.com/rss_news.php
URL_7=http://www.spesoft.com/news.xml
URL_8=http://www.gameex.info/forums/index.php?app=core&module=global§ion=rss&type=forums&id=1
URL_9=http://www.hulu.com/feed/highest_rated/videos
URL_10=http://www.hulu.com/feed/popular/videos/this_week
URL_11=http://www.hulu.com/feed/recent/movies
URL_12=
URL_13=
URL_14=
URL_15=
URL_16=
URL_17=
URL_18=
URL_19=
URL_20=
URL_21=
URL_22=
URL_23=
URL_24=
URL_25=
URL_26=
URL_27=
URL_28=
URL_29=
URL_30=
URL_31=
URL_32=
URL_33=
URL_34=
URL_35=
URL_36=
[radio]
RadioEnabled=True
Enabled_5=True
Name_5=Kohina - old school game & demo
URL_5=http://acamar.org:8000/listen.pls
Enabled_6=False
Name_6=Bangkok Radio
URL_6=http://64.62.253.55/bangkok64
Enabled_7=True
Name_7=Kohina - Fresh Tracks
URL_7=http://anka.org:8080/fresh.ogg.m3u
Enabled_4=False
Name_4=Delta Uno
URL_4=http://www.deltauno.it/home/delta1.asx
Enabled_1=False
Name_1=
URL_1=
Enabled_2=
Name_2=
URL_2=
Enabled_3=
Name_3=
URL_3=
Enabled_8=
Name_8=
URL_8=
Enabled_9=
Name_9=
URL_9=
Enabled_10=
Name_10=
URL_10=
Enabled_11=
Name_11=
URL_11=
Enabled_12=
Name_12=
URL_12=
Enabled_13=
Name_13=
URL_13=
Enabled_14=
Name_14=
URL_14=
Enabled_15=
Name_15=
URL_15=
Enabled_16=
Name_16=
URL_16=
Enabled_17=
Name_17=
URL_17=
Enabled_18=
Name_18=
URL_18=
Enabled_19=
Name_19=
URL_19=
Enabled_20=
Name_20=
URL_20=
Enabled_21=False
Name_21=Capital Gold
URL_21=mms://ms1.capitalinteractive.co.uk/gold_high
Enabled_22=True
Name_22=Slay Radio
URL_22=
Name_23=XFM
URL_23=http://rope.icgo.fimc.net/staticweb/onair_players/onair_xfm_abacast/player/onair_xfm.asx
Enabled_23=False
Name_24=Radio Woodstock
URL_24=http://nick8.surfernetwork.com/Media/RWST.asx
Enabled_25=True
Name_25=Club 977 Alternative
URL_25=http://www.977alt.com/977alt.asx
Enabled_26=True
Name_26=Radio Paradise
URL_26=http://www.changeip.com/radio/rp_128.asx
Enabled_27=True
Name_27=Hitz Radio
URL_27=http://www.hitzradio.com/hitzradio.asx
Enabled_28=True
Name_28=Club 977
URL_28=http://www.club977.com/club977.asx
Enabled_29=True
Name_29=9412 Rock Station
URL_29=http://www.9412.com/9412.asx
Enabled_30=True
Name_30=Power Hitz
URL_30=http://www.powerhitz.com/powerhitz.asx
Enabled_31=True
Name_31=Radio Wazee
URL_31=http://www.wazee.org/128.asx
Enabled_32=True
Name_32=The Edge Radio
URL_32=http://mfkrboard.com/edgeradio/edge.m3u
Enabled_33=True
Name_33=WFUV 90.7 FM Public Radio
URL_33=http://www.wfuv.org/wfuvlive.asx
Enabled_34=False
Name_34=Pirate Radio
URL_34=http://www.loudcity.net/Portals/0/LCPlayLists/90/123.asx
Enabled_35=True
Name_35=EYE 97
URL_35=http://www.loudcity.net/Portals/0/LCPlayLists/157/eye97.asx
Enabled_36=True
Name_36=Hit Music Station
URL_36=http://www.hitmusicstation.net/ecoute_haut_debit.m3u
Name_37=Radio IO 80's
URL_37=http://radioio.sc.llnwd.net:8240
Enabled_24=
Enabled_37=False
Enabled_80=True
Url_80=FAVREMOVE
Enabled_81=True
Url_81=FAVREMOVE
Enabled_82=True
Url_82=FAVREMOVE
Enabled_83=True
Url_83=FAVREMOVE
enabled_84=True
name_84=radioio.com : 80s New Wave
url_84=http://www.shoutcast.com/sbin/shoutcast-playlist.pls?rn=1269943&file=filename.pls
Enabled_85=
Name_85=
Url_85=
Enabled_38=True
Name_38=C64.COM's SID Stream
URL_38=http://www.c64.com/sid.m3u
[htmlapplications]
enabled_1=False
URL_1=http://10foot.cbuenger.com/mceWeather/index.php?start=1〈=2
Name_1=Weather
Logo_1=Weather
MouseEmu_1=False
Enabled_2=True
URL_2=https://online.gameex.com
Name_2=GameEx Online
Logo_2=
MouseEmu_2=False
Enabled_3=False
URL_3=http://10foot.cbuenger.com/mceWeather/index.php?start=1〈=2
Name_3=Weather
Logo_3=Weather
MouseEmu_3=True
Enabled_4=False
URL_4=
Name_4=
Logo_4=
MouseEmu_4=True
Enabled_5=False
URL_5=
Name_5=
Logo_5=
MouseEmu_5=True
Enabled_6=False
URL_6=
Name_6=
Logo_6=
MouseEmu_6=True
UseHTMLApps=True
Hide_2=False
Hide_3=
Hide_4=True
Hide_5=
[externalapplications]
Enabled_99=True
Name_99=Configuration
Path_99=[apppath]
CMD_99=GameExConfig.exe
Snap_99=GameExText
ShowDesktop_99=True
MapKeys_99=False
WaitBeforeKeys_99=
SendKeys_99=
Enabled_2=False
Name_2=Notepad
Path_2=c:\windows
CMD_2=notepad.exe
Snap_2=GameExText
ShowDesktop_2=True
MapKeys_2=True
WaitBeforeKeys_2=
SendKeys_2=
Enabled_3=False
Name_3=Mad Dog McCree
Path_3=G:\Mad_Dog_mcCree
CMD_3=G:\Mad_Dog_mcCree\mdm.exe
Snap_3=GameExText
ShowDesktop_3=True
MapKeys_3=True
WaitBeforeKeys_3=4000
SendKeys_3=F
Enabled_1=False
name_1=Close And Restart GameEx
path_1=G:\-DATA-\-MY PROJECTS-\GameEx - VB.net\bin
cmd_1=CloseAndRestartGameEx.bat
snap_1=
showdesktop_1=True
mapkeys_1=True
WaitBeforeKeys_1=d
SendKeys_1=
Enabled_4=False
name_4=
path_4=
cmd_4=
snap_4=
showdesktop_4=True
mapkeys_4=True
WaitBeforeKeys_4=
SendKeys_4=
Enabled_5=False
name_5=
path_5=
cmd_5=
snap_5=
showdesktop_5=True
mapkeys_5=True
WaitBeforeKeys_5=
SendKeys_5=
Enabled_6=False
name_6=
path_6=
cmd_6=
snap_6=
showdesktop_6=True
mapkeys_6=True
WaitBeforeKeys_6=
SendKeys_6=
Enabled_7=False
name_7=
path_7=
cmd_7=
snap_7=
showdesktop_7=True
mapkeys_7=True
WaitBeforeKeys_7=
SendKeys_7=
Enabled_8=False
name_8=
path_8=
cmd_8=
snap_8=
showdesktop_8=True
mapkeys_8=True
WaitBeforeKeys_8=
SendKeys_8=
Enabled_9=False
name_9=
path_9=
cmd_9=
snap_9=
showdesktop_9=True
mapkeys_9=True
WaitBeforeKeys_9=
SendKeys_9=
Enabled_10=False
name_10=
path_10=
cmd_10=
snap_10=
showdesktop_10=True
mapkeys_10=True
WaitBeforeKeys_10=
SendKeys_10=
Enabled_11=False
name_11=
path_11=
cmd_11=
snap_11=
showdesktop_11=True
mapkeys_11=True
WaitBeforeKeys_11=
SendKeys_11=
Enabled_12=False
name_12=
path_12=
cmd_12=
snap_12=
showdesktop_12=True
mapkeys_12=True
WaitBeforeKeys_12=
SendKeys_12=
Enabled_13=False
name_13=
path_13=
cmd_13=
snap_13=
showdesktop_13=True
mapkeys_13=True
WaitBeforeKeys_13=
SendKeys_13=
Enabled_14=False
name_14=
path_14=
cmd_14=
snap_14=
showdesktop_14=True
mapkeys_14=True
WaitBeforeKeys_14=
SendKeys_14=
Enabled_15=False
name_15=
path_15=
cmd_15=
snap_15=
showdesktop_15=True
mapkeys_15=True
WaitBeforeKeys_15=
SendKeys_15=
Enabled_16=False
name_16=
path_16=
cmd_16=
snap_16=
showdesktop_16=True
mapkeys_16=True
WaitBeforeKeys_16=
SendKeys_16=
Enabled_17=
name_17=
path_17=
cmd_17=
snap_17=
showdesktop_17=
mapkeys_17=
WaitBeforeKeys_17=
SendKeys_17=
Enabled_18=
name_18=
path_18=
cmd_18=
snap_18=
showdesktop_18=
mapkeys_18=
WaitBeforeKeys_18=
SendKeys_18=
Enabled_19=
name_19=
path_19=
cmd_19=
snap_19=
showdesktop_19=
mapkeys_19=
WaitBeforeKeys_19=
SendKeys_19=
Enabled_20=
name_20=
path_20=
cmd_20=
snap_20=
showdesktop_20=
mapkeys_20=
WaitBeforeKeys_20=
SendKeys_20=
Enabled_21=
name_21=
path_21=
cmd_21=
snap_21=
showdesktop_21=
mapkeys_21=
WaitBeforeKeys_21=
SendKeys_21=
Enabled_22=
name_22=
path_22=
cmd_22=
snap_22=
showdesktop_22=
mapkeys_22=
WaitBeforeKeys_22=
SendKeys_22=
Enabled_24=
name_24=
path_24=
cmd_24=
snap_24=
showdesktop_24=
mapkeys_24=
WaitBeforeKeys_24=
SendKeys_24=
Enabled_25=
name_25=
path_25=
cmd_25=
snap_25=
showdesktop_25=
mapkeys_25=
WaitBeforeKeys_25=
SendKeys_25=
EmulateMouse_1=-1
EmulateMouse_2=-1
EmulateMouse_3=3
EmulateMouse_4=
EmulateMouse_5=
EmulateMouse_6=
EmulateMouse_7=
EmulateMouse_8=
EmulateMouse_9=
EmulateMouse_10=
EmulateMouse_11=
EmulateMouse_12=
EmulateMouse_13=
EmulateMouse_14=
EmulateMouse_15=
EmulateMouse_16=
EmulateMouse_17=
EmulateMouse_18=
EmulateMouse_19=
EmulateMouse_20=
EmulateMouse_21=
EmulateMouse_22=
EmulateMouse_24=
EmulateMouse_25=-1
LaunchBefore_16=
LaunchAfter_16=
AlsoLaunch_16=
LaunchBefore_17=
LaunchAfter_17=
LaunchBefore_1=
HelpText_1=
[text]
mameCHDlist=CHD
mameCHDstart=MAME CHD Games
steamlist=Steam
steamstart=Steam Games
uplaylist=Uplay
uplaystart=Uplay Games
originlist=Origin
originstart=Origin Games
banner=Banner
Downloading=Downloading
Seeking=Seeking
Download=Download
PlayBluRay=Play Blu Ray
GetMetaData=Get MetaData
Touch_Help_1=Control is located at bottom of screen.
Touch_Help_2=Continuously tap bottom right for credits and top right to start.
Touch_Help_3=Controls are located bottom and middle of screen.
Touch_Help_4=Control is located at bottom of screen.
GameExArcadeStart=Arcade
GameExArcadeList=Arcade
RipDVD=Rip DVD
SearchMusic=Search Music
Dialog_RippingCD=Ripping CD
Dialog_PleaseWait=Please Wait
Dialog_ScanningFolders=Scanning Folders
Dialog_ScanningFiles=Scanning Files
Dialog_LoadingDatabases=Loading Databases
Dialog_LoadingSettings=Loading Settings
Status_ListUpdated=List Updated
Status_FavRemoved=Removed from favorites
Status_FavAdded=Added to favorites
Status_ItemRemoved=Item removed
Status_NextTrack=Next track
Status_PreviousTrack=Previous track
Status_Pause=Pause
Status_play=Play
Status_AddedToQ=Added to queue
Status_NetPlayReq=Requested NetPlay
Status_NetPlayCan=Cancelled NetPlay
YouTube=YouTube
News=News
SearchYouTube=Search YouTube
RequestNetPlay=Request NetPlay
CancelNetPlay=Cancel NetPlay Request
MAMENetPlayStart=MAME NetPlay
NetPlayList=NetPlay
Accept=Accept
Now=Now
Next=Next
GameMusic=Game Music
TVAdvert=TV Advert
Commands=Commands
RecordVideo=Record Video
ResumeGame=Resume Game
ExitGame=Exit Game
InGame=In Game
Stopped=Stopped
Play=Play
ResumeDVD=Resume DVD
NoItems=- NO ITEMS FOUND -
Hibernate=Hibernate
MenuMore=More
AllGamesStart=All Games
AllGamesList=All Games
NotAvailable=Not Available
HiScore=High Score
GetLyrics=Get Lyrics
OtherSystems=Other Systems
OpenMedia=Open Media
Biography=Biography
MenuView=Change View
MenuBack=Back
MenuExit=Exit
MenuHome=Home
LastPlayedList=Last Played
LastPlayedStart=Last Played
SEARCHTITLE=Enter criteria then select menu
SEARCHTITLE2=Press select to release cursor
SearchList=Search
SearchStart=Search
SearchMedia=Search Media
SearchJukebox=Search Jukebox
Items=Items
MediaPlayerStart=Library
MediaPlayerList=Library
NoMediaFound=- NO MEDIA FOUND -
eBookViewerStart=eBooks
eBookViewerList=eBooks
Artwork=Artwork
PCB=PCB
Statistics=Statistics
InsertCD=Insert CD:
SearchGames=Search Games
GameManual=Manual
PlayStation=Playstation
mame2simlist=2 Players
mame2simstart=2 Player Simultaneous
mame4simlist=4 Players
mame4simstart=4 Player Simultaneous
MCEEXPORT=Export To MCE
StartScreenSaver=Start Screensaver
Visualize=Visualize
SelectVisualize=Select Visualization
About1=Windows Emulator Front End and HTPC
About2=Written By:
About3=For Latest Version, please visit:
byalbum=By Album
byartistalbum=By Artist/Album
byartist=By Artist
bycat=By Category
bygenre=By Genre
bymanu=By Manufacturer
bysys=By System
byname=By Name
bytitle=By Title
byyear=By Year
Selectplaylist=Play list / More
createsnaps=Create Snaps
CreateSnaps1A=You are about to create snap shots or videos for every game in the [EMULATOR] Games List. This option can be removed from GameEx, by enabling the Hide Create Snaps option in the configuration.
CreateSnaps2=You should be aware this is a lengthy process
CreateSnaps3=With your current settings it is estimated that it will take at least:
CreateSnaps4=[MINUTES] Minutes to complete this process if you use a 20 second pause between snaps.
CreateSnaps5=You should also be warned that the SNAP shots will be saved in the SNAP Path defined for this emulator
CreateSnaps6=This process is not recommended on Windows 98
CreateSnaps7=To exit this process once run HOLD down ESCAPE.
CreateSnaps8=Do you want to proceed?
Exit=Exit GameEx
HTMLPleaseWait=Please Wait
IsUpdatingList=GameEx is updating the MAME game list:
jukelist=Jukebox
jukestart=Jukebox
Karaokelist=Karaoke
Karaokestart=Karaoke
StartKaraoke=Start Karaoke Player
LaaunchingGame=Launching:
laserlist=Laserdisc
laserstart=Laserdisc Games
logoff=Log Off
favlist=Favorites
favstart=Favorites
mamealllist=MAME Games
mameallstart=All MAME Games
mamecpslist=CPS Games
mamecpsstart=CPS Games
mameAtarilist=Atari Games
mameAtaristart=Atari Games
mameGunlist=Lightgun
mameGunstart=Lightgun Games
mameTrackballlist=Trackball
mameTrackballstart=Trackball Games
mameSpinnerlist=Spinner
mameSpinnerstart=Spinner Games
mameModel2list=Model 2
mameModel2start=Sega Model 2 Games
mameGoldenlist=Golden Era
mameGoldenstart=Golden Era Of Arcade
mameneolist=Neo-Geo
mameNEostart=Neo-Geo Games
mamemultilist=MAME Multiplay
mamemultistart=MAME Multiplayer Games
mamevectorlist=MAME Vector
mamevectorstart=MAME Vector Games
Of=of
shutdown=Turn Off System
standby=Stand By System
Restart=Restart System
Start=Start..
updatelist=Update List
UpdatingList=Updating Game List:
UpdatingPleaseWait=Please Wait......
videoslist=Videos
videostart=Videos
LaunchingGame=Launching Game:
PlayThisGame=Play This Game
Recommended=Recommended Games:
Series=Games in Series:
Title=Title
Flyer=Flyer
Cabinet=Cabinet
Cabinet3d=3D Cabinet
Panel=Panel
Box=Box
Cartridge=Cartridge
Marquee=Marquee
FavoritesAdd=Add To Favorites
FavoritesRemove=Remove From Favorites
NoVideosFound=- NO VIDEOS FOUND -
NoPicturesFound=- NO PICTURES FOUND -
NoMusicFound=- NO MUSIC FOUND -
NoArtistsFound=- NO ARTISTS FOUND -
NoAlbumsFound=- NO ALBUMS FOUND -
NoGenresFound=- NO GENRES FOUND -
NoGamesFound=- NO GAMES FOUND -
NoStationsFound=- NO STATIONS FOUND -
NoNewsFound=- NO NEWS FOUND -
CannotCreateSnaps1=Cannot Create Snaps
CannotCreateSnaps2=Emulator '[EMULATOR]' Does not have a valid Snap path, so Snaps cannot be created. Setup a valid snap path in the configuration and try again.
ViewControls=View Controls
Instructions=Instructions
ViewControlsKey=Press '[KEY]' to view in game.
AllMusic=All Music
ClearCurrentPlaylist=Clear Current Playlist
ShufflePlaylist=Shuffle Current Playlist
PlayLastGame=Last MAME Game
ViewSlideShow=View Slide Show
Pictures=Pictures
Radio=Radio
PlayDVD=Play DVD
PlayCD=Play CD
DVDonDiskStart=DVDs
DVDonDiskList=DVDs
Demo=Demo:
Playing=Playing:
MAMEOriginal=MAME Original Games
MAMEOriginallist=Originals
MAMEAdult=MAME Adult Games
MAMEAdultlist=Adult
ClearAndQueueAll=Clear and Queue All
AddAndQueueAll=Add all to Queue
RandomGame=Play Random Game
StartMAME=MAME
StartApps=More Games & Programs
StartEMU=Emulated Games
StartControl=Exit/Shutdown
StartMedia=Multimedia
ListMAME=MAME
ListApps=Games & Apps
ListEMU=Games
ListControl=Exit
ListMedia=Media
TimesPlayed=Times Played
LastPlayed=Last Played
DeleteFavs=Delete Favorites
DeleteMost=Delete Most Played
Chapter=Chapter
Aspect=Aspect
Aspect0=Original Aspect - Not Zoomed
Aspect4=Widescreen on 4:3 - Stretched
Aspect5=Fill Screen
Aspect3a=Widescreen to 4:3 - Zoomed
Aspect3b=Letterbox to Widescreen - Zoomed
Aspect2=Original Aspect - Zoomed
Aspect1a=Widescreen to 4:3 - Shrunk
Aspect1b=4:3 to Widescreen - Stretched
Paused=Paused
PlayVideo=Play Video
ResumeVideo=Resume Video
RestartVideo=Restart Video
VideoQueue=Play All
QueueAllRandom=Play Randomly
More=More..
MostPlayed=Most Played
MostPlayedList=Most Played
VariousArtists=Various Artists
ConfirmDialog1=Select To Confirm.
ConfirmDialog2=Back To Cancel.
RemoveGame=Remove Game?
LocalDisk=Local Disk
SystemDisk=System Disk
CDDVD=CD/DVD Drive
NetworkDrive=Network Drive
RamDisk=Ram Disk
FloppyDisk=Floppy Disk
RemovableDisk=Removable Disk
UpdateGameList=Update List?
VideoQueueAll=
playstationstart=Playstation
themepickerlist=Themes
themepickerstart=Theme Picker
playstationlist=Playstation
mameVertList=Vertical
mameVertStart=MAME Vertical Games
mameHorizlist=Horizontal
mameHorizstart=MAME Horizontal Games
mamenotplayedlist=Not Played
mamenotplayedstart=MAME Not Played
mamemawslist=Live - MAWS
mameMAWSstart=Live - MAWS Hall Of Fame
mameGameExlist=Live - GameEx
mameGamEexstart=Live - GameEx Favorites
ripcd=Rip CD
ripthiscd=Rip This CD Now
cantrip=- No CD, Invalid CD, or no CDDB data -
ViewPlaylist=View Playlist
KaraokAllSongs=All Songs
KaraokaMode1Click=Instant Play Mode
KaraokaModeQueue=Queue Mode
KaraokePlaylist=View/Edit Playlist
KaraokeStartMenu=Start Karaoke
mammodel2list=
CreateSnaps1=You are about to create snap shots for every game in the [EMULATOR] Games List.
NoeBooksFound=- NO EBOOKS FOUND -
QueueAll=Queue All
weather=Weather
Titles=Titles
Movies=Movies
Actors=Actors
Year=Year
Directors=Directors
Genres=Genres
Collections=Collections
Ratings=Ratings
Cast=Cast
Director=Director
Collection=Collection
TV=TV
NetFlix=NetFlix
SearchNetFlix=Search NetFlix
[favorites]
ReplaceDash=True
ReplaceUnder=True
Capitals=True
RemoveBrackets=True
[dvrms]
DVRFFDSHOW=0
CODEC=
[atractmodenewgametimer]
When in attract mode start a new random game or video each time this value is reached.=2
[attractvideospath]
The folder your videos are located.=L:\GameAds
[gameextender]
RemoteGameExLocation=\\workstation1\g$\-DATA-\-MY PROJECTS-\GameEx - VB.net\bin
Enabled=False
Windowed=False
RemoteExtenderLocation=G:\-DATA-\-MY PROJECTS-\GameEx - VB.net\bin
IPADDRESS=127.0.0.1
Port=8383
RefreshRate=20
SysUserName=Jay
Username=User33549
ComputerName=JAY-PC
Publish=False
UserInfo=
GameExtenderCustomImage=False
GameExtenderImageNotFound=
[gameextenderviewer]
Server=90.0.0.13
PORT=8383
RefreshRate=7
StartWithGameEx=False
ExitWithGameEx=False
Windowed=False
[karaoke]
Path=C:\Karaoke
mode=False
[arcadesoundplugin]
Volume=8
[emulator_]
SelectionMusicFolder=C:\Music
[ebook]
Paths=C:\eBooks
Quality=0
fittopage=False
[mediaplayer]
AudioMode=0
[cpwizard]
CPWizardEnable=False
CPWizardPath=C:\Program Files\CPWizard\CPWizard.exe
CPWizardStarted=True
CPWizardStartup=True
UseWMPWMV=
CMD=
[advkeyboard]
Forward=60
Rewind=61
PageUp=62
PageDown=63
VolumeDown=64
VolumeUp=65
Stop=66
Play=67
[cursorhider]
DoNotHide=
DoNotHideInGameEX=False
[defaultpaths]
EmuPath1=C:\Emulators
AssetPath1=C:\Assets
RomPath1=C:\Roms
[gamebase]
Enabled=False
Path=
MapBack=False
ShowDesktop=True
[dvdrip]
Format=MP4
DVDRIPFOLDER=C:\DVD RIPS
Profile=Normal
CUSTOMCMD=
[gameexarcade]
[touchscreen]
Touchscreen_Enabled=2
Touchscreen_HidePointer=True
TouchScreen_ShowHelpScreens=True
TouchScreen_SingleClick=True
TouchScreen_OnlyCompatibleGames=True
TouchScreen_CheckForExit=True
TouchScreen_SendCredit=True
TouchScreen_ShowMouseAnimations=True
[laststatus]
specialfilter=
oldspecialfilter=LIST
curemulator=0
listtype=8
curbak=Start
maxgames=11
gamename=
[steam]
LaunchBefore=
LaunchAfter=
[mappeddrives_1]
UNCPATH=\\Nasusa\roms_mint
Drive=R
[uplay]
UPlayEnabled=False
LaunchBefore=
[origin]
OriginEnabled=False
[emulator_0]
excludedfileswithnamesverifiedfound=;10yard85;
[login]
[movies]
[netflix]
[tv]
available=False
[iNTERNAL]
currentstation=
VGenre=---
OPTIMIZED=0
version=14.40
timesruncount=5
startpagethumbscount=5
emu_1lastfolderwrite=10/18/2015 5:11:57 PM
emu_1lastromfilter=*.avi
emu_1_dbcachemodified=12/16/2014 10:11:34 PM
emu_1_lastnumgames=4
emu_1_dbcachelastname=[Console] Atari 5200
emu_1_dbcacheinicreated51=True
emu_2lastfolderwrite=10/18/2015 5:11:57 PM
emu_2lastromfilter=*.avi
emu_2_dbcachemodified=12/16/2014 10:12:24 PM
emu_2_lastnumgames=4
emu_2_dbcachelastname=[Console] Nintendo SNES
emu_2_dbcacheinicreated51=True
emu_3lastfolderwrite=10/18/2015 5:11:57 PM
emu_3lastromfilter=*.avi
emu_3_dbcachemodified=12/16/2014 10:12:04 PM
emu_3_lastnumgames=4
emu_3_dbcachelastname=[Console] Nintendo N64
emu_3_dbcacheinicreated51=True
mamevideolists_reset22_startmame=False
mamevideolists_lastmodifiedlist_startmame=7/24/2010 1:06:58 PM
mamevideolists_list_startmame=mrdrillr.avi|puckman.avi|dkong.avi|tempest.avi|smashtv.avi
mamevideolists_reset22_most=False
mamevideolists_lastmodifiedlist_most=7/24/2010 1:06:58 PM
mamevideolists_list_most=
mamevideolists_reset22_mameall=False
mamevideolists_lastmodifiedlist_mameall=7/24/2010 1:06:58 PM
mamevideolists_list_mameall=mrdrillr.avi|smashtv.avi|dkong.avi|puckman.avi|tempest.avi
lastglaunchlist=0
glaunchlistselected_0=1
glaunchlisttop_0=1
viewalbumtype=0
windowed=False
selectedgame=1
gamelisttop=1
catfilter=
manufilter=
yearfilter=
listtype=8
emulator=0
yearlisttop=1
catlisttop=1
namelisttop=1
manulisttop=1
yearselectedgame=1
catselectedgame=1
manuselectedgame=1
nameselectedgame=1
romname=dkongo
romname2=dkongo
specialfilter=LIST
currentstationurl=
mamevideolists_reset22_mamef=False
mamevideolists_lastmodifiedlist_mamef=7/24/2010 1:06:58 PM
mamevideolists_list_mamef=
mamepath=C:\GameEx
mamefilemodified=4/3/2014 3:46:50 AM
mamefilesize=920299
mamepromptupdate=True
mameis32bit=True
emu_1_romfilter=*.avi
emu_1_rompath=C:\GameEx\DEMO\5200\video
emu_1_manualpath=C:\GameEx\DEMO\5200\manual
emu_1_workingpath=C:\GameEx\DEMO
emu_1_removebrackets=True
emu_1_showdesktop=False
emu_1_command=demo.exe
[rompath]\[romfile]
emu_1_database=[Console] Atari 5200
emu_2_romfilter=*.avi
emu_2_rompath=C:\GameEx\DEMO\SNES\video
emu_2_manualpath=C:\GameEx\DEMO\SNES\manual
emu_2_workingpath=C:\GameEx\DEMO
emu_2_removebrackets=True
emu_2_showdesktop=False
emu_2_command=demo.exe
[rompath]\[romfile]
emu_2_database=[Console] Nintendo SNES
emu_3_romfilter=*.avi
emu_3_rompath=C:\GameEx\DEMO\N64\video
emu_3_manualpath=C:\GameEx\DEMO\N64\manual
emu_3_workingpath=C:\GameEx\DEMO
emu_3_removebrackets=True
emu_3_showdesktop=False
emu_3_command=demo.exe
[rompath]\[romfile]
emu_3_database=[Console] Nintendo N64
[CachedImages]
res=1764000
bakres=1764000
[CachedImagesMenuFont]
res=0
[Emulator_1]
enabled=True
startpagename=Atari 5200
titletext=Atari 5200
startpagelogo=5200
romfilter=*.avi
snappath=C:\GameEx\DEMO\5200\video
titlepath=C:\GameEx\DEMO\5200\titles
boxpath=C:\GameEx\DEMO\5200\boxart
cartpath=C:\GameEx\DEMO\5200\cart
removebrackets=True
showdesktop=False
command=demo.exe "[rompath]\[romfile]"
lastgame=
[Emulator_2]
enabled=True
startpagename=Nintendo SNES
titletext=Nintendo SNES
startpagelogo=SNES
romfilter=*.avi
snappath=C:\GameEx\DEMO\SNES\video
titlepath=C:\GameEx\DEMO\SNES\titles
boxpath=C:\GameEx\DEMO\SNES\boxart
cartpath=C:\GameEx\DEMO\SNES\cart
removebrackets=True
showdesktop=False
lastgame=
[Emulator_3]
enabled=True
startpagename=Nintendo N64
titletext=Nintendo N64
startpagelogo=N64
romfilter=*.avi
snappath=C:\GameEx\DEMO\N64\video
titlepath=C:\GameEx\DEMO\N64\titles
boxpath=C:\GameEx\DEMO\N64\boxart
cartpath=C:\GameEx\DEMO\N64\cart
removebrackets=True
showdesktop=False
lastgame=
[CachedImagesGameFont]
res=1764000
[CachedImagesGameFontFaded]
res=1764000
[CachedImages3d]
themedir=\themes\Default - Media Center V1\MEDIA\
titlefontres=1764000
titlefont=Trebuchet MS
titlefontstyle=0
titlefontsize=0
outlinefonts=False
use16bitcolour=False
gradienttitlefont=True
lowercasetitlefont=True
antialiasfonts=True
windowed=False
[setupWizard]
EmuPath1=R:\
RomPath1=C:\Roms
DefaultPathPrompt=True
DownloadDatabasePrompt=True
DownloadEmulatorPrompt=True
WizardMode=0
CustomArray=
SearchArray=
SavePosition=False
SearchText=
EmulatorIndex=0
EmulatorGroupIndex=0
DaphneIndex=0
HTMLAppsIndex=0
ExternalAppsIndex=0
RadioStationsIndex=0
NewsFeedsIndex=0
MappedDrivesIndex=0
SystemIndex=0
ShowPanel=True
FontSize=1
WindowSize=650, 478
WindowLocation=515, 266
WindowState=Normal
SectionIndex=42
Hi. I waited almost an hour and still have not been successful in completion. I have attached the 2 requested logfiles to this post. Thanks in advance for any help!
GameEx.ini
Hey again erlo,
OK, I noted a few things about your Mame setup that look a little odd:
  • You list the Mame executable as Mame Mapping Magician.exe. It should be the Mame executable... which I assume is in your Mame32 folder. Mame Mapping Magician.exe is actually a small program used to create .map files for GameEx. Now, I don't actually know the process that GameEx goes through to generate it's Mame files, but I would bet that it uses the Mame executable...so it's pretty likely that it's choking out on this thing called Mame Mapping Magician.exe.
  • Your config says that your Mame Roms are located in C:\GameEx\DEMO;C:\GameEx\DEMO\MAME. While there is nothing wrong with putting roms in the Mame folder or two different folders, most people put them in a ROM folder (eg, C:\GameEx\DEMO\MAME\ROMS). That is only a problem unless your roms are NOT actually located in those two folders.
...and a side suggestion: Your Mame config is split between the C:\GameEx\DEMO folder, the C:\GameEx\DEMO\MAME folder, and the C:\Emulators\Mame32 folder. In my experience, most people keep assets for an emulator in the same folder. Again, this would not cause an issue as long as you are familiar with Mame and know how your config works. The way I do it is to place all the emulator 'stuff' in it's own folder outside the GameEx folder just in case I ever need to reinstall GameEx.
I did not look any further than this, so I would suggest checking over your entire Mame configuration using the SetupWizard to make sure everything else is pointing in the right place and then give it another go.
Good luck. Hope it helps. :)
  • Like 3
I have the same issue my Mame games list goes to 25% than quits. It's better than the last version which would not even open the list. I had to go back to Win 8.1 because Win10 blew my computer up and it completely stopped working. So I will look through the threads and see if I can locate the version of gameex that Tom sent me that one worked. Are Win 10 and Win 8 that different? Will Win8.1 still be supported now that 10 is the new kitten or puppy?
GameEx.ini
The main issues with Win 10 that I have seen are drivers (or lack thereof) and some 3rd party apps that are slow to update to the latest OS. I find it to be every bit as stable and then some on my rig. We support back to XP still so you should be fine with whatever OS you choose.
Hey Methodman,
This is odd because, like erlo above, your mame executable is also listed as Mame Mapping Magician.exe.
Go into the SetupWizard > MAME Settings > MAME EXE and enter the name of the Mame Executable you are utilizing. Save the config, reverify that it took the change, maybe recheck the other settings on that page, and then try triggering the Mame list update again. Also, make sure GameEx is not running when you are using the SetupWizard.
It is odd that both you and erlo would have Mame Mapping Magician.exe as the Mame executable. Do you recall setting it up that way or if it was somehow defaulted that way? I assume that you are aware that GameEx does not come with a version of Mame included...
Red Dog, It is a hyperspin prepared drive. The reason I wanted to test it out in Gameex is that Gameex lists All the games It doesn't categorically divide the games the way hyperspin does. Oh well I guess it is incompatible with that drive. I thought I would try it. The Mame 64 UI works I am just curious why GameEx doesn't.
It probably does work, but you need to point GameEx at MAME, not MAME Mapping Magician as he said or it won't parse the roms correctly.
The drive doesn't matter, neither do the paths as long as they're configured properly. It takes a few minutes at best.
Hi Methodman
What RedDog is describing has nothing to do with your hard drive in the slightest. It has to do with your settings for GameEx. GameEx is not like HyperSpin in that it matters not a lick where your want to put your emulators, ROMs, etc. What does matter is how you configure GameEx in the Setup Wizard. Are you using the Setup Wizard to configure GameEx? Specifically RedDog noted that you have Mame Mapping Magician.exe set as your Mame.exe. It's this setting in the Setup Wizard. You need that setting to point towards the Mame.exe you want to use through GameEx. After that you'll want to fix that and analyze and/or configure the rest of your settings for validity. Good luck, man. It's pretty easy once you start getting it set up.
I'm with RedDog - I do think it's odd that this unusual configuration has popped up twice within a couple of days.
I've not used Hyperspin, so I don't know how it is configured, but GameEx is an almost completely manual setup. At the start of the configuration, it does provide a suggestion as to where you may want to install your Mame, but it is not something that is required.
One of the nice things about having a manual setup is that you have a lot of freedom in how you organize your files and how you might set certain aspects up...but one of the drawbacks is that you DO have to configure most everything. GameEx won't do much 'out of the box'. It is very important to take the time to walk through the BASIC configuration at least and the ADVANCED settings once you are ready to look at the fine details.
Hope it works out for you. I've used GameEx for a LONG time and I really like the customization options it gives me.
I finally had time to work on it. I changed the directory and got it going to 55% then it gave me an error. It seems to have loaded Mame. Would I be bett off using the Mame ui64 on the C:/ drive than the roms on the R:/ drive? I pointed it to the Mame on R:/
GameEx.ini
Where's your runitgame.bat ?
Thanks for your reply it gets stuck at 55% than I break it and it says romset is ok but it seems to not go past 55%. What I runitgame.bat where do I find it?
