Scooby1 Posted October 7, 2015 Share Posted October 7, 2015 Hey guys,I have many tables now launching smoothly from PinballX and have really been enjoying playing pinball. There are so many great tables and PinballX is awesome.The one table I am having an issue with is ACDC (Stern). This table plays great directly from Visual Pinball, however when I launch it from PinballX, it crashes. This is the only table that does this.I thought maybe it was an issue with how my Stern tables are set up, however I don't have any issues with other Stern tables from PinballX, such as Transformers, X-men and 24.Attached is the crash box that pops up whenever I launch ACDC from PinballX.Any ideas what I can do to fix this?Thanks in advance! Link to comment Share on other sites More sharing options...
Draco1962 Posted October 7, 2015 Share Posted October 7, 2015 Have you tried upgrading to VP 9.9.1? Also, we need to see the log.txt (right after the error) and pinballx.ini files to assist. Thanks! Link to comment Share on other sites More sharing options...
Scooby1 Posted October 7, 2015 Author Share Posted October 7, 2015 Thanks Draco. I'll try to get the log and ini posted shortly.As for VP 9.9.1, the ACDC table is a PM5 table and runs great from my VP PM5.exe directly. All of my other PM5 tables run great from the PM5.exe (from PBX as well).Do you think running this table in VP 9.9.1 instead of PM5 will work? Link to comment Share on other sites More sharing options...
Draco1962 Posted October 7, 2015 Share Posted October 7, 2015 Not sure as I do not run that system currently. Have you tried installing a fresh copy of that particular table to see if it may just be a problem with the table you have? Link to comment Share on other sites More sharing options...
Draco1962 Posted October 7, 2015 Share Posted October 7, 2015 If you search the web for keywords ACDC Stern physmod 5 you will probably find a few threads in the various pinball forums that reference some issues with this table and some recommendations as to what version ROM needs to be used, etc. The issue does not appear to be specific to PinballX from the evidence presented thus far, even if it is working well outside of it. I would think that there would be an issue with all tables if that were the case. Link to comment Share on other sites More sharing options...
Scooby1 Posted October 8, 2015 Author Share Posted October 8, 2015 It may not be an issue specific to PBX. When I delete the nvram file for this table, it launches okay...the first time. After that, if I launch it a second time, it crashes.I'll poke around to see if there is a fix for this.Thanks. Link to comment Share on other sites More sharing options...
Draco1962 Posted October 8, 2015 Share Posted October 8, 2015 Do you have VP running as adminstrator? Link to comment Share on other sites More sharing options...
Scooby1 Posted October 8, 2015 Author Share Posted October 8, 2015 I checked and I do have VP running as admin. I've been reading and trying everything others have suggested, but none change my issue with launching this one table from PBX. I have tried new versions (were actually the same as what I had) for the rom, dll, pm5, naming structure, made sure zip file is exactly as others have instructed works.I also now have this table running every time outside of PBX. I even got it to run a couple of successive launches from PBX, but then it crashed again from PBX.I'm convinced it is a conflict with something within PBX (or my settings are conflicting).This table is one of my favorites, but if I can't launch it from PBX, it won't ever get played. That would be a shame because it's such an amazing table.Here are my PBX files and I'm hoping something can be found that I can change. PBX config:[Display]Monitor=0rotate=270Windowed=Falsewindowwidth=480windowheight=270windowx=592windowy=294PlayFieldBrightness=250WheelTextColor=ff506f00WheelTextOutlineColor=ff000000InfoTextColor=ffffffffInfoTextOutlineColor=ff000000FilterTextColor=ffffffffFilterTextOutlineColor=ff000000MenuColor=ffbbbb00WheelAutoCrop=FalseFullScreenWindowed=TrueShowExitImageFor=2[backGlass]monitor=1x=0y=0width=1360height=768UseB2S=False[DMD]Enabled=Truemonitor=2x=25y=230width=1320height=332AutoPositionPinMAME=FalseUsePinMAME=FalseHidePinMAME=False[FileSystem]EnableFileMatching=False[interface]DesktopModeEnabled=FalseEnableAdditionalDetail=TrueShowSystem=TrueShowRatings=FalseOneClickLaunch=TrueWheelOverlay=2[Audio]StreamVolume=40SampleVolume=40PlaySoundInVideos=True[startup]playsound=Falseplayvideo=FalseStartWithWindows=Yes[KeyCodes]quit=69left=160right=161select=13rotate=82pageleft=33pageright=34exitemulator=69ingame=80screenshot=121screenshotbackglass=120instructions=73volumedown=189volumeup=187[JoyCodes]quit=7left=9right=1select=8rotate=pageleft=4pageright=2exitemulator=7ingame=6instructions=[Text]Line1=Select Table with FlippersLine2=Press Start[FuturePinball]Enabled=TrueWorkingPath=D:\Future Pinball\BAMTablePath=D:\Future Pinball\TablesExecutable=FPLauncher.exeParameters=/STAYINRAM /open "[TABLEPATH]\[TABLEFILE]" /play /exitLaunchBeforeEnabled=TrueLaunchBeforeWorkingPath=D:\Future PinballLaunchBeforeExecutable=FutureDMD.exeLaunchBeforeHideWindow=TrueLaunchBeforeWaitForExit=FalseLaunchAfterEnabled=FalseLaunchAfterWorkingPath=LaunchAfterExecutable=notepad.exeLaunchAfterHideWindow=FalseLaunchAfterWaitForExit=TrueMouseClickFocus=TrueFPRAMPath=D:\Future Pinball\fpRAMLaunchBeforeParameters=table="[TABLEFILE]" close=1LaunchAfterParameters=[VisualPinball]Enabled=TrueWorkingPath=C:\Program Files (x86)\Visual PinballTablePath=C:\Program Files (x86)\Visual Pinball\TablesExecutable=VPinball.exeParameters=/play -"[TABLEPATH]\[TABLEFILE]"LaunchBeforeEnabled=falseLaunchBeforeWorkingPath=LaunchBeforeExecutable=notepad.exeLaunchBeforeHideWindow=FalseLaunchBeforeWaitForExit=TrueLaunchAfterEnabled=FalseLaunchAfterWorkingPath=LaunchAfterExecutable=notepad.exeLaunchAfterHideWindow=FalseLaunchAfterWaitForExit=True[ExitScreen]Enabled=TrueEnableExit=TrueEnableShutdown=TrueConfirmExitGameTimer=False[startupProgram]Enabled=falseWorkingPath=Executable=notepad.exeParamaters=HideWindow=trueWaitForExit=false[ExitProgram]Enabled=falseWorkingPath=Executable=notepad.exeParamaters=HideWindow=FalseWaitForExit=[AttractMode]Enabled=TrueTimer=2ShowFor=30MuteAudio=False[system_1]Name=MAMEEnabled=FalseWorkingPath=C:\- EMULATORS -\- MAME -TablePath=C:\Executable=mamep64.exeParameters=[TABLEFILE]SystemType=0LaunchBeforeEnabled=FalseLaunchAfterEnabled=False[AutoExit]Enabled=TrueMinutes=45[Login]Enabled=False[PinballFX2]Enabled=FalseWorkingPath=D:\SteamExecutable=Steam.exeParameters=-applaunch 226980 "[TABLEFILE]" < parameter “Tablefile” will launch tables directly>Process=Pinball FX2WaitFor=-1LaunchBeforeEnabled=FalseLaunchBeforeWorkingPath=D:\PinballXLaunchBeforeExecutable=Pinball_FX2_Borderless_DMD.ahkLaunchBeforeWaitForExit=FalseLaunchAfterEnabled=TrueLaunchAfterWorkingPath=D:\PinballXLaunchAfterExecutable=KillPFX2.batLaunchAfterWaitForExit=False[internal]lastwheelcachematchsize=2479260lastselected=The Addams Family - NightThe Addams Family - PM5 NightSystem_3filter_year=filter_company=filter_custom=filtername=Tableslastwheelcachematchsize2=0[setupWizard]EmuPath1=C:\EmulatorsAssetPath1=C:\AssetsRomPath1=C:\RomsDefaultPathPrompt=TrueDownloadDatabasePrompt=TrueDownloadEmulatorPrompt=TrueWizardMode=1CustomArray=SearchArray=SavePosition=FalseSectionIndex=0SearchText=EmulatorIndex=0EmulatorGroupIndex=0DaphneIndex=0HTMLAppsIndex=0ExternalAppsIndex=0RadioStationsIndex=0NewsFeedsIndex=0MappedDrivesIndex=0SystemIndex=2ShowPanel=TrueFontSize=1WindowState=0WindowSize=1092,737WindowLocation=125,137[GameListManager]onlinemode=false[Plugin_1]Enabled=TrueName=FutureDMDStats.dll[Plugin_2]Enabled=TrueName=PlugInLED.dll[Plugin_3]Enabled=FalseName=PlugInSpeech.dll[Plugin_4]Enabled=TrueName=QuickLaunch (PinballX Edition).dll[Plugin_5]Enabled=FalseName=Xpadder Plugin.dll[system_3]Name=Visual Pinball - PhysMod5WorkingPath=C:\Program Files (x86)\Visual PinballTablePath=C:\Program Files (x86)\Visual Pinball\TablesExecutable=VP_PM5.exeParameters=/play -"[TABLEPATH]\[TABLEFILE]"Enabled=TrueSystemType=1LaunchBeforeParameters=LaunchBeforeEnabled=FalseLaunchBeforeWorkingPath=LaunchBeforeExecutable=LaunchBeforeWaitForExit=FalseLaunchBeforeHideWindow=False[system_2]Name=WorkingPath=TablePath=Executable=Parameters=XML: 24Stern2009FalseFalseFalse0ACDC PhysModStern2012FalseFalseFalse0AC-DC_PhysMod5_Helen_rev.1.1cssFalseFalseTrue0Attack From MarsMidway1995FalseFalseTrue0Austin PowersStern2001FalseFalseTrue0AvatarStern2010FalseFalseTrue0Back to the Future1990TrueFalseTrue0Big Bang BarFalseFalseTrue0Big Buck HunterFalseFalseTrue0Black RoseMidway1992FalseFalseTrue0Bride of PinbotWilliams1991FalseFalseTrue0Cactus CanyonMidway1998FalseFalseTrue0Cirqus VoltaireMidway1997FalseFalseTrue0CometWilliams1985TrueFalseTrue0Creature from the Black LagoonWilliams1992FalseFalseTrue0EarthshakerWilliams1989FalseFalseFalse0Elvira and the Party MonstersWilliams1989FalseFalseFalse0ElvisStern2004FalseFalseTrue0F-14 Tomcat (Williams 1987) PhysModWilliams1987FalseFalseFalse0Fish TalesWilliams1992FalseFalseTrue0Flash GordonBally1981FalseFalseTrue0FunhouseWilliams1990FalseFalseTrue0Getaway Physmod5Williams1992FalseFalseTrue0Harley DavidsonFalseFalseTrue0HookData East1992FalseFalseTrue0Hook (Data East 1992)Data East1992FalseFalseFalse4Indiana JonesWilliams1993FalseFalseTrue0Indiana Jones (Stern 2008)Stern2008FalseFalseTrue3Jurassic ParkData East1993FalseFalseTrue0Medieval MadnessWilliams1997FalseFalseTrue4Monster BashWilliams1998FalseFalseTrue0Mystery CastleAlvin G1993FalseFalseTrue0OxoWillams1973FalseFalseTrue0Party ZoneWilliams1991FalseFalseFalse0Party Zone - Night PhysModWilliams1991FalseFalseTrue0PlayboyFalseFalseFalse0Power PlayBally1978TrueFalseTrue0QBerts QuestGottlieb1983TrueFalseTrue0Red and Ted's RoadshowWilliams1994FalseFalseTrue0Road RaceGottlieb1969FalseFalseFalse0Scared StiffWilliams1996FalseFalseTrue0South ParkSega1999FalseFalseFalse0Star Trek the Next GenerationWilliams1993FalseFalseTrue0Star WarsData East1992FalseFalseTrue0Starship TroopersSega1997FalseFalseFalse0T2 Chrome PhysModWilliams1991FalseFalseTrue0Tales of the Arabian NightsWilliams1996FalseFalseFalse0TaxiWilliams1988FalseFalseTrue0The Addams FamilyMidway1992FalseFalseFalse0The Addams Family - DayMidway1992FalseFalseTrue0The Addams Family - NightMidway1992FalseFalseTrue0The AvengersStern2012FalseFalseTrue0The FlintstonesWilliams1994FalseFalseTrue0The SimpsonsData East1990FalseFalseTrue0The Simpsons (Data East 1990)FalseFalseFalse4Theatre of MagicMidway1995FalseFalseTrue0TransformersStern2011FalseFalseTrue0Tron LegacyStern2011SSFalseFalseTrue0WhitewaterWilliams1993FalseFalseFalse0World Cup SoccerMidway1994FalseFalseFalse0World Poker TourStern2006FalseFalseFalse0WWF Royal RumbleData East1994FalseFalseFalse0X-MenStern2012FalseFalseTrue0 Link to comment Share on other sites More sharing options...
Jannek Posted October 8, 2015 Share Posted October 8, 2015 Hey Scooby1,if this table runs fine outside PBX, this may be an issue with your available resources (ACDC is very hungry for resources...).You may test if the table runs fine with the "Lite Version" of PBX (you will find it in the same Folder as the regular exe).This won´t help you in total, because the Lite Version does not show BG and DMD in the PBX menu, but maybe this hintpoints you in the direction for a suitable solution.Kind regards,Jannek 1 Link to comment Share on other sites More sharing options...
Scooby1 Posted October 8, 2015 Author Share Posted October 8, 2015 Thanks Jannek. I tried the PBX lite version but the ACDC Stern table is still crashing every launch from PBX (regular or lite version). This is the only table that does this.Here are my system specs:AMD A10-7850K Radeon R7 Quad Core 3.70 GhzSapphire Dual-X Radeon R9 280 3GB 384-Bit GDDR5 GPUGigabyte GA-F2A88XM-D3H FM2+/FM2 AMD A88X 6Gb Motherboard120GB SSD (C drive)256GB SSD (D drive)8GB RAMWindows 7From everything I've read, I should have plenty of horse power to run all tables and PBX. Is this correct or do I need more RAM?If this wasn't such a great table, I might just forget about this one. However, it's one of my favorites so I really want to figure this out and launch it from PBX.Any other suggestions? I would greatly appreciate it! Link to comment Share on other sites More sharing options...
Draco1962 Posted October 8, 2015 Share Posted October 8, 2015 Maybe redownload the table? I am at a loss here. Can you provide your log.txt file from right after the table crashes? That is the only file you haven't provided that might provide a clue. Link to comment Share on other sites More sharing options...
Scooby1 Posted October 9, 2015 Author Share Posted October 9, 2015 Thanks Draco, here is my log. I hope you see something that I need to change (fingers crossed)!Log: 21:12:52.3 10/8/2015: PinballX - Version 2.0421:12:52.3 10/8/2015: Windows 7 Home Premium Service Pack 1 64-bit (6.9GB)21:12:52.3 10/8/2015: Loading Settings21:12:52.4 10/8/2015: Initialize Component21:12:52.4 10/8/2015: Initialize Display21:12:53.5 10/8/2015: Loading PlugIns21:12:53.5 10/8/2015: Loaded Plugin:"FutureDMD PinballX Stats" Version 1 By GauntletLover21:12:55.1 10/8/2015: PlugIn: "FutureDMD PinballX Stats" Initialized OK21:12:55.1 10/8/2015: Using Plugin System Version: 121:12:55.1 10/8/2015: Loaded Plugin:"LED Plugin" Version 1 By Tom Speirs21:12:55.1 10/8/2015: PlugIn Did not initialize. Disabling PlugIn21:12:55.1 10/8/2015: Loaded Plugin:"QuickLaunch for PinballX" Version 1.0.4 By Adultery21:12:55.1 10/8/2015: PlugIn: "QuickLaunch for PinballX" Initialized OK21:12:55.1 10/8/2015: Using Plugin System Version: 121:12:55.3 10/8/2015: Created DirectX BackGlass Window21:12:55.4 10/8/2015: Created DirectX DMD Window21:12:55.6 10/8/2015: Hiding Cursor21:12:55.6 10/8/2015: Hiding Taskbar21:12:55.7 10/8/2015: CPU: AMD A10-7850K Radeon R7, 12 Compute Cores 4C+8G21:12:55.7 10/8/2015: GPU 1: AMD Radeon R9 200 Series21:12:55.7 10/8/2015: GPU 2: AMD Radeon R7 Graphics21:12:55.7 10/8/2015: Displays: 321:12:55.9 10/8/2015: Load Game List21:12:55.9 10/8/2015: Loading Database: Future Pinball21:12:56.0 10/8/2015: Loading Database: Visual Pinball21:12:56.0 10/8/2015: Loading Database: Visual Pinball - PhysMod521:12:56.0 10/8/2015: Finding and matching artwork and videos21:12:56.2 10/8/2015: Also Creating and Caching Wheels for Overlays21:12:56.4 10/8/2015: Loading Game Statistics and Scores21:12:56.4 10/8/2015: Main display running full screen windowed.21:12:56.5 10/8/2015: Loading Surfaces21:12:56.8 10/8/2015: Finished Loading Surfaces21:12:56.8 10/8/2015: Initialize Audio21:12:56.9 10/8/2015: Set Keyboard Controls21:12:56.9 10/8/2015: Initialize Joystick21:12:57.0 10/8/2015: 1 Joystick Attached21:12:57.0 10/8/2015: Started21:14:15.2 10/8/2015: Launch System21:14:15.2 10/8/2015: Waiting for threads21:14:15.2 10/8/2015: Disposing display21:14:18.9 10/8/2015: C:\Program Files (x86)\Visual Pinball\VP_PM5.exe /play -"C:\Program Files (x86)\Visual Pinball\Tables\Medieval Madness Physmod.vpt"21:14:19.0 10/8/2015: D:\PinballX\vpauto.exe21:14:31.4 10/8/2015: Hidden Visual Pinball Editor Window21:15:17.3 10/8/2015: Exit System Control Pressed21:15:25.7 10/8/2015: Created DirectX BackGlass Window21:15:25.7 10/8/2015: Created DirectX DMD Window21:15:25.7 10/8/2015: Main display running full screen windowed.21:18:59.4 10/8/2015: Launch System21:18:59.4 10/8/2015: Waiting for threads21:18:59.5 10/8/2015: Disposing display21:19:03.1 10/8/2015: C:\Program Files (x86)\Visual Pinball\VP_PM5.exe /play -"C:\Program Files (x86)\Visual Pinball\Tables\AC-DC_PhysMod5_Helen_rev.1.1c.vpt"21:19:03.1 10/8/2015: D:\PinballX\vpauto.exe21:19:16.5 10/8/2015: Hidden Visual Pinball Editor Window21:19:31.6 10/8/2015: Created DirectX BackGlass Window21:19:31.7 10/8/2015: Created DirectX DMD Window21:19:31.7 10/8/2015: Main display running full screen windowed.21:19:39.3 10/8/2015: Exiting21:19:41.1 10/8/2015: Showing Taskbar21:19:41.4 10/8/2015: Unhiding Mouse Cursor21:19:41.4 10/8/2015: Disposing Plugins21:19:41.4 10/8/2015: Saving Settings21:19:41.4 10/8/2015: Bye Link to comment Share on other sites More sharing options...
Jannek Posted October 9, 2015 Share Posted October 9, 2015 Sorry Scooby,I´m out. I like this table as well, but it´s always crashing on my System. So I will have to wait until I get a more powerful PC and will my own tests later on. Therefore I´m not able to give you further hints...Kind regards,Jannek Link to comment Share on other sites More sharing options...
Draco1962 Posted October 9, 2015 Share Posted October 9, 2015 Was the log.txt right after attempting to launch ACDC?Also, you may want to "google" the following key words "acdc table crashing" and check the two threads that show in the top of your search. I have a feeling that, even though you can get it to run outside of PinballX (although you did not state clearly if you ran it mutliple times back-to-back), I do not think that this is necessarily a PinballX issue.If anyone else has this table running OK via PinballX, please chime in. 1 Link to comment Share on other sites More sharing options...
Carny_Priest Posted October 9, 2015 Share Posted October 9, 2015 Yes, AC/DC launches fine from within PBX. Link to comment Share on other sites More sharing options...
Scooby1 Posted October 9, 2015 Author Share Posted October 9, 2015 I did grab the log.txt after launching ACDC. It shows both the ACDC table and MM table attempted and one thing I notice in the log is MM shows Exit System Control Pressed (since I pressed the exit table button). The ACDC table shows Exiting, not Exit System Control Pressed (I did not press anything, it just crashes). Is this because VP crashed after launching ACDC or is this a normal log entry?It sounds like this might be the most resource intensive VP table (at least of the tables I have). There is an ACDC non-rom table, that plays great. It's just this amazing Stern version from Javier15 that is giving me so much trouble.Are there settings I should look at to be sure my system has enough resources/horse power to run this table every time? Link to comment Share on other sites More sharing options...
Draco1962 Posted October 9, 2015 Share Posted October 9, 2015 I don't think that your system resources are insufficient. I may be a matter of how this particular table was written. Link to comment Share on other sites More sharing options...
Ginsonic Posted October 13, 2015 Share Posted October 13, 2015 Scooby1,I had troubles with that table too. If I remember correctly, I compiled (script) and saved the PM5 table using Visual Pinball (regular EXE, not PM5 !) and then started it again with the correct PM5 VP version.Worth a try ! Link to comment Share on other sites More sharing options...
Scooby1 Posted October 13, 2015 Author Share Posted October 13, 2015 Thanks Ginsonic. For someone like me who has not done this, how exactly is it done? I open the ACDC stern table with regular VP, open the script, then what do I change in the script before compiling? Link to comment Share on other sites More sharing options...
Ginsonic Posted October 14, 2015 Share Posted October 14, 2015 Open table file in "normal" VP.exeOpen script editorNo need to change anything !Select "compile" from menuClose Script editor windowSave File (Ctrl + S)Then close VP.exe and try to start it in VP_PM5 using PinballXIf this does not work, try to repeat the steps above using VP_PM5.exeI once tried some combinations compiling/saving, but I do not exactly remember, which worked finally.But it worked ;-) 1 Link to comment Share on other sites More sharing options...
Scooby1 Posted October 14, 2015 Author Share Posted October 14, 2015 Thanks for the suggestion. It could have been this (probably was), as I can now get ACDC Stern to launch from PBX, well, most of the time. The table still seems to have trouble sometimes if I have any other program running in the background. For example, if I have been making changes to PBX and the Game Manager open or a web browser, then this table sometimes crashes on launch.For the most part, it seems to be running more consistently. I still consider this an unpredictable table, as I never know if it's going to launch or crash.Since it's now launching more than it's crashing, I'm going to leave it and see how it does when it gets more play.Thanks for the help! Link to comment Share on other sites More sharing options...
Scooby1 Posted October 20, 2015 Author Share Posted October 20, 2015 Update: This awesome table now plays every time it's launched from PBX (all other programs need to be closed). It is now among the top 5 tables played on my cab!Thanks for the great work and support! 1 Link to comment Share on other sites More sharing options...
tthurman Posted October 21, 2015 Share Posted October 21, 2015 Nothing short of great news here, as this is an obvious favorite table of many, and one that has proved difficult to run for many!Thanks for following through so others will not throw in the towel when faced with a bit of adversity here Link to comment Share on other sites More sharing options...
