Hello,
Must say i really like the GameEx front-end and i have been having a play the last few days.
The problem i have is i cant seem to get the theme to change i download the theme i want to use via the wizard, i pick it in the theme selector and close.
When i launch gameex it launches the default theme everytime. I have double checked and the correct theme has been set but it doesnt appear to change
When i open backup the wizard the theme i want is still selected.
I am sure this is an easy fix but i cant seem to work it out.
Any help would be greatly appreciated
Regards
Couple things, see my sig for posting some support files, your ini and log, we may be able to spot something in there that's causing. It's always a good place to start.
Secondly, try downloading one from the repository, and manually installing it.
GameEx>Themes
or via the Repository Manager located in the GameEx program group.
One additional note, you will want to make sure that you are running gameex,exe as administrator (select this for all users if multiple users on your PC).
Absolute "face palm" moment the desktop icon i had setup was launching to game launcher mode.
Sorry guys appreciate the speedy response.
It always makes sense when you look at it with fresh perspective.
Shuwatch! - I will post ini and log files in the future wasn't aware of the options.
