hi
i use Supermodel-r271-x86x64 to run my games. outside i have no problem.
i used the map file attached to the thread..i recevie black screen if i disable desktop view. if i active descktop view i see the emulator and the rom choice ( and then start...)
i use this to run games
Supermodel-UI exe "[rompath]\[romfile]"
also tried
Supermodel.exe "[ROMPath]\[ROMFile]"
also the video downloaded from emu movie doesen't start...
thanks
GameEx.ini
Plug this into Google Search: site:www.gameex.info supermodel
I was able to find the answers you seek.
There are a few more links using that search that are more recent you will want to review as well.
thanks. i verified that there was not the resolution in the string...
another question. the game listed are all playable? i have some of them that doesen't start.. ex emergency
Supermodel is far from perfected, and development seems to be mostly from the community side currently. Like everyone else, their dev's have real life issues to contend with too, but hopefully they will return to it at some point.
I've followed it with great interest myself, but I would suggest you head over to their forum for more specific details concerning what is, and is not functional,
The Supermodel site also has a list of games and what is playable or not. as tthurman noted, the emulator sites generally are the best source of what is playable or not.
