So new issue when pinballx loads the backglass shows different game then imported. example terminator selected and tron backglass shows. When the game is loaded the backglass corrects itself. Then switches back when entering pinballx front end. I have found and deleted all png image files of the one showing in pinballx still continues to remain. Is there a location where that file is cached or stored. I have imported it from the FTP and selected manually. Also deleted it in game list manager and readded. Just reinserts it. Any insight would be great. Tks in advanced.
  Reveal hidden contents
Display]
Monitor=0
rotate=270
Windowed=False
WindowWidth=480
WindowHeight=720
WindowX=0
WindowY=65
PlayFieldBrightness=230
WheelTextColor=ffffffff
InfoTextColor=ffffffff
InfoTextOutlineColor=ff000000
FilterTextColor=ffffffff
MenuColor=ff800000
FullScreenWindowed=False
[backGlass]
monitor=1
x=0
y=0
width=1700
height=1400
[DMD]
monitor=2
x=512
y=340
width=900
height=300
[FileSystem]
EnableFileMatching=False
[interface]
DesktopModeEnabled=False
EnableAdditionalDetail=True
ShowSystem=True
ShowRatings=True
[Audio]
StreamVolume=90
SampleVolume=90
PlaySoundInVideos=True
[startup]
playsound=True
playvideo=False
StartWithWindows=No
[KeyCodes]
quit=27
left=37
right=39
select=13
rotate=82
pageleft=33
pageright=34
exitemulator=27
ingame=80
screenshot=83
screenshotbackglass=66
instructions=73
volumedown=109
volumeup=107
[JoyCodes]
quit=7
left=9
right=1
select=8
rotate=3
pageleft=4
pageright=5
exitemulator=7
ingame=13
instructions=14
[Text]
Line1=Terry's PINBALL
Line2=Press Start to select game *** Use Flippers Left and Right to browse games ***
[FuturePinball]
WorkingPath=h:\-PINBALL-\-FUTURE PINBALL-
TablePath=h:\-PINBALL-\-FUTURE PINBALL-\Tables
Executable=Future Pinball.exe
LaunchBeforeEnabled=false
LaunchBeforeWorkingPath=
LaunchBeforeHideWindow=False
LaunchBeforeWaitForExit=True
LaunchAfterEnabled=False
LaunchAfterWorkingPath=
LaunchAfterHideWindow=False
LaunchAfterWaitForExit=True
MouseClickFocus=True
[VisualPinball]
WorkingPath=C:\Program Files (x86)\Visual Pinball
TablePath=C:\Program Files (x86)\Visual Pinball\Tables
Executable=VPinball990.exe
[ExitScreen]
EnableExit=True
EnableShutdown=True
[startupProgram]
Enabled=False
WorkingPath=
Executable=
Paramaters=
HideWindow=true
WaitForExit=false
[ExitProgram]
Enabled=false
WorkingPath=
Paramaters=
HideWindow=False
WaitForExit=
[AttractMode]
Timer=1
ShowFor=15
MuteAudio=False
[system_1]
Name=MAME
Enabled=False
TablePath=C:\
Executable=mamep64.exe
Parameters=[TABLEFILE]
SystemType=0
[AutoExit]
Enabled=False
Minutes=10
[Login]
[PinballFX2]
Enabled=False
Executable=steam.exe
Parameters=-applaunch 226980
Process=Pinball FX2.exe
WaitFor=20
[internal]
lastwheelcachematchsize=-1123
lastselected=Tron LegacyTron FS Physmod5VisualPinball
filter_year=
filter_company=
filter_custom=
filtername=Tables
[setupWizard]
EmuPath1=C:\Emulators
AssetPath1=C:\Assets
RomPath1=C:\Roms
DefaultPathPrompt=True
DownloadDatabasePrompt=True
DownloadEmulatorPrompt=True
WizardMode=1
CustomArray=
SearchArray=
SavePosition=False
SectionIndex=5
SearchText=
EmulatorIndex=0
EmulatorGroupIndex=0
DaphneIndex=0
HTMLAppsIndex=0
ExternalAppsIndex=0
RadioStationsIndex=0
NewsFeedsIndex=0
MappedDrivesIndex=0
SystemIndex=0
ShowPanel=True
FontSize=1
WindowState=0
WindowSize=1204,688
WindowLocation=81,281
[GameListManager]
onlinemode=true
23:16:33.4 7/16/2015: PinballX - Version 2.02
23:16:33.4 7/16/2015: Windows 7 Professional Service Pack 1 64-bit (3.9GB)
23:16:33.4 7/16/2015: Loading Settings
23:16:33.4 7/16/2015: Initialize Component
23:16:33.5 7/16/2015: Initialize Display
23:16:34.8 7/16/2015: Loading PlugIns
23:16:35.2 7/16/2015: Created DirectX BackGlass Window
23:16:35.3 7/16/2015: Created DirectX DMD Window
23:16:35.5 7/16/2015: Hiding Cursor
23:16:35.5 7/16/2015: Hiding Taskbar
23:16:35.6 7/16/2015: CPU: Intel® Core2 CPU 6400 @ 2.13GHz
23:16:35.6 7/16/2015: GPU 1: NVIDIA GeForce GTX 550 Ti
23:16:35.6 7/16/2015: Displays: 3
23:16:35.6 7/16/2015: Load Game List
23:16:35.6 7/16/2015: Loading Database: Future Pinball
23:16:35.7 7/16/2015: Loading Database: Visual Pinball
23:16:35.7 7/16/2015: Finding and matching artwork and videos
23:16:36.0 7/16/2015: Loading Game Statistics and Scores
23:16:36.5 7/16/2015: Loading Surfaces
23:16:36.9 7/16/2015: Finished Loading Surfaces
23:16:36.9 7/16/2015: Initialize Audio
23:16:37.0 7/16/2015: Set Keyboard Controls
23:16:37.0 7/16/2015: Initialize Joystick
23:16:37.2 7/16/2015: 1 Joystick Attached
23:16:37.2 7/16/2015: Started
  • 1 year later...
Bump, because I have the same problem and could not find a solution yet. Please help!
Bump without a copy of your pinballx.ini and log.txt files won't get you very far towards a solution. ;)
General troubleshooting
In pinballx settings, turn off "Enable File Matching"
Make sure the media filenames exactly match the table filename or table description name in the xml file
