jester82 Posted June 8, 2015 Share Posted June 8, 2015 I Set both disable exit and disable escape key and it still exits when player 2 start and player 2 coin are pressed. Any ideas? Link to comment Share on other sites More sharing options...
Draco1962 Posted June 8, 2015 Share Posted June 8, 2015 Hi - When reporting issues, it is better to submit a new thread rather than in a [NEWS] item that may get overlooked. I went ahead and split your issue into a new thread.Please provide copies of your gameex.ini and log.txt (Click here for additional information on how to find these files and others that may be required).Thanks. Link to comment Share on other sites More sharing options...
jester82 Posted June 8, 2015 Author Share Posted June 8, 2015 Some reason I cant seem to paste my ini file??? So I just attached it.. Link to comment Share on other sites More sharing options...
tthurman Posted June 8, 2015 Share Posted June 8, 2015 I don't see it.I order to paste, stay way upper left in the reply window, right clicking in order to get it to show as an option. Link to comment Share on other sites More sharing options...
DazzleHP Posted June 8, 2015 Share Posted June 8, 2015 Bare in mind you need to click "Attach This File" after browsing to it Link to comment Share on other sites More sharing options...
jester82 Posted June 22, 2015 Author Share Posted June 22, 2015 sorry for late reply, was out of town. here is my config file for real this time GameEx.ini Link to comment Share on other sites More sharing options...
Draco1962 Posted June 22, 2015 Share Posted June 22, 2015 Sorry to inform you that GameEx is now up to version 14.11. Please update your installation to that version and report back with both your up-to-date gameex.ini and log.txt files. We need both to troubleshoot. If the update fixes the issue you are having, let us know as well. Thanks! Link to comment Share on other sites More sharing options...
jester82 Posted June 22, 2015 Author Share Posted June 22, 2015 My GamEx is up to date to version 14.11. That config file was from the newest version. here is the log file too...log.txt Link to comment Share on other sites More sharing options...
DazzleHP Posted June 22, 2015 Share Posted June 22, 2015 Try this:Load the Setup Wizard> Custom> Input Settings.Scroll down to find Global Exit.To the right of Global Escape Key Combo click the browse button [...] then click Clear.To the right of Joystick Exit click the browse button [...] then click Clear.All exit combos should now be disabled. 2 Link to comment Share on other sites More sharing options...
Draco1962 Posted June 22, 2015 Share Posted June 22, 2015 I changed the title to reflect the latest version. The log.txt file contains that info, and lots of other goodness, hence why we ask for it along with the gameex.ini file.EDIT: Issue deprecated as of many later versions (now at 14.37). Submit a new thread if still an issue. 1 Link to comment Share on other sites More sharing options...
