Hi
I'm à newbie in gameex and after a lot of tests I don't understand when I execute gameex with mame V0.161 I finish with this message reading listinfo.dat ( 25%) and after nothing
If I use mame V0.145 there is no problem and the listinfo.dat is create normally
I join my log
thanks for you're help
Welcome to the GameEx forums!
Have you updated after you made any configuration changes?
Does your romset match your mame relase, 0.161? If you're running an old 0.145 set, with a new MAME build, that's not recommneded, especially with that much difference in releases.
If your set matches the release, you could try renaming your current listinfo to something like oldlistinfo.dat, and then go back into GameEx, and run update to rebuild a new one.
We need to see your gamex.ini
Edited by tthurman
Hi
I have two directories one with mame 0145 and one with mame0161 but i use the same directory for the roms and I delete at each run listinfo.dat
I join my last log and my last game.ini
GameEx.ini
Hi
I run gameex with mame 0161 with only 1 rom in the directory "rom" and I have the same result
hmmm
Double check and ensure your paths are correct.
Try these configuration changes
Only Working - Yes
Allow Imperfect - Yest
Verifgy - No
Only Existing - Yes
Then remember to update list within GameEx, and try again
I'm a bit confused..
How can you use the same rom set and point two different mame builds at it and have both be proper to the version?
I'm guessing that there's an issue with the mame.exe since the list comes from there.
delete listinfo.dat
verify path
Path ok ( verify with test on wizard)
custom mame
Only Working - Yes
Verify - No
Only Existing - Yes
run gameex
Same result block a 25%
ps : Then remember to update list within GameEx --> ?? --> how I do this ?
thanks for help
Inisde GameEx, click Mame, scroll to the bottom "update list"
Takes awhile with a full romset.
I take it he is upgrading from an old build, and has a directory for 0.145, and a directory for 0.161, but has configured it GameEx to point to the 0.161 directory, and has simply moved his old roms out of the rom folder, and put a single rom from 0.161 there.
Edited by tthurman
Correction, Mame, not Home
Yeah that's my guess too. Which typically doesn't work. ;)
ok I have reinstalled gameex
step by step after installation
1 ) I execute gameex the first time I choose more game
2 ) I choose configuration , then language, then base,
3 ) eight time "next"
4 ) I choose install mame option
5 ) I choose parameters optin : path mame, mame.exe, path roms , that all after i delete all selection with mame version 0.161
6) next
7 ) I choose mame in selection choose emulator menu but no download
8 ) next
9 ) cross to finish
10) update list --> I confirm
11 block in reading listinfo.dat : 25%
have you I idea ?
thanks
I have reinstalled again gameex
2 ) I choose configuration , then language, personalise and i choose only mame settings
3 ) I choose parameters optin : path mame, mame.exe, path roms , that all after i delete all selection with mame version 0.161
4 ) cross to finish
5 ) update liste confirm
6) block in reading listinfo.dat : 25%
I don't understand the problem
thanks
GameEx.ini
I have reinstalled again gameex but to use mame 0.145
3 ) I choose parameters option : path mame, mame.exe, path roms , that all after i delete all selection with mame version 0.145
4 ) cross to finish
6) that's ok liste created with no problem
what is the difference between mame 0.145 and mame 0.161 I don't no but the result is ok for 0.145 et ko with 0.161
I don't know the problem it's very strange
As I said before, it's probably your mame.exe.
Yes I think I have a problem with my mame.exe
can I send to me a good link for a mame.exe ?
thank a lot
Hello
I've found the solution for all version > .145
I download mame 0.161
I decompress it
I keep only directories (roms, snap) and mame.exe and after I execute gameex
I choose personalize option and i choose only mame settings
I choose parameters option : path mame, mame.exe, path roms, path snap , that all
4 ) cross to finish
I think that some files block with this delete it's all right
thanks for all :)
Every time i update a new mame with gameex it takes maybe 2-4 hours, it always does, a few months ago i kept thinking that gameex had just crashed, but just let it keep going, a pain in the arse i know, but i normally have a kip...
mak
May not be a directly related issue so since the issue reported by the OP is resolved, I am locking this thread.
@shatshoes - If you would like for us to continue with assistance for your issue, please open a new thread with the pertinent info and attachments. Thanks!
