AO I've been fighting with this for three nights, up until 2:30 trying different approaches every night. I'm about done, unless someone can help.
I have been working against a list of about 50 roms, Gameex detects NONE of them. I've tried a dozen different MAME versions and builds, every solution seen so far on this forum. If I step up to a set of 4,000 roms that I have on a separate drive, Gameex will detect about 78 of them. Obviously, my Rom folder is correct if it detects a subset of the roms... Nothing is working at this point.
Everythign was PERFECT until Sunday, when I paid to get a lifetime subscription. I'm at the point now where I regret that choice, and will probably have to seek a refund and switch to Maximus arcade, since I know that it actually works, whereas I have been completely unable to use gameex at all, no matter how much more I like it....
Sounds like you've most likely read the threads about adjusting for the filtering options already, but the problem you're describing is almost always related to this.
Have you tried downloading the current version and simply doing a over the top installation, followed by updating?
You should post your .ini and log so we can see how you have things configured. Integrated MAME support or Emulator? We don't have a whole lot to go on.
How to ask for help
At work now, but have to work a half day so that my wife can go to the doctor. I'll try installing latest version when I get home, and if that fails, I'll post ini, etc...
At this point, I have filters turned off, so not even sure how that could be the issue.
Given your description, it sounds as if something may have went South on you during the registration installation. Hopefully a reinstall will resolve the issue for you. I'm obviously biased, but I think if we can successfully work you through this, you will be much happier with a current, and supported product.
I'm sure I will. I loved the system prior to registering. I've just gotten to a point of frustration that I can't sort this out. I'm a configuration monkey for a living, so the fact that I can't get this working right so far is a double whammy, since it is hurting my ego as well. 😕
One question I do have, though. It very well could be something that I screwed up in running through advanced configuration. I first installed gameex on Saturday, so would assume I have the latest version. I've done several "fresh" installs since, after deleting the gameex folders entirely, but a lot of my settings seem to stick from one install to the next... Is there any way to completely wipe these out so that I am truly starting fresh?
Got it to recognize about 200 games earlier today, but still not ones I care about... If I run against an EMPTY roms folder, it gives me two famicom bioses...
INI file below, incase that is the issue:
You should still be able to post it as an attachment. It would also be helpful to take a look at your log as all of this is going on. Seeing the information contained in these files will allow us to get a better picture of what's happening. Here are some instructions, if you're not entirely sure of how to get to that info. Don't go to MA dude, it's barely even supported anymore! (and there's almost certainly no hope of bug fixes/improvements AFAIK) :D
Try turning off 'verify roms' and update the list again?
I have to turn off "only existing Roms" to get it to identify anything, if I turn off verify, won't that leave me with every single rom showing?
I recommend providing us with a copy of your gameex.ini and log.txt (Click here for additional information on how to find these files and others that may be required). If you prefer to attach the files, you can click on Use Full Editor at the bottom of your reply to this thread and click the Choose Files... button that will appear in the lower left of your reply.
No, there is all kinds of crap none of us want, and Tom knows that :D
Stuff like wack a mole and the like, it's filtered elsewhere, but if you have it verify, then it will check it to make sure it's 100% functional in every way. This really isn't necessary, and will exclude many titles!
Edited by tthurman
okay not crap, but you know what I mean!
ini:
  Reveal hidden contents
[gameexonline]
StreamQuality=0
[general]
Xresolution=800
Yresolution=600
DisplayOnSecondary=False
mamepath=C:\MAME Plus!
mameexe=mamep.exe
rompath=C:\MAME Plus!\roms
StartWait=False
USeAdvanceMame=False
AdvanceMAMEEXE=
AdvanceMAMEPATH=
ADVANCEMAMEOptions=
UseZinc=False
ZincEXE=
ZincPATH=
ZincOptions=
Font=Trebuchet MS
TitleText=MAME Games
OnlyWorking=False
AllowImperfect=True
VerifyRoms=True
OnlyRoms=True
NoGameInfo=True
GameFilter=Japan;Korea;Asia;Hispanic;Bootleg;French;German;Hack;Prototype;Hardware;Spanish;(Easy;(harder
GameFilterOn=True
NoAdult=False
NoClones=False
MameOptions=-nowindow -joy -skip_gameinfo
ArcadeMode=False
UseLargeFonts=True
snappath=C:\MameUI64\snap
avisnappath=
AVIFrameSkip=0
flyerpath=C:\MameUI64\flyers
cabinetpath=C:\MameUI64\cabinets
CatverLocation=C:\GameEx\DATA\catver.ini
nplayerslocation=C:\GameEx\DATA\nplayers.ini
HistoryLocation=C:\GameEx\DATA\history.dat
InfoLocation=C:\GameEx\DATA\mameinfo.dat
CommandLocation=C:\GameEx\DATA\command.dat
ShowGameInfoPage=True
EnableStartPage=True
ShowStartPageFirst=True
skipintro=False
AntiAliasFonts=True
OutlineFonts=False
DisplayBackgroundImage=True
SnapBrightness=120
MusicPlayList=H:\Music
MusicVolume=100
MediaCenterMode=2
PlayIntroSound=True
AttractModeTimer=4
AttractModeAudio=2
UsingArcadeVGA=False
StretchResToX=640
StretchResToY=288
TryToStretchto256=True
NoWaitVSync=False
Sleep=True
HideUpdateList=False
DisableExit=False
HideShutDown=False
StartUpVideo=C:\Video
LaunchOnStart=
LaunchOnStartNoWait=
LaunchOnExit=
LaunchOnExitNoWait=
FontSize=0
VectorResX=632
VectorResY=264
AlwaysStretch=410x256
DisableEscape=False
DisableRemoveGame=False
theme=Default - Media Center
Language=English
flatstartpage=False
DontSwitchRes=True
SnapDelay=4
AllowWindowResize=True
ShowLoadingScreen=True
Use16BitColour=False
Widescreen=False
DisableMAME=False
ShellBeforeLaunch=
ShellOnExit=
EnableJukeBox=True
jukeboxplaylist=Live! (CD1)
EnableMediaControls=True
ShufflePlayLists=True
LoadPlayListAtStartup=False
LoadPlayListThread=False
DownloadArt=True
TitleFont=Trebuchet MS
DialogTextWhite=False
TimeFormat=True
HideToolBar=3
DoNotFilterROMS=pacman;splatter
MAMEAudioMode=1
DisplayTitle=True
AVIAudio=True
marqueepath=C:\MameUI64\marquees
panelpath=C:\MameUI64\cpanel
titlepath=C:\MameUI64\titles
iconpath=C:\MameUI64\icons
CPEnabled=True
CPPATH=C:\GameEx\DATA\controls.ini
ShowVector=True
ShowNeoGeo=True
ShowOriginal=True
ShowAdult=True
ShowCPS=True
ShowVertical=True
ShowHorizontal=True
EnableFavorites=True
ShowMulti=True
ShowAllMAME=True
ShowLastGame=True
ShowRandomGame=True
ShowListNumbers=True
AlphaBlendVideos=True
EnableSound=True
MediaCenterOpenCheck=true
UseSharp=True
CreateImageOnThread=False
HideCreateSnaps=False
HideLogoff=False
HideStandBy=False
DisableMouse=False
ShowVideos=False
VideoPath=
EnableAlphaPage=True
EnableJoystick=True
EnableSlikStik=False
KeyboardDirectInput=False
NoMahjong=False
VIDEOFFDSHOW=0
JoystickDevice=
EnableCustomInput=False
EnableCustomJoyInput=False
AttractVideosEnabled=True
attractvideosratio=-1
attractvideospath=C:\GameEx\DEMO\Videos
AtractModeNewGameTimer=2
AdvancedGFX=True
HideZinc=False
TransitionType=0
Bypass=True
DontBlitWait=False
ShowMostPlayed=True
ExcludedMAMERoms=
DeadZoneX=0
DeadZoneY=0
jukeboxmode=0
enableambiance=False
HIDEDESKTOP=True
UseSnapBestMatch=true
IngameVK=121|122
EnableThemePicker=True
DisablePleaseWaitAnimation=False
EnableRipCD=True
DumbyValue=
DVDPath=G:\
AttractOnlyFavs=False
rotateplus90=False
ShowButtons=True
DisplayTitleText=True
PlayExitSaverSound=False
ShowAtari=True
ShowGolden=True
ShowHorizVert=0
UseModel2=False
Model2PATH=
ShowModel2=True
ShowLightGun=True
EnableBezel=False
autoupdate=1
NoMAMEOnStartPage=False
HideRestart=False
EnableStartScreenSaver=True
SortMAMEThE=True
SortEmuThE=True
ShowMCEEXport=True
NoRotationRestrictions=False
MakeToolbarTextWhite=False
ExitGameAfter=0
ShowTrackball=True
ShowSpinner=True
LoadEmusOnThread=True
LoadRadioOnThread=False
StartPageAni=True
EmusAttractMode=False
MuteEmuAttractMode=False
Show4Player=True
CabControlFriendly=False
manualpath=
HideShowTaskbar=True
CustomMAMEFolderPath=
MAMEFavoritesini=
MenuFontSameSize=False
PreviewVideos=2
ShowStatistics=True
DisableMouseWheel=False
ErrorReporting=0
ReduceCPU=True
ShowNotPlayed=True
ShowOnlineLists=True
ScreensaverMode=0
AttractText=Touch screen to start...
GlaunchEnabled=False
PCBPath=
ArtworkPath=
LoadJukeTracksOnStartup=True
EnableLetterSelect=True
JukeQueueMode=0
EnableBezelAttract=True
ForceDailyReboot=-1
EnableSearch=True
FixToEmuList=0
ShowLastPlayed=True
TwoThreeRes=
EnableTouchScreen=True
EnableMediaCheck=True
EnableOtherSystems=True
ForceShutdown=False
EnableHiScore=True
DisplayImageList=False
SortEmulators=True
ShowAllGames=True
InactivityTimer=0
EnableAdvCustomInput=False
HideHibernate=False
EnableKeyboardShutdown=False
AutoRotateMAME=False
EnableLaunchDialog=True
lastmusicpath=\\Nasusa\music
looplist=False
TrackballSupport=False
EnableVisualizations=True
EnableVideoThumbs=False
cabinet3dpath=
EnableClientServerMAME=False
ClientServerMAMEPath=
ClientServerMAMEEXE=
OnQueueEndMode=0
MAMERemoveDupes=0
CommnadLocation=\DATA\command.dat
AutoDownloadDescriptions=False
GameExtenderCustomImageMAMEPath=C:\Mame32\marquees
Enablepopupdescriptions=True
SetPalRes=False
PalRes=800x600x32x60
SetNTCSRes=True
NTSCRes=800x600x32x60
SetNTSCRes=False
SetTwoThreeRes=False
AmbianceFolder=C:\ArcadeAmbiance
EnableEscapeKeyExit=True
DisableChangeView=False
EnabledConfigurationApp=True
resumelastatstartup=False
HelpText=
ShowHistoryAndMAMEInfo=True
baksnappath=
TVVideoPath=
othervideopath=C:\GameEx\DEMO\Videos;C:\Video;[myvideos]
ChangeMonitorFrequency=False
ChangeMonitorResolution=False
NoCasino=False
EnableDownloadService=True
ShowCHD=True
Databasesnappath=
SeekPreviewVideo=0
demoinstalledversion=1
[daphne]
UseDaphne=False
DaphnePath=
DaphneExe=
DaphneSnap=
DaphneOptions=
Enabled_1=True
ROMName_1=
GameName_1=
GameOptions_1=
Enabled_2=True
ROMName_2=badlands
GameName_2=Badlands
GameOptions_2=-framefile "R:\ARCADE\Daphne\vldp\badlands\badlands.txt"
Enabled_3=True
ROMName_3=bega
GameName_3=Bega's Battle
GameOptions_3=-framefile "R:\ARCADE\Daphne\vldp\bega\bega.txt"
Enabled_4=True
ROMName_4=cliff
GameName_4=Cliff Hanger
GameOptions_4=-framefile "R:\ARCADE\Daphne\vldp\cliff\cliff.txt"
Enabled_5=True
ROMName_5=cobraab
GameName_5=Cobra Command
GameOptions_5=-framefile "R:\ARCADE\Daphne\vldp\cobra\cobra.txt
Enabled_6=True
ROMName_6=lair
GameName_6=Dragon's Lair
GameOptions_6=-framefile "R:\ARCADE\Daphne\lair_HD\lair_hd.txt"
Enabled_7=True
ROMName_7=lair2
GameName_7=Dragon's Lair II Timewarp
GameOptions_7=-framefile "R:\ARCADE\Daphne\vldp\lair2\lair2.txt"
Enabled_8=True
ROMName_8=esh
GameName_8=Esh's Aurunmilla
GameOptions_8=-framefile "R:\ARCADE\Daphne\vldp\esh\esh.txt"
Enabled_9=False
ROMName_9=firefox
GameName_9=Firefox
GameOptions_9=-framefile "R:\ARCADE\Daphne\vldp\FireFox\firefox.txt"
Enabled_10=False
ROMName_10=ffr
GameName_10=Freedom Fighter
GameOptions_10=-framefile "C:\Roms\Laserdisc\Freedom Fighter\ffr.txt"
Enabled_11=True
ROMName_11=galaxy
GameName_11=Galaxy Ranger
GameOptions_11=-framefile "R:\ARCADE\Daphne\vldp\galaxyr\galaxyr.txt"
Enabled_12=False
ROMName_12=gtg
GameName_12=Goal to Go
GameOptions_12=-framefile "C:\Roms\Laserdisc\Goal to Go\gtg.txt"
Enabled_13=True
ROMName_13=interstellar
GameName_13=Interstellar
GameOptions_13=-framefile "R:\ARCADE\Daphne\vldp\interstellar\interstellar.txt"
Enabled_14=True
ROMName_14=gpworld
GameName_14=GP World
GameOptions_14=-framefile "R:\ARCADE\Daphne\vldp\gpworld\gpworld.txt"
Enabled_15=True
ROMName_15=mach3
GameName_15=Mach 3
GameOptions_15=-framefile "R:\ARCADE\Daphne\vldp\mach3\mach3.txt"
Enabled_16=True
ROMName_16=roadblaster
GameName_16=Road Blaster
GameOptions_16=-framefile "R:\ARCADE\Daphne\vldp\rb\rb.txt"
Enabled_17=True
ROMName_17=ace
GameName_17=Space Ace
GameOptions_17=-framefile "R:\ARCADE\Daphne\Space Ace HD\ace_hd.txt"
Enabled_18=True
ROMName_18=sdq
GameName_18=Super Don Quix-ote
GameOptions_18=-framefile "R:\ARCADE\Daphne\vldp\sdq\sdq.txt"
Enabled_19=False
ROMName_19=tq
GameName_19=Thayer's Quest
GameOptions_19=-framefile "R:\ARCADE\Daphne\vldp\tq\tq.txt"
Enabled_20=True
ROMName_20=uvt
GameName_20=Us vs Them
GameOptions_20=-framefile "R:\ARCADE\Daphne\vldp\uvt\uvt.txt"
UseGamepad=False
DaphneFlyer=
DaphneCabinet=
DaphneTitle=
DaphneMarquee=
DaphnePanel=
LaunchBefore=
LaunchAfter=
DaphneCustomGameExtenderCustomArtPath=
DaphneBakSNAP=
[dvd]
EnableDVD=False
CODEC=0
DVDFFDSHOW=0
EnableDVDDisk=True
DVDPath=C:\DVD
UseVMR9=True
EnableExternalPlayer=False
Use VMR9=False
CMD=""C:\Program Files (x86)\Corel\DVD9\WinDVD.exe" "[dvd]""
[pictures]
PicturesEnabled=False
paths=C:\GameEx\DEMO\Pictures;C:\Pictures;[mypictures]
UseAlphaBlend=True
SlideDuration=12
[news]
URL_1=http://rss.news.yahoo.com/rss/topstories
URL_2=
URL_3=http://rss.news.yahoo.com/rss/tech
URL_4=http://slashdot.org/index.rss
URL_5=
URL_6=http://www.emulator-zone.com/rss_news.php
URL_7=http://www.spesoft.com/news.xml
URL_8=http://www.gameex.info/forums/index.php?app=core&module=global&section=rss&type=forums&id=1
URL_9=http://www.hulu.com/feed/highest_rated/videos
URL_10=http://www.hulu.com/feed/popular/videos/this_week
URL_11=http://www.hulu.com/feed/recent/movies
URL_12=
URL_13=
URL_14=
URL_15=
URL_16=
URL_17=
URL_18=
URL_19=
URL_20=
URL_21=
URL_22=
URL_23=
URL_24=
URL_25=
URL_26=
URL_27=
URL_28=
URL_29=
URL_30=
URL_31=
URL_32=
URL_33=
URL_34=
URL_35=
URL_36=
[radio]
RadioEnabled=True
Enabled_5=True
Name_5=Kohina - old school game & demo
URL_5=http://acamar.org:8000/listen.pls
Enabled_6=False
Name_6=Bangkok Radio
URL_6=http://64.62.253.55/bangkok64
Enabled_7=True
Name_7=Kohina - Fresh Tracks
URL_7=http://anka.org:8080/fresh.ogg.m3u
Enabled_4=False
Name_4=Delta Uno
URL_4=http://www.deltauno.it/home/delta1.asx
Enabled_1=False
Name_1=
URL_1=
Enabled_2=
Name_2=
URL_2=
Enabled_3=
Name_3=
URL_3=
Enabled_8=
Name_8=
URL_8=
Enabled_9=
Name_9=
URL_9=
Enabled_10=
Name_10=
URL_10=
Enabled_11=
Name_11=
URL_11=
Enabled_12=
Name_12=
URL_12=
Enabled_13=
Name_13=
URL_13=
Enabled_14=
Name_14=
URL_14=
Enabled_15=
Name_15=
URL_15=
Enabled_16=
Name_16=
URL_16=
Enabled_17=
Name_17=
URL_17=
Enabled_18=
Name_18=
URL_18=
Enabled_19=
Name_19=
URL_19=
Enabled_20=
Name_20=
URL_20=
Enabled_21=False
Name_21=Capital Gold
URL_21=mms://ms1.capitalinteractive.co.uk/gold_high
Enabled_22=True
Name_22=Slay Radio
URL_22=
Name_23=XFM
URL_23=http://rope.icgo.fimc.net/staticweb/onair_players/onair_xfm_abacast/player/onair_xfm.asx
Enabled_23=False
Name_24=Radio Woodstock
URL_24=http://nick8.surfernetwork.com/Media/RWST.asx
Enabled_25=True
Name_25=Club 977 Alternative
URL_25=http://www.977alt.com/977alt.asx
Enabled_26=True
Name_26=Radio Paradise
URL_26=http://www.changeip.com/radio/rp_128.asx
Enabled_27=True
Name_27=Hitz Radio
URL_27=http://www.hitzradio.com/hitzradio.asx
Enabled_28=True
Name_28=Club 977
URL_28=http://www.club977.com/club977.asx
Enabled_29=True
Name_29=9412 Rock Station
URL_29=http://www.9412.com/9412.asx
Enabled_30=True
Name_30=Power Hitz
URL_30=http://www.powerhitz.com/powerhitz.asx
Enabled_31=True
Name_31=Radio Wazee
URL_31=http://www.wazee.org/128.asx
Enabled_32=True
Name_32=The Edge Radio
URL_32=http://mfkrboard.com/edgeradio/edge.m3u
Enabled_33=True
Name_33=WFUV 90.7 FM Public Radio
URL_33=http://www.wfuv.org/wfuvlive.asx
Enabled_34=False
Name_34=Pirate Radio
URL_34=http://www.loudcity.net/Portals/0/LCPlayLists/90/123.asx
Enabled_35=True
Name_35=EYE 97
URL_35=http://www.loudcity.net/Portals/0/LCPlayLists/157/eye97.asx
Enabled_36=True
Name_36=Hit Music Station
URL_36=http://www.hitmusicstation.net/ecoute_haut_debit.m3u
Name_37=Radio IO 80's
URL_37=http://radioio.sc.llnwd.net:8240
Enabled_24=
Enabled_37=False
Enabled_80=True
Url_80=FAVREMOVE
Enabled_81=True
Url_81=FAVREMOVE
Enabled_82=True
Url_82=FAVREMOVE
Enabled_83=True
Url_83=FAVREMOVE
enabled_84=True
name_84=radioio.com : 80s New Wave
url_84=http://www.shoutcast.com/sbin/shoutcast-playlist.pls?rn=1269943&file=filename.pls
Enabled_85=
Name_85=
Url_85=
Enabled_38=True
Name_38=C64.COM's SID Stream
URL_38=http://www.c64.com/sid.m3u
[htmlapplications]
enabled_1=False
URL_1=http://10foot.cbuenger.com/mceWeather/index.php?start=1〈=2
Name_1=Weather
Logo_1=Weather
MouseEmu_1=False
Enabled_2=True
URL_2=http://gameex.net
Name_2=GameEx homepage
Logo_2=
MouseEmu_2=False
Enabled_3=False
URL_3=http://10foot.cbuenger.com/mceWeather/index.php?start=1〈=2
Name_3=Weather
Logo_3=Weather
MouseEmu_3=True
Enabled_4=False
URL_4=
Name_4=
Logo_4=
MouseEmu_4=True
Enabled_5=False
URL_5=
Name_5=
Logo_5=
MouseEmu_5=True
Enabled_6=False
URL_6=
Name_6=
Logo_6=
MouseEmu_6=True
UseHTMLApps=True
Hide_2=False
Hide_3=
Hide_4=True
Hide_5=
[externalapplications]
Enabled_99=True
Name_99=Configuration
Path_99=[apppath]
CMD_99=GameExConfig.exe
Snap_99=GameExText
ShowDesktop_99=True
MapKeys_99=False
WaitBeforeKeys_99=
SendKeys_99=
Enabled_2=False
Name_2=Notepad
Path_2=c:\windows
CMD_2=notepad.exe
Snap_2=GameExText
ShowDesktop_2=True
MapKeys_2=True
WaitBeforeKeys_2=
SendKeys_2=
Enabled_3=False
Name_3=Mad Dog McCree
Path_3=G:\Mad_Dog_mcCree
CMD_3=G:\Mad_Dog_mcCree\mdm.exe
Snap_3=GameExText
ShowDesktop_3=True
MapKeys_3=True
WaitBeforeKeys_3=4000
SendKeys_3=F
Enabled_1=False
name_1=Close And Restart GameEx
path_1=G:\-DATA-\-MY PROJECTS-\GameEx - VB.net\bin
cmd_1=CloseAndRestartGameEx.bat
snap_1=
showdesktop_1=True
mapkeys_1=True
WaitBeforeKeys_1=d
SendKeys_1=
Enabled_4=False
name_4=
path_4=
cmd_4=
snap_4=
showdesktop_4=True
mapkeys_4=True
WaitBeforeKeys_4=
SendKeys_4=
Enabled_5=False
name_5=
path_5=
cmd_5=
snap_5=
showdesktop_5=True
mapkeys_5=True
WaitBeforeKeys_5=
SendKeys_5=
Enabled_6=False
name_6=
path_6=
cmd_6=
snap_6=
showdesktop_6=True
mapkeys_6=True
WaitBeforeKeys_6=
SendKeys_6=
Enabled_7=False
name_7=
path_7=
cmd_7=
snap_7=
showdesktop_7=True
mapkeys_7=True
WaitBeforeKeys_7=
SendKeys_7=
Enabled_8=False
name_8=
path_8=
cmd_8=
snap_8=
showdesktop_8=True
mapkeys_8=True
WaitBeforeKeys_8=
SendKeys_8=
Enabled_9=False
name_9=
path_9=
cmd_9=
snap_9=
showdesktop_9=True
mapkeys_9=True
WaitBeforeKeys_9=
SendKeys_9=
Enabled_10=False
name_10=
path_10=
cmd_10=
snap_10=
showdesktop_10=True
mapkeys_10=True
WaitBeforeKeys_10=
SendKeys_10=
Enabled_11=False
name_11=
path_11=
cmd_11=
snap_11=
showdesktop_11=True
mapkeys_11=True
WaitBeforeKeys_11=
SendKeys_11=
Enabled_12=False
name_12=
path_12=
cmd_12=
snap_12=
showdesktop_12=True
mapkeys_12=True
WaitBeforeKeys_12=
SendKeys_12=
Enabled_13=False
name_13=
path_13=
cmd_13=
snap_13=
showdesktop_13=True
mapkeys_13=True
WaitBeforeKeys_13=
SendKeys_13=
Enabled_14=False
name_14=
path_14=
cmd_14=
snap_14=
showdesktop_14=True
mapkeys_14=True
WaitBeforeKeys_14=
SendKeys_14=
Enabled_15=False
name_15=
path_15=
cmd_15=
snap_15=
showdesktop_15=True
mapkeys_15=True
WaitBeforeKeys_15=
SendKeys_15=
Enabled_16=False
name_16=
path_16=
cmd_16=
snap_16=
showdesktop_16=True
mapkeys_16=True
WaitBeforeKeys_16=
SendKeys_16=
Enabled_17=
name_17=
path_17=
cmd_17=
snap_17=
showdesktop_17=
mapkeys_17=
WaitBeforeKeys_17=
SendKeys_17=
Enabled_18=
name_18=
path_18=
cmd_18=
snap_18=
showdesktop_18=
mapkeys_18=
WaitBeforeKeys_18=
SendKeys_18=
Enabled_19=
name_19=
path_19=
cmd_19=
snap_19=
showdesktop_19=
mapkeys_19=
WaitBeforeKeys_19=
SendKeys_19=
Enabled_20=
name_20=
path_20=
cmd_20=
snap_20=
showdesktop_20=
mapkeys_20=
WaitBeforeKeys_20=
SendKeys_20=
Enabled_21=
name_21=
path_21=
cmd_21=
snap_21=
showdesktop_21=
mapkeys_21=
WaitBeforeKeys_21=
SendKeys_21=
Enabled_22=
name_22=
path_22=
cmd_22=
snap_22=
showdesktop_22=
mapkeys_22=
WaitBeforeKeys_22=
SendKeys_22=
Enabled_24=
name_24=
path_24=
cmd_24=
snap_24=
showdesktop_24=
mapkeys_24=
WaitBeforeKeys_24=
SendKeys_24=
Enabled_25=
name_25=
path_25=
cmd_25=
snap_25=
showdesktop_25=
mapkeys_25=
WaitBeforeKeys_25=
SendKeys_25=
EmulateMouse_1=-1
EmulateMouse_2=-1
EmulateMouse_3=3
EmulateMouse_4=
EmulateMouse_5=
EmulateMouse_6=
EmulateMouse_7=
EmulateMouse_8=
EmulateMouse_9=
EmulateMouse_10=
EmulateMouse_11=
EmulateMouse_12=
EmulateMouse_13=
EmulateMouse_14=
EmulateMouse_15=
EmulateMouse_16=
EmulateMouse_17=
EmulateMouse_18=
EmulateMouse_19=
EmulateMouse_20=
EmulateMouse_21=
EmulateMouse_22=
EmulateMouse_24=
EmulateMouse_25=-1
LaunchBefore_16=
LaunchAfter_16=
AlsoLaunch_16=
LaunchBefore_17=
LaunchAfter_17=
LaunchBefore_1=
HelpText_1=
[text]
Titles=Titles
Movies=Movies
Actors=Actors
Year=Year
Directors=Directors
Genres=Genres
Collections=Collections
Ratings=Ratings
Cast=Cast
Director=Director
Collection=Collection
mameCHDlist=CHD
mameCHDstart=MAME CHD Games
steamlist=Steam
steamstart=Steam Games
uplaylist=Uplay
uplaystart=Uplay Games
originlist=Origin
originstart=Origin Games
banner=Banner
Downloading=Downloading
Seeking=Seeking
Download=Download
PlayBluRay=Play Blu Ray
GetMetaData=Get MetaData
Touch_Help_1=Control is located at bottom of screen.
Touch_Help_2=Continuously tap bottom right for credits and top right to start.
Touch_Help_3=Controls are located bottom and middle of screen.
Touch_Help_4=Control is located at bottom of screen.
GameExArcadeStart=Arcade
GameExArcadeList=Arcade
RipDVD=Rip DVD
SearchMusic=Search Music
Dialog_RippingCD=Ripping CD
Dialog_PleaseWait=Please Wait
Dialog_ScanningFolders=Scanning Folders
Dialog_ScanningFiles=Scanning Files
Dialog_LoadingDatabases=Loading Databases
Dialog_LoadingSettings=Loading Settings
Status_ListUpdated=List Updated
Status_FavRemoved=Removed from favorites
Status_FavAdded=Added to favorites
Status_ItemRemoved=Item removed
Status_NextTrack=Next track
Status_PreviousTrack=Previous track
Status_Pause=Pause
Status_play=Play
Status_AddedToQ=Added to queue
Status_NetPlayReq=Requested NetPlay
Status_NetPlayCan=Cancelled NetPlay
YouTube=YouTube
News=News
SearchYouTube=Search YouTube
RequestNetPlay=Request NetPlay
CancelNetPlay=Cancel NetPlay Request
MAMENetPlayStart=MAME NetPlay
NetPlayList=NetPlay
Accept=Accept
Now=Now
Next=Next
GameMusic=Game Music
TVAdvert=TV Advert
Commands=Commands
RecordVideo=Record Video
ResumeGame=Resume Game
ExitGame=Exit Game
InGame=In Game
Stopped=Stopped
Play=Play
ResumeDVD=Resume DVD
NoItems=- NO ITEMS FOUND -
Hibernate=Hibernate
MenuMore=More
AllGamesStart=All Games
AllGamesList=All Games
NotAvailable=Not Available
HiScore=High Score
GetLyrics=Get Lyrics
OtherSystems=Other Systems
OpenMedia=Open Media
Biography=Biography
MenuView=Change View
MenuBack=Back
MenuExit=Exit
MenuHome=Home
LastPlayedList=Last Played
LastPlayedStart=Last Played
SEARCHTITLE=Enter criteria then select menu
SEARCHTITLE2=Press select to release cursor
SearchList=Search
SearchStart=Search
SearchMedia=Search Media
SearchJukebox=Search Jukebox
Items=Items
MediaPlayerStart=Library
MediaPlayerList=Library
NoMediaFound=- NO MEDIA FOUND -
eBookViewerStart=eBooks
eBookViewerList=eBooks
Artwork=Artwork
PCB=PCB
Statistics=Statistics
InsertCD=Insert CD:
SearchGames=Search Games
GameManual=Manual
PlayStation=Playstation
mame2simlist=2 Players
mame2simstart=2 Player Simultaneous
mame4simlist=4 Players
mame4simstart=4 Player Simultaneous
MCEEXPORT=Export To MCE
StartScreenSaver=Start Screensaver
Visualize=Visualize
SelectVisualize=Select Visualization
About1=Windows Emulator Front End and HTPC
About2=Written By:
About3=For Latest Version, please visit:
byalbum=By Album
byartistalbum=By Artist/Album
byartist=By Artist
bycat=By Category
bygenre=By Genre
bymanu=By Manufacturer
bysys=By System
byname=By Name
bytitle=By Title
byyear=By Year
Selectplaylist=Play list / More
createsnaps=Create Snaps
CreateSnaps1A=You are about to create snap shots or videos for every game in the [EMULATOR] Games List. This option can be removed from GameEx, by enabling the Hide Create Snaps option in the configuration.
CreateSnaps2=You should be aware this is a lengthy process
CreateSnaps3=With your current settings it is estimated that it will take at least:
CreateSnaps4=[MINUTES] Minutes to complete this process if you use a 20 second pause between snaps.
CreateSnaps5=You should also be warned that the SNAP shots will be saved in the SNAP Path defined for this emulator
CreateSnaps6=This process is not recommended on Windows 98
CreateSnaps7=To exit this process once run HOLD down ESCAPE.
CreateSnaps8=Do you want to proceed?
Exit=Exit GameEx
HTMLPleaseWait=Please Wait
IsUpdatingList=GameEx is updating the MAME game list:
jukelist=Jukebox
jukestart=Jukebox
Karaokelist=Karaoke
Karaokestart=Karaoke
StartKaraoke=Start Karaoke Player
LaaunchingGame=Launching:
laserlist=Laserdisc
laserstart=Laserdisc Games
logoff=Log Off
favlist=Favorites
favstart=Favorites
mamealllist=MAME Games
mameallstart=All MAME Games
mamecpslist=CPS Games
mamecpsstart=CPS Games
mameAtarilist=Atari Games
mameAtaristart=Atari Games
mameGunlist=Lightgun
mameGunstart=Lightgun Games
mameTrackballlist=Trackball
mameTrackballstart=Trackball Games
mameSpinnerlist=Spinner
mameSpinnerstart=Spinner Games
mameModel2list=Model 2
mameModel2start=Sega Model 2 Games
mameGoldenlist=Golden Era
mameGoldenstart=Golden Era Of Arcade
mameneolist=Neo-Geo
mameNEostart=Neo-Geo Games
mamemultilist=MAME Multiplay
mamemultistart=MAME Multiplayer Games
mamevectorlist=MAME Vector
mamevectorstart=MAME Vector Games
Of=of
shutdown=Turn Off System
standby=Stand By System
Restart=Restart System
Start=Start..
updatelist=Update List
UpdatingList=Updating Game List:
UpdatingPleaseWait=Please Wait......
videoslist=Videos
videostart=Videos
LaunchingGame=Launching Game:
PlayThisGame=Play This Game
Recommended=Recommended Games:
Series=Games in Series:
Title=Title
Flyer=Flyer
Cabinet=Cabinet
Cabinet3d=3D Cabinet
Panel=Panel
Box=Box
Cartridge=Cartridge
Marquee=Marquee
FavoritesAdd=Add To Favorites
FavoritesRemove=Remove From Favorites
NoVideosFound=- NO VIDEOS FOUND -
NoPicturesFound=- NO PICTURES FOUND -
NoMusicFound=- NO MUSIC FOUND -
NoArtistsFound=- NO ARTISTS FOUND -
NoAlbumsFound=- NO ALBUMS FOUND -
NoGenresFound=- NO GENRES FOUND -
NoGamesFound=- NO GAMES FOUND -
NoStationsFound=- NO STATIONS FOUND -
NoNewsFound=- NO NEWS FOUND -
CannotCreateSnaps1=Cannot Create Snaps
CannotCreateSnaps2=Emulator '[EMULATOR]' Does not have a valid Snap path, so Snaps cannot be created. Setup a valid snap path in the configuration and try again.
ViewControls=View Controls
Instructions=Instructions
ViewControlsKey=Press '[KEY]' to view in game.
AllMusic=All Music
ClearCurrentPlaylist=Clear Current Playlist
ShufflePlaylist=Shuffle Current Playlist
PlayLastGame=Last MAME Game
ViewSlideShow=View Slide Show
Pictures=Pictures
Radio=Radio
PlayDVD=Play DVD
PlayCD=Play CD
DVDonDiskStart=DVDs
DVDonDiskList=DVDs
Demo=Demo:
Playing=Playing:
MAMEOriginal=MAME Original Games
MAMEOriginallist=Originals
MAMEAdult=MAME Adult Games
MAMEAdultlist=Adult
ClearAndQueueAll=Clear and Queue All
AddAndQueueAll=Add all to Queue
RandomGame=Play Random Game
StartMAME=MAME
StartApps=More Games & Programs
StartEMU=Emulated Games
StartControl=Exit/Shutdown
StartMedia=Multimedia
ListMAME=MAME
ListApps=Games & Apps
ListEMU=Games
ListControl=Exit
ListMedia=Media
TimesPlayed=Times Played
LastPlayed=Last Played
DeleteFavs=Delete Favorites
DeleteMost=Delete Most Played
Chapter=Chapter
Aspect=Aspect
Aspect0=Original Aspect - Not Zoomed
Aspect4=Widescreen on 4:3 - Stretched
Aspect5=Fill Screen
Aspect3a=Widescreen to 4:3 - Zoomed
Aspect3b=Letterbox to Widescreen - Zoomed
Aspect2=Original Aspect - Zoomed
Aspect1a=Widescreen to 4:3 - Shrunk
Aspect1b=4:3 to Widescreen - Stretched
Paused=Paused
PlayVideo=Play Video
ResumeVideo=Resume Video
RestartVideo=Restart Video
VideoQueue=Play All
QueueAllRandom=Play Randomly
More=More..
MostPlayed=Most Played
MostPlayedList=Most Played
VariousArtists=Various Artists
ConfirmDialog1=Select To Confirm.
ConfirmDialog2=Back To Cancel.
RemoveGame=Remove Game?
LocalDisk=Local Disk
SystemDisk=System Disk
CDDVD=CD/DVD Drive
NetworkDrive=Network Drive
RamDisk=Ram Disk
FloppyDisk=Floppy Disk
RemovableDisk=Removable Disk
UpdateGameList=Update List?
VideoQueueAll=
playstationstart=Playstation
themepickerlist=Themes
themepickerstart=Theme Picker
playstationlist=Playstation
mameVertList=Vertical
mameVertStart=MAME Vertical Games
mameHorizlist=Horizontal
mameHorizstart=MAME Horizontal Games
mamenotplayedlist=Not Played
mamenotplayedstart=MAME Not Played
mamemawslist=Live - MAWS
mameMAWSstart=Live - MAWS Hall Of Fame
mameGameExlist=Live - GameEx
mameGamEexstart=Live - GameEx Favorites
ripcd=Rip CD
ripthiscd=Rip This CD Now
cantrip=- No CD, Invalid CD, or no CDDB data -
ViewPlaylist=View Playlist
KaraokAllSongs=All Songs
KaraokaMode1Click=Instant Play Mode
KaraokaModeQueue=Queue Mode
KaraokePlaylist=View/Edit Playlist
KaraokeStartMenu=Start Karaoke
mammodel2list=
CreateSnaps1=You are about to create snap shots for every game in the [EMULATOR] Games List.
NoeBooksFound=- NO EBOOKS FOUND -
QueueAll=Queue All
TV=TV
NetFlix=NetFlix
SearchNetFlix=Search NetFlix
[favorites]
ReplaceDash=True
ReplaceUnder=True
Capitals=True
RemoveBrackets=True
[dvrms]
DVRFFDSHOW=0
CODEC=
[atractmodenewgametimer]
When in attract mode start a new random game or video each time this value is reached.=2
[attractvideospath]
The folder your videos are located.=L:\GameAds
[gameextender]
RemoteGameExLocation=\\workstation1\g$\-DATA-\-MY PROJECTS-\GameEx - VB.net\bin
Enabled=False
Windowed=False
RemoteExtenderLocation=G:\-DATA-\-MY PROJECTS-\GameEx - VB.net\bin
IPADDRESS=127.0.0.1
Port=8383
RefreshRate=20
SysUserName=paul-tower
Username=User33549
ComputerName=TOWER
Publish=False
UserInfo=
GameExtenderCustomImage=False
GameExtenderImageNotFound=
[gameextenderviewer]
Server=90.0.0.13
PORT=8383
RefreshRate=7
StartWithGameEx=False
ExitWithGameEx=False
Windowed=False
[karaoke]
Enabled=False
Path=C:\Karaoke
mode=False
[arcadesoundplugin]
Volume=8
[emulator_]
SelectionMusicFolder=C:\Music
[ebook]
Enabled=False
Paths=C:\eBooks
Quality=0
fittopage=False
[mediaplayer]
AudioMode=0
[cpwizard]
CPWizardEnable=False
CPWizardPath=
CPWizardStarted=True
CPWizardStartup=False
UseWMPWMV=
CMD=
[advkeyboard]
Forward=60
Rewind=61
PageUp=62
PageDown=63
VolumeDown=64
VolumeUp=65
Stop=66
Play=67
[cursorhider]
DoNotHide=
DoNotHideInGameEX=False
[defaultpaths]
EmuPath1=C:\Emulators
AssetPath1=C:\Assets
RomPath1=C:\Roms
Enabled=False
[gamebase]
Enabled=False
Path=
MapBack=False
ShowDesktop=True
[dvdrip]
Format=MP4
DVDRIPFOLDER=C:\DVD RIPS
Profile=Normal
CUSTOMCMD=
[gameexarcade]
Enabled=False
[touchscreen]
Touchscreen_Enabled=2
Touchscreen_HidePointer=True
TouchScreen_ShowHelpScreens=True
TouchScreen_SingleClick=True
TouchScreen_OnlyCompatibleGames=True
TouchScreen_CheckForExit=True
TouchScreen_SendCredit=True
TouchScreen_ShowMouseAnimations=True
[laststatus]
specialfilter=
oldspecialfilter=
curemulator=0
listtype=0
curbak=Start
maxgames=11
gamename=
[steam]
LaunchBefore=
LaunchAfter=
[mappeddrives_1]
UNCPATH=\\Nasusa\roms_mint
Drive=R
[uplay]
UPlayEnabled=False
LaunchBefore=
[origin]
OriginEnabled=False
[movies]
Enabled=False
[login]
Enabled=False
[netflix]
Enabled=False
[iNTERNAL]
currentstation=
VGenre=---
OPTIMIZED=0
version=14.02
timesruncount=19
mameexe=mamep.exe
mamefilemodified=6/13/2010 8:01:22 AM
mamefilesize=40694272
mamepromptupdate=False
mameis32bit=True
bezelversion=2
mameversion=0.138
startpagethumbscount=19
emu_1lastfolderwrite=3/4/2015 11:56:19 PM
emu_1lastromfilter=*.avi
emu_1_dbcachemodified=12/16/2014 5:11:34 PM
emu_1_lastnumgames=4
emu_1_dbcachelastname=[Console] Atari 5200
emu_1_dbcacheinicreated51=True
emu_2lastfolderwrite=3/4/2015 11:56:19 PM
emu_2lastromfilter=*.avi
emu_2_dbcachemodified=12/16/2014 5:12:24 PM
emu_2_lastnumgames=4
emu_2_dbcachelastname=[Console] Nintendo SNES
emu_2_dbcacheinicreated51=True
emu_3lastfolderwrite=3/4/2015 11:56:19 PM
emu_3lastromfilter=*.avi
emu_3_dbcachemodified=12/16/2014 5:12:04 PM
emu_3_lastnumgames=4
emu_3_dbcachelastname=[Console] Nintendo N64
emu_3_dbcacheinicreated51=True
emu_4lastfolderwrite=3/1/2015 1:22:48 AM
emu_4lastromfilter=*.*
mamevideolists_reset18_startmame=False
mamevideolists_lastmodified_startmame=3/6/2015 1:57:10 PM
mamevideolists_lastmodifiedlist_startmame=3/6/2015 2:06:44 PM
mamevideolists_list_startmame=
lastglaunchlist=0
glaunchlistselected_0=1
glaunchlisttop_0=1
viewalbumtype=0
windowed=False
selectedgame=1
gamelisttop=1
catfilter=
manufilter=
yearfilter=
listtype=0
emulator=0
yearlisttop=1
catlisttop=1
namelisttop=1
manulisttop=1
yearselectedgame=1
catselectedgame=1
manuselectedgame=1
nameselectedgame=1
romname=deerhuntc
romname2=lordgun
specialfilter=
currentstationurl=
mamevideolists_reset18_most=False
mamevideolists_lastmodified_most=3/5/2015 12:39:50 AM
mamevideolists_lastmodifiedlist_most=3/5/2015 9:28:31 PM
mamevideolists_list_most=
mamevideolists_reset18_mameall=False
mamevideolists_lastmodified_mameall=3/6/2015 1:57:10 PM
mamevideolists_lastmodifiedlist_mameall=3/6/2015 2:06:44 PM
mamevideolists_list_mameall=
mamevideolists_reset18_original=False
mamevideolists_lastmodified_original=3/5/2015 12:39:50 AM
mamevideolists_lastmodifiedlist_original=3/6/2015 2:03:00 PM
mamevideolists_list_original=
mamevideolists_reset18_notplayed=False
mamevideolists_lastmodified_notplayed=3/5/2015 12:39:50 AM
mamevideolists_lastmodifiedlist_notplayed=3/6/2015 2:03:00 PM
mamevideolists_list_notplayed=
mamevideolists_reset18_golden=False
mamevideolists_lastmodified_golden=3/5/2015 12:39:50 AM
mamevideolists_lastmodifiedlist_golden=3/6/2015 2:03:00 PM
mamevideolists_list_golden=
emu_1_romfilter=*.avi
emu_1_rompath=C:\GameEx\DEMO\5200\video
emu_1_manualpath=C:\GameEx\DEMO\5200\manual
emu_1_workingpath=C:\GameEx\DEMO
emu_1_removebrackets=True
emu_1_showdesktop=False
emu_1_command=demo.exe
Edited by tthurman
compressed text
log:
14:15:27.4 3/6/2015: Opening Configuration File
14:15:27.4 3/6/2015: GameEx: Version 14.02: Starting Log
14:15:27.5 3/6/2015: Windows 8.1 Pro 64-bit
14:15:27.5 3/6/2015: Aero running
14:15:27.5 3/6/2015: Tablet PC detected
14:15:27.5 3/6/2015: Initializing Vista/Windows 7 volume control
14:15:27.5 3/6/2015: Getting CPU and RAM info
14:15:27.5 3/6/2015: AMD FX-6300 Six-Core Processor, 16348MB
14:15:27.5 3/6/2015: 3.52Ghz - 6 Cores or CPU's
14:15:27.5 3/6/2015: Running Randomize()
14:15:27.5 3/6/2015: Loading PlugIns
14:15:27.5 3/6/2015: Checking for applications to Launch On Startup
14:15:27.5 3/6/2015: Setting default net connection limit to 15
14:15:27.5 3/6/2015: Running Misc startup tasks
14:15:27.5 3/6/2015: Setting Menu types
14:15:27.5 3/6/2015: Getting Configuration Values
14:15:27.5 3/6/2015: Touchscreen support enabled
14:15:27.5 3/6/2015: Using Theme: Default - Media Center
14:15:27.5 3/6/2015: Checking for alternate Image Directory for Theme: Default - Media Center
14:15:27.5 3/6/2015: Using Images from theme: Default - Media Center V1\MEDIA\
14:15:27.5 3/6/2015: Launching HideOS.exe
14:15:27.5 3/6/2015: Initialising Video/MNG DLL's
14:15:27.5 3/6/2015: GameEx will check for media insertion (may affect performance)
14:15:27.5 3/6/2015: Hiding Taskbar
14:15:27.6 3/6/2015: Is Media Center running?
14:15:27.6 3/6/2015: Checking/Creating LCD Registry values
14:15:27.6 3/6/2015: Check Media Center Exit/Start Mode
14:15:27.6 3/6/2015: Media Center Mode 2
14:15:27.6 3/6/2015: Video previews on. Warning: Only recommended on modern systems
14:15:27.6 3/6/2015: Snap Delay set to: 4
14:15:27.6 3/6/2015: Get other settings
14:15:27.6 3/6/2015: Desktop set to Hide ICONS and set Background to Black
14:15:27.6 3/6/2015: Set: Find emulator artwork on best match basis
14:15:27.6 3/6/2015: Start work for Form
14:15:27.6 3/6/2015: Getting Original Screen Size
14:15:27.6 3/6/2015: Opening Database Connection
14:15:27.7 3/6/2015: Initializing Component
14:15:27.7 3/6/2015: MAME Path is: C:\MAME Plus!
14:15:27.7 3/6/2015: MAME EXE file is: mamep.exe
14:15:27.7 3/6/2015: ROM Path is: C:\MAME Plus!\roms
14:15:27.7 3/6/2015: Catver.ini is located at: C:\GameEx\DATA\catver.ini
14:15:27.7 3/6/2015: controls.ini is located at: C:\GameEx\DATA\controls.ini
14:15:27.8 3/6/2015: History.dat is located at: C:\GameEx\DATA\history.dat
14:15:27.8 3/6/2015: nplayers.ini is located at: C:\GameEx\DATA\nplayers.ini
14:15:27.8 3/6/2015: command.dat is located at: C:\GameEx\DATA\command.dat
14:15:27.8 3/6/2015: MAMEinfo.dat is located at: C:\GameEx\DATA\mameinfo.dat
14:15:27.8 3/6/2015: Loading Controls.ini map file
14:15:27.8 3/6/2015: Snap Path is: C:\MameUI64\snap
14:15:27.8 3/6/2015: Database Snap Path: Not Found
14:15:27.8 3/6/2015: Background Snap Path: Not Found
14:15:27.8 3/6/2015: AVI Snap Path: Not Found
14:15:27.8 3/6/2015: Flyer Path is: C:\MameUI64\flyers
14:15:27.8 3/6/2015: Cabinet Path is: C:\MameUI64\cabinets
14:15:27.8 3/6/2015: Cabinet 3D Path: Not Found
14:15:27.8 3/6/2015: Title Path is: C:\MameUI64\titles
14:15:27.8 3/6/2015: PCB Path: Not Found
14:15:27.8 3/6/2015: Artwork Preview Path: Not Found
14:15:27.8 3/6/2015: Panel Path is: C:\MameUI64\cpanel
14:15:27.8 3/6/2015: Manual Path: Not Found
14:15:27.8 3/6/2015: Icon Path is: C:\MameUI64\icons
14:15:27.9 3/6/2015: Marquee Path is: C:\MameUI64\marquees
14:15:27.9 3/6/2015: Applying Language/Text
14:15:27.9 3/6/2015: Text/Language: English
14:15:27.9 3/6/2015: Loading Language/Text
14:15:27.9 3/6/2015: Loading Custom Emulators
14:15:27.9 3/6/2015: Using Version 3 Themes Animations
14:15:27.9 3/6/2015: Retrieving resolution setting
14:15:27.9 3/6/2015: Using General Font: Trebuchet MS
14:15:27.9 3/6/2015: Using Title Font: Trebuchet MS
14:15:27.9 3/6/2015: GameEx will try to reduce CPU usage
14:15:28.0 3/6/2015: Initialising Direct3D
14:15:28.0 3/6/2015: Applying GameEx is Loading Image
14:15:28.0 3/6/2015: Setting Resolution to 1920x1080 32 bit color
14:15:28.1 3/6/2015: Creating Surfaces
14:15:28.2 3/6/2015: Creating Primary Surface - Full Screen Mode
14:15:28.2 3/6/2015: Creating Back Buffer
14:15:28.2 3/6/2015: Loading graphic Surfaces
14:15:28.3 3/6/2015: Display is running at: 1920x1080 32bit color, 60hz
14:15:28.3 3/6/2015: Adapter: NVIDIA GeForce GTX 660
14:15:28.3 3/6/2015: Max texture size: 16384x16384
14:15:28.3 3/6/2015: Available texture memory: -82MB
14:15:28.3 3/6/2015: Initialising Bass Audio Library
14:15:28.3 3/6/2015: Creating Surfaces Misc and Dialogs
14:15:28.4 3/6/2015: Creating Surfaces Volume
14:15:28.4 3/6/2015: Creating Surfaces Arrows
14:15:28.4 3/6/2015: Creating Surfaces GameEXlogo Text
14:15:28.4 3/6/2015: Creating Surfaces Toolbar
14:15:28.4 3/6/2015: Creating Surfaces Toolbar Controls
14:15:28.4 3/6/2015: Creating Surfaces Backgrounds
14:15:28.5 3/6/2015: Creating Surfaces GameEx Logo
14:15:28.5 3/6/2015: Creating Surface Unselected
14:15:28.5 3/6/2015: Creating Surfaces Snaps
14:15:28.5 3/6/2015: Creating Surfaces Menu and List Bars
14:15:28.7 3/6/2015: Creating Fonts
14:15:28.7 3/6/2015: Creating Game Font
14:15:28.8 3/6/2015: Creating Game Font Faded
14:15:28.8 3/6/2015: Creating Title Font
14:15:28.8 3/6/2015: Restoring Title Font From Cache
14:15:28.9 3/6/2015: Creating Font Black
14:15:28.9 3/6/2015: Creating Font Black Small
14:15:29.0 3/6/2015: Fonts Created Succesfully
14:15:29.3 3/6/2015: Attempting to load game list
14:15:29.3 3/6/2015: MAME CMD options: -nowindow -joy -skip_gameinfo
14:15:29.3 3/6/2015: Initialising DirectInput for Gamepad support
14:15:29.6 3/6/2015: Unable to create a joystick device
14:15:29.6 3/6/2015: Loading Start Page
14:15:29.6 3/6/2015: Initializing MCE Remote
14:15:29.6 3/6/2015: Playing intro sound file
14:15:29.7 3/6/2015: Initialization OK! Starting GameEx!
14:15:29.7 3/6/2015: Testing Main Loop Once: Processing Frame
14:15:29.9 3/6/2015: Testing Main Loop Once: Main Loop ran successfully
14:15:33.4 3/6/2015: Checking if Steam enabled
14:15:33.4 3/6/2015: Steam is installed correctly
14:15:33.4 3/6/2015: Found Steam Base Install Folder: f:/steam
14:15:33.7 3/6/2015: Found Steam Game: Terraria. AppID=105600. Location:F:\Steam\steamapps\common\Terraria
14:15:33.7 3/6/2015: Found Steam Game: Alan Wake. AppID=108710. Location:F:\Steam\steamapps\common\Alan Wake
14:15:33.7 3/6/2015: Found Steam Game: L.A. Noire. AppID=110800. Location:F:\Steam\steamapps\common\L.A.Noire
14:15:33.7 3/6/2015: Directory does not exist: f:\steam\steamapps\duloz\half-life blue shift
14:15:33.7 3/6/2015: Found Steam Game: Sid Meier's Civilization IV: Colonization. AppID=16810. Location:F:\Steam\steamapps\common\Civilization IV Colonization
14:15:33.7 3/6/2015: Directory does not exist: f:\steam\steamapps\duloz\team fortress classic
14:15:33.7 3/6/2015: Found Steam Game: Batman: Arkham City GOTY. AppID=200260. Location:F:\Steam\steamapps\common\Batman Arkham City GOTY
14:15:33.7 3/6/2015: Found Steam Game: Deus Ex: Human Revolution - The Missing Link. AppID=201280. Location:f:\steam\steamapps\common\dxhrml
14:15:33.7 3/6/2015: Found Steam Game: Wolfenstein: The New Order. AppID=201810. Location:F:\Steam\steamapps\common\Wolfenstein.The.New.Order
14:15:33.7 3/6/2015: Found Steam Game: Alan Wake's American Nightmare. AppID=202750. Location:F:\Steam\steamapps\common\alan wakes american nightmare
14:15:33.7 3/6/2015: Found Steam Game: Tomb Raider. AppID=203160. Location:f:\steam\steamapps\common\Tomb Raider
14:15:33.7 3/6/2015: Found Steam Game: Red Faction: Guerrilla . AppID=20500. Location:F:\Steam\steamapps\common\Red Faction Guerrilla
14:15:33.8 3/6/2015: Found Steam Game: Rocksmith. AppID=205190. Location:F:\Steam\steamapps\common\Rocksmith
14:15:33.8 3/6/2015: Found Steam Game: Red Faction. AppID=20530. Location:F:\Steam\steamapps\common\Red Faction
14:15:33.9 3/6/2015: Found Steam Game: Saints Row IV. AppID=206420. Location:F:\Steam\steamapps\common\Saints Row IV
14:15:33.9 3/6/2015: Found Steam Game: Endless Space. AppID=208140. Location:F:\Steam\steamapps\common\Endless Space
14:15:33.9 3/6/2015: Found Steam Game: Deadlight. AppID=211400. Location:F:\Steam\steamapps\common\Deadlight
14:15:33.9 3/6/2015: Found Steam Game: Dark Souls: Prepare to Die Edition. AppID=211420. Location:F:\Steam\steamapps\common\Dark Souls Prepare to Die Edition
14:15:33.9 3/6/2015: Found Steam Game: FTL: Faster Than Light. AppID=212680. Location:F:\Steam\steamapps\common\FTL Faster Than Light
14:15:33.9 3/6/2015: Found Steam Game: Dream Pinball 3D. AppID=215790. Location:F:\Steam\steamapps\common\dream_pinball_3D
14:15:33.9 3/6/2015: Found Steam Game: Half-Life 2. AppID=220. Location:F:\Steam\steamapps\common\Half-Life 2
14:15:33.9 3/6/2015: Found Steam Game: Kerbal Space Program. AppID=220200. Location:F:\Steam\steamapps\common\Kerbal Space Program
14:15:33.9 3/6/2015: Found Steam Game: Far Cry® 3. AppID=220240. Location:F:\Steam\steamapps\common\Far Cry 3
14:15:33.9 3/6/2015: Invalid or filtered path:
14:15:33.9 3/6/2015: Found Steam Game: Fallout: New Vegas. AppID=22380. Location:f:\steam\steamapps\common\fallout new vegas
14:15:33.9 3/6/2015: Found Steam Game: The Ultimate DOOM. AppID=2280. Location:F:\Steam\steamapps\common\Ultimate Doom
14:15:33.9 3/6/2015: Found Steam Game: ACE COMBAT™ ASSAULT HORIZON Enhanced Edition. AppID=228400. Location:f:\steam\steamapps\common\Ace Combat Assault Horizon
14:15:33.9 3/6/2015: Found Steam Game: Final DOOM. AppID=2290. Location:F:\Steam\steamapps\common\Final Doom
14:15:33.9 3/6/2015: Found Steam Game: DOOM II: Hell on Earth. AppID=2300. Location:F:\Steam\steamapps\common\Doom 2
14:15:33.9 3/6/2015: Found Steam Game: Surgeon Simulator 2013. AppID=233720. Location:F:\Steam\steamapps\common\Surgeon Simulator 2013
14:15:34.0 3/6/2015: Found Steam Game: Poker Night 2. AppID=234710. Location:F:\Steam\steamapps\common\Poker Night 2
14:15:34.0 3/6/2015: Found Steam Game: HeXen: Beyond Heretic. AppID=2360. Location:F:\Steam\steamapps\common\Hexen
14:15:34.0 3/6/2015: Found Steam Game: HeXen: Deathkings of the Dark Citadel. AppID=2370. Location:F:\Steam\steamapps\common\Hexen Deathkings of the Dark Citadel
14:15:34.0 3/6/2015: Found Steam Game: Pinball Arcade. AppID=238260. Location:F:\Steam\steamapps\common\PinballArcade
14:15:34.0 3/6/2015: Found Steam Game: Heretic: Shadow of the Serpent Riders. AppID=2390. Location:F:\Steam\steamapps\common\Heretic Shadow of the Serpent Riders
14:15:34.0 3/6/2015: Found Steam Game: Game Dev Tycoon. AppID=239820. Location:F:\Steam\steamapps\common\Game Dev Tycoon
14:15:34.0 3/6/2015: Found Steam Game: Democracy 3. AppID=245470. Location:F:\Steam\steamapps\common\Democracy 3
14:15:34.0 3/6/2015: Found Steam Game: Nether. AppID=247730. Location:F:\Steam\steamapps\common\Nether
14:15:34.0 3/6/2015: Found Steam Game: Battlefield: Bad Company 2. AppID=24960. Location:f:\steam\steamapps\common\battlefield bad company 2
14:15:34.0 3/6/2015: Invalid or filtered path:
14:15:34.0 3/6/2015: Found Steam Game: Gauntlet™ . AppID=258970. Location:F:\Steam\steamapps\common\Gauntlet
14:15:34.0 3/6/2015: Found Steam Game: Goat Simulator. AppID=265930. Location:F:\Steam\steamapps\common\GoatSimulator
14:15:34.0 3/6/2015: Found Steam Game: Descent. AppID=273570. Location:F:\Steam\steamapps\common\Descent
14:15:34.0 3/6/2015: Found Steam Game: Descent 2. AppID=273580. Location:F:\Steam\steamapps\common\Descent 2
14:15:34.1 3/6/2015: Found Steam Game: Descent 3. AppID=273590. Location:F:\Steam\steamapps\common\Descent 3
14:15:34.1 3/6/2015: Found Steam Game: Half-Life: Source. AppID=280. Location:f:\steam\steamapps\duloz\half-life source
14:15:34.1 3/6/2015: Found Steam Game: Deus Ex: Human Revolution. AppID=28050. Location:f:\steam\steamapps\common\deus ex - human revolution
14:15:34.1 3/6/2015: Found Steam Game: Half-Life 2: Deathmatch. AppID=320. Location:F:\Steam\steamapps\common\Half-Life 2 Deathmatch
14:15:34.1 3/6/2015: Found Steam Game: Star Wars Jedi Knight: Dark Forces II. AppID=32380. Location:F:\Steam\steamapps\common\Star Wars Jedi Knight
14:15:34.1 3/6/2015: Found Steam Game: Star Wars - Jedi Knight: Mysteries of the Sith. AppID=32390. Location:F:\Steam\steamapps\common\Jedi Knight Mysteries of the Sith
14:15:34.1 3/6/2015: Found Steam Game: Star Wars: Dark Forces. AppID=32400. Location:F:\Steam\steamapps\common\Dark Forces
14:15:34.1 3/6/2015: Found Steam Game: Half-Life 2: Lost Coast. AppID=340. Location:F:\Steam\steamapps\common\Half-Life 2
14:15:34.1 3/6/2015: Found Steam Game: Batman: Arkham Asylum GOTY Edition. AppID=35140. Location:F:\Steam\steamapps\common\Batman Arkham Asylum GOTY
14:15:34.1 3/6/2015: Directory does not exist: f:\steam\steamapps\duloz\half-life deathmatch source
14:15:34.1 3/6/2015: Found Steam Game: Half-Life 2: Episode One. AppID=380. Location:F:\Steam\steamapps\common\Half-Life 2
14:15:34.1 3/6/2015: Found Steam Game: Sid Meier's Civilization IV. AppID=3900. Location:F:\Steam\steamapps\common\Sid Meier's Civilization IV
14:15:34.1 3/6/2015: Found Steam Game: Moonbase Alpha. AppID=39000. Location:F:\Steam\steamapps\common\Moon Base Alpha
14:15:34.1 3/6/2015: Found Steam Game: Sid Meier's Civilization IV: Warlords. AppID=3990. Location:F:\Steam\steamapps\common\Sid Meier's Civilization IV Warlords
14:15:34.1 3/6/2015: Directory does not exist: f:\steam\steamapps\duloz\portal
14:15:34.1 3/6/2015: Found Steam Game: Garry's Mod. AppID=4000. Location:f:\steam\steamapps\duloz\garrysmod
14:15:34.1 3/6/2015: Found Steam Game: Half-Life 2: Episode Two. AppID=420. Location:F:\Steam\steamapps\common\Half-Life 2
14:15:34.2 3/6/2015: Found Steam Game: Metro 2033. AppID=43110. Location:F:\Steam\steamapps\common\Metro 2033
14:15:34.2 3/6/2015: Found Steam Game: Metro: Last Light. AppID=43160. Location:F:\Steam\steamapps\common\Metro Last Light
14:15:34.2 3/6/2015: Found Steam Game: Ultra Street Fighter IV. AppID=45760. Location:F:\Steam\steamapps\common\Super Street Fighter IV - Arcade Edition
14:15:34.2 3/6/2015: Found Steam Game: Borderlands 2. AppID=49520. Location:F:\Steam\steamapps\common\Borderlands 2
14:15:34.2 3/6/2015: Directory does not exist: f:\steam\steamapps\duloz\opposing force
14:15:34.2 3/6/2015: Found Steam Game: Amnesia: The Dark Descent. AppID=57300. Location:F:\Steam\steamapps\common\Amnesia The Dark Descent
14:15:34.2 3/6/2015: Found Steam Game: Star Wars Jedi Knight: Jedi Academy. AppID=6020. Location:F:\Steam\steamapps\common\Jedi Academy
14:15:34.2 3/6/2015: Found Steam Game: Star Wars - Jedi Knight II: Jedi Outcast. AppID=6030. Location:F:\Steam\steamapps\common\Jedi Outcast
14:15:34.2 3/6/2015: Found Steam Game: Portal 2. AppID=620. Location:F:\Steam\steamapps\common\Portal 2
14:15:34.2 3/6/2015: Found Steam Game: Sid Meier's Civilization: Beyond Earth. AppID=65980. Location:F:\Steam\steamapps\common\Sid Meier's Civilization Beyond Earth
14:15:34.2 3/6/2015: Found Steam Game: Just Cause. AppID=6880. Location:F:\Steam\steamapps\common\Just Cause
14:15:34.2 3/6/2015: Found Steam Game: Deus Ex: Game of the Year Edition. AppID=6910. Location:F:\Steam\steamapps\common\Deus Ex
14:15:34.3 3/6/2015: Found Steam Game: Deus Ex: Invisible War. AppID=6920. Location:F:\Steam\steamapps\common\Deus Ex Invisible War
14:15:34.3 3/6/2015: Directory does not exist: f:\steam\steamapps\duloz\half-life
14:15:34.3 3/6/2015: Found Steam Game: Universe Sandbox. AppID=72200. Location:F:\Steam\steamapps\common\Universe Sandbox
14:15:34.3 3/6/2015: Found Steam Game: The Elder Scrolls V: Skyrim. AppID=72850. Location:F:\Steam\steamapps\common\Skyrim
14:15:34.3 3/6/2015: Found Steam Game: BioShock. AppID=7670. Location:F:\Steam\steamapps\common\Bioshock
14:15:34.3 3/6/2015: Found Steam Game: Just Cause 2. AppID=8190. Location:f:\steam\steamapps\common\just cause 2
14:15:34.3 3/6/2015: Found Steam Game: Sid Meier's Civilization IV: Beyond the Sword. AppID=8800. Location:F:\Steam\steamapps\common\Sid Meier's Civilization IV Beyond the Sword
14:15:34.3 3/6/2015: Found Steam Game: BioShock 2. AppID=8850. Location:f:\steam\steamapps\common\bioshock 2
14:15:34.3 3/6/2015: Found Steam Game: BioShock Infinite. AppID=8870. Location:F:\Steam\steamapps\common\BioShock Infinite
14:15:34.3 3/6/2015: Found Steam Game: Borderlands. AppID=8980. Location:F:\Steam\steamapps\common\Borderlands
14:15:34.3 3/6/2015: Found Steam Game: HeXen II. AppID=9060. Location:F:\Steam\steamapps\common\Hexen 2
14:15:34.4 3/6/2015: Found Steam Game: Dead Island. AppID=91310. Location:F:\Steam\steamapps\common\Dead Island
14:15:34.4 3/6/2015: Found Steam Game: Master Levels for DOOM II. AppID=9160. Location:F:\Steam\steamapps\common\Master Levels of Doom
14:15:34.4 3/6/2015: Found Steam Game: Commander Keen Complete Pack. AppID=9180. Location:F:\Steam\steamapps\common\Commander Keen
14:15:34.4 3/6/2015: Found Steam games. Steam enabled.
14:15:34.5 3/6/2015: Checking if Origin enabled
14:15:34.5 3/6/2015: Found Origin Game: Battlefield™ Hardline Beta. ContentID=1024943. ProductID=Origin.OFR.50.0000602. Location:C:\Program Files (x86)\Origin Games\BFH Beta 2
14:15:34.5 3/6/2015: Found Origin Game: Theme Hospital™. ContentID=1025169. ProductID=Origin.OFR.50.0000500. Location:C:\Program Files (x86)\Origin Games\Theme Hospital
14:15:34.5 3/6/2015: Found Origin games. Origin Enabled.
14:15:34.5 3/6/2015: Checking if Uplay enabled
14:15:34.5 3/6/2015: Cannot find UPlay executable
14:21:49.1 3/6/2015: Starting Attract Mode
14:21:49.1 3/6/2015: Reading MAME hall of fame
14:21:49.1 3/6/2015: Shutting down display
14:21:53.1 3/6/2015: Warning: Display is running in full screen compatibility mode.
14:21:53.1 3/6/2015: Exception occured running Attract Mode
14:21:53.1 3/6/2015: Error in the application.
14:21:53.1 3/6/2015: at Microsoft.DirectX.Direct3D.Device..ctor(Int32 adapter, DeviceType deviceType, Control renderWindow, CreateFlags behaviorFlags, PresentParameters[] presentationParameters)
14:21:53.1 3/6/2015: at Direct2D.Direct2d.Device.a(Form A_0, Int32 A_1, Int32 A_2, Boolean A_3, Boolean A_4, Boolean A_5, Boolean A_6, Int32 A_7)
14:21:53.1 3/6/2015: at Direct2D.Direct2d.Device..ctor(Form FormHandle, Int32 Width, Int32 Height, Boolean Windowed, Boolean VSync, Boolean Display16Bit, Boolean SecondaryDisplay)
14:21:53.2 3/6/2015: at GameEx.GameEx.MainForm.a(Boolean A_0, Boolean A_1, Boolean A_2, Boolean A_3, Int32 A_4, Int32 A_5, Int32 A_6, Boolean A_7, Boolean A_8)
14:21:53.2 3/6/2015: at GameEx.GameEx.MainForm.a(Boolean A_0, Boolean A_1, Boolean A_2, Boolean A_3, Int32 A_4, Int32 A_5, Int32 A_6, Boolean A_7)
14:21:53.2 3/6/2015: at GameEx.GameEx.MainForm.a(Boolean A_0, Boolean A_1, Boolean A_2, Boolean A_3, Int32 A_4, Int32 A_5, Int32 A_6)
14:21:53.2 3/6/2015: at GameEx.GameEx.MainForm.a(Boolean A_0, Boolean A_1, Boolean A_2, Boolean A_3, Int32 A_4)
14:21:53.2 3/6/2015: at GameEx.GameEx.MainForm.d(Boolean A_0, Boolean A_1)
14:21:53.2 3/6/2015: at GameEx.GameEx.MainForm.x(Boolean A_0)
15:22:35.0 3/6/2015: 21 Consecutive Exceptions Occured
15:22:35.0 3/6/2015: Object reference not set to an instance of an object.
15:22:35.0 3/6/2015: at Direct2D.Direct2d.Device.TestCooperativeLevel()
15:22:35.0 3/6/2015: at GameEx.GameEx.MainForm.d1()
15:22:35.0 3/6/2015: Trying reinitialising the display after sleeping for 4 seconds
15:22:35.0 3/6/2015: Exception count will be dropped to 15
15:24:40.7 3/6/2015: Exiting GameEx!
15:24:40.7 3/6/2015: Disposing all videos
15:24:40.7 3/6/2015: Deleting temporary Karaoke videos
15:24:40.7 3/6/2015: Disposing Image List
15:24:40.7 3/6/2015: Disposing Fonts
15:24:40.7 3/6/2015: Disposing Surfaces
15:24:40.7 3/6/2015: Saving Settings
15:24:40.7 3/6/2015: Shutting down Bass
15:24:40.8 3/6/2015: Closing HideOS.exe
15:24:40.9 3/6/2015: Disposing Plugins
15:24:41.0 3/6/2015: Closing database connection
15:24:41.0 3/6/2015: Checking for applications to Launch On Exit
15:24:41.0 3/6/2015: Bye
Edited by tthurman
compressed text
Hi duloz,
There is one statement in your OP that is causing some concern:
MAME is not like regular emulators where you would just update to the latest .exe and keep on using your existing roms. With MAME your roms MUST match the MAME.exe version exactly to function correctly. You may get lucky by mixing but this is just pot luck and a sure-fire way to mess things up before you even start.
Also your later comment that "I have to turn off "only existing Roms" to get it to identify anything" is setting off alarm bells in my head. It basically confirms that your roms don't match your MAME version at all.
Assuming i'm correct there are two ways to go about this:
1) Find out which romset you have and acquire the matching MAME version (assuming your roms are from the same set)
2) Settle for the MAME.exe you like and "fix/update" your romset to match your MAME version
We can help you with both but i think we need to get these fundamentals confirmed before moving on.
These are all great suggestions from Dazz, and would be highly worth following up on. Just out of curiosity, what is the last game that appears in your current game list?
(I'm wondering if this isn't the same old History.dat issue popping up again)
Ok, I have no idea what changed... Scratching my head on this, but suddenly this morning without making any further changes, it appears that everything is there... I'll do some further testing before I declare this one solved, but going to scratch my head for a while...
Very curious. But good news I suppose! Let us know how it goes for you.
ok. So whatever I managed to do to fix it came from this thread. Since it didn't resolve immediately upon whatever fix I did, I can't give credit where credit is due, but basically here's the gist of it:
Ran update this morning with "Existing Roms Only" turned off, but "Verify Roms" turned on. It Gave me EVERY rom compatable with my MAME version, whether I had it in my roms folder or not... Went back to the configuration tool, turned existing roms only back on, updated the list, and now have the proper roms list...
The only thing that I KNOW is different from when I was having trouble is that I took the PC to my in-laws house to continue working on it, as we drove up to visit for the weekend... Geographic location is not likely to be the fix, but for some reason, things just start work properly in this house... May be it is the "ghost" of my wife's grandfather, they always joke around that he likes to play tricks on them...
More likely, obviously, is that one of the above pieces of advice fixed my issue, but it wasn't immediate, so I can't say which.
So, thanks everyone for your help! Wish I could be more specific.
So just realized one major difference, but not sure if it would have an impact, since MAME is configured to the correct mapping, and It just mimics keyboard inputs, but at home I do have the pc hooked up to an X-arcade dual stick controller, but since it is permanently attached to my arcade cabinet, it is not connected now... any weird and off the deep end chance that that would have an impact?
otherwise, MODs, please mark as resolved.
Good news, hope it holds up!
<EDIT> Didn't see page 2 :blush:
Didn't really have time to look at your config last night after you posted, but just glanced at the filtering settings.
You will get more titles if you chage the following:
VerifyRoms=True (false)
GameFilter=Japan (take Japan out of this list, it filters some good titles, fighting games etc....)
This is how I have mine set, and I have arouind 3600+ titles showing, and have had no noticable problmes with any of them not running correctly. And no, I haven't tried everyone of them :)
Edited by tthurman
