You need to actually have gameex running at the time so that is one thing. You also need to enter your forum credentials in the setup wizard. If you still have trouble you should find log files in C:\gameex\log. Please post them.
Thanks.
Tom.
This is what I have
02:19:14.6 2/25/2015: GameEx Online Thread Started
02:19:14.6 2/25/2015: UserID: brandonjmusic
02:19:14.6 2/25/2015: Logging In
02:19:15.3 2/25/2015: Login Success
02:19:15.3 2/25/2015: Reading Games List
02:19:15.6 2/25/2015: Compressing Games List
02:19:15.7 2/25/2015: Uploading Games List: 313 KiloBytes
02:19:15.7 2/25/2015: This may take a while.
02:19:15.7 2/25/2015: Also processing records on server.
02:19:19.3 2/25/2015: Upload Games List Fail
02:19:19.3 2/25/2015: Exit Thread.
Also mame gets stuck at trying to read listinfo.dat
02:19:09.0 2/25/2015: Opening Configuration File
02:19:09.0 2/25/2015: GameEx: Version 14.02: Starting Log
02:19:09.0 2/25/2015: Windows 8.1 Pro with Media Center 64-bit
02:19:09.0 2/25/2015: Aero running
02:19:09.0 2/25/2015: Tablet PC detected
02:19:09.0 2/25/2015: Initializing Vista/Windows 7 volume control
02:19:09.0 2/25/2015: Getting CPU and RAM info
02:19:09.0 2/25/2015: Intel® Core i5-3570K CPU @ 3.40GHz, 8079MB
02:19:09.0 2/25/2015: 3.4Ghz - 4 Cores or CPU's
02:19:09.0 2/25/2015: Running Randomize()
02:19:09.0 2/25/2015: Loading PlugIns
02:19:09.0 2/25/2015: Checking for applications to Launch On Startup
02:19:09.0 2/25/2015: Setting default net connection limit to 15
02:19:09.0 2/25/2015: Running Misc startup tasks
02:19:09.0 2/25/2015: Setting Menu types
02:19:09.0 2/25/2015: Getting Configuration Values
02:19:09.0 2/25/2015: Touchscreen support enabled
02:19:09.0 2/25/2015: Using Theme: Default - Default V1
02:19:09.0 2/25/2015: Checking for alternate Image Directory for Theme: Default - Default V1
02:19:09.0 2/25/2015: Using Images from theme: Default - Default\MEDIA\
02:19:09.0 2/25/2015: Initialising Video/MNG DLL's
02:19:09.0 2/25/2015: GameEx will check for media insertion (may affect performance)
02:19:09.0 2/25/2015: Is Media Center running?
02:19:09.0 2/25/2015: Checking/Creating LCD Registry values
02:19:09.0 2/25/2015: Check Media Center Exit/Start Mode
02:19:09.0 2/25/2015: Media Center Mode 2
02:19:09.0 2/25/2015: Video previews on. Warning: Only recommended on modern systems
02:19:09.0 2/25/2015: Snap Delay set to: 4
02:19:09.0 2/25/2015: Get other settings
02:19:09.0 2/25/2015: Set: Find emulator artwork on best match basis
02:19:09.0 2/25/2015: Start work for Form
02:19:09.0 2/25/2015: Getting Original Screen Size
02:19:09.0 2/25/2015: Opening Database Connection
02:19:09.1 2/25/2015: Initializing Component
02:19:09.1 2/25/2015: MAME Path is: E:\GameEx\EMULATORS\mame
02:19:09.1 2/25/2015: MAME EXE file is: MAMEUIFX x64 .150 Cave+NoNag+HiScore+NeoGeoXtra&OC+NoBuffer + DirectInput FIXED.exe
02:19:09.1 2/25/2015: ROM Path is: E:\Roms\Mame
02:19:09.1 2/25/2015: Catver.ini is located at: E:\GameEx\DATA\catver.ini
02:19:09.1 2/25/2015: controls.ini is located at: E:\GameEx\DATA\controls.ini
02:19:09.1 2/25/2015: History.dat is located at: E:\GameEx\DATA\history.dat
02:19:09.1 2/25/2015: nplayers.ini is located at: E:\GameEx\DATA\nplayers.ini
02:19:09.1 2/25/2015: command.dat is located at: E:\GameEx\DATA\command.dat
02:19:09.1 2/25/2015: MAMEinfo.dat is located at: E:\GameEx\DATA\mameinfo.dat
02:19:09.1 2/25/2015: Loading Controls.ini map file
02:19:09.1 2/25/2015: Snap Path: Not Found
02:19:09.1 2/25/2015: Database Snap Path: Not Found
02:19:09.1 2/25/2015: Background Snap Path: Not Found
02:19:09.1 2/25/2015: AVI Snap Path: Not Found
02:19:09.1 2/25/2015: Flyer Path: Not Found
02:19:09.1 2/25/2015: Cabinet Path: Not Found
02:19:09.1 2/25/2015: Cabinet 3D Path: Not Found
02:19:09.1 2/25/2015: Title Path: Not Found
02:19:09.1 2/25/2015: PCB Path: Not Found
02:19:09.1 2/25/2015: Artwork Preview Path: Not Found
02:19:09.1 2/25/2015: Panel Path: Not Found
02:19:09.1 2/25/2015: Manual Path: Not Found
02:19:09.1 2/25/2015: Icon Path: Not Found
02:19:09.2 2/25/2015: Marquee Path: Not Found
02:19:09.2 2/25/2015: Applying Language/Text
02:19:09.2 2/25/2015: Text/Language: English
02:19:09.2 2/25/2015: Loading Language/Text
02:19:09.2 2/25/2015: Loading Custom Emulators
02:19:09.2 2/25/2015: Loading Emulator 1: [Handheld] Bandai WonderSwan (mednafen)
02:19:09.2 2/25/2015: Loading Emulator 2: [Handheld] Bandai WonderSwan Color (mednafen)
02:19:09.2 2/25/2015: Loading Emulator 3: [Console] NEC PC-FX (mednafen)
02:19:09.2 2/25/2015: Loading Emulator 4: [Console] NEC SuperGrafx (mednafen)
02:19:09.2 2/25/2015: Loading Emulator 5: [Console] NEC TurboGrafx CD (mednafen)
02:19:09.2 2/25/2015: Loading Emulator 6: [Console] NEC TurboGrafx-16 (mednafen)
02:19:09.2 2/25/2015: Loading Emulator 7: [Handheld] Nintendo Game Boy (mednafen)
02:19:09.2 2/25/2015: Loading Emulator 8: [Handheld] Nintendo Game Boy Color (mednafen)
02:19:09.2 2/25/2015: Loading Emulator 9: [Handheld] Nintendo Game Boy Advance (mednafen)
02:19:09.2 2/25/2015: Loading Emulator 10: [Console] Nintendo NES (MESS)
02:19:09.2 2/25/2015: Loading Emulator 11: [Console] Nintendo SNES (Snes9x)
02:19:09.2 2/25/2015: Loading Emulator 12: [Console] Nintendo N64 (Project64)
02:19:09.2 2/25/2015: Loading Emulator 13: [Console] Nintendo GameCube (Dolphin)
02:19:09.2 2/25/2015: Loading Emulator 14: [Console] Nintendo Wii (Dolphin)
02:19:09.2 2/25/2015: Loading Emulator 15: [Arcade] Sammy Atomiswave (DEmul)
02:19:09.2 2/25/2015: Loading Emulator 16: [Handheld] Sega Game Gear (MESS)
02:19:09.2 2/25/2015: Loading Emulator 17: [Console] Sega Master System (Fusion)
02:19:09.2 2/25/2015: Loading Emulator 18: [Console] Sega Genesis (Fusion)
02:19:09.2 2/25/2015: Loading Emulator 19: [Console] Sega 32X (Fusion)
02:19:09.2 2/25/2015: Loading Emulator 20: [Console] Sega CD (Fusion)
02:19:09.2 2/25/2015: Loading Emulator 21: [Console] Sega Saturn (SSF)
02:19:09.2 2/25/2015: Loading Emulator 22: [Console] Sega Dreamcast (nullDC)
02:19:09.2 2/25/2015: Loading Emulator 23: [Arcade] Sega Naomi (DEmul)
02:19:09.2 2/25/2015: Loading Emulator 24: [Console] SNK Neo Geo CD (Nebula)
02:19:09.2 2/25/2015: Loading Emulator 25: [Handheld] SNK Neo Geo Pocket (Mednafen)
02:19:09.2 2/25/2015: Loading Emulator 26: [Console] Sony Playstation (ePSXe)
02:19:09.2 2/25/2015: Loading Emulator 27: [Handheld] Sony PSP (PCSP)
02:19:09.2 2/25/2015: Checking if Steam enabled
02:19:09.2 2/25/2015: Steam is installed correctly
02:19:09.2 2/25/2015: Found no valid steam base install folders
02:19:09.2 2/25/2015: Checking if Origin enabled
02:19:09.2 2/25/2015: Origin support is turned off in configuration.
02:19:09.2 2/25/2015: Checking if Uplay enabled
02:19:09.2 2/25/2015: UPlay support is turned off in configuration.
02:19:09.2 2/25/2015: Using 2D Animations
02:19:09.2 2/25/2015: Retrieving resolution setting
02:19:09.2 2/25/2015: Using General Font: Trebuchet MS
02:19:09.2 2/25/2015: Using Title Font: Trebuchet MS
02:19:09.2 2/25/2015: GameEx will try to reduce CPU usage
02:19:09.2 2/25/2015: Initialising Direct3D
02:19:09.3 2/25/2015: Applying GameEx is Loading Image
02:19:09.3 2/25/2015: Creating Surfaces
02:19:09.3 2/25/2015: Creating Primary Surface - Windowed Mode
02:19:09.3 2/25/2015: Creating Back Buffer
02:19:09.3 2/25/2015: Loading graphic Surfaces
02:19:09.3 2/25/2015: Display is running at: 1920x1080 32bit color, 60hz
02:19:09.3 2/25/2015: Adapter: NVIDIA GeForce GTX 560 Ti
02:19:09.3 2/25/2015: Max texture size: 16384x16384
02:19:09.3 2/25/2015: Available texture memory: -55MB
02:19:09.3 2/25/2015: Initialising Bass Audio Library
02:19:09.4 2/25/2015: Creating Surfaces Misc and Dialogs
02:19:09.4 2/25/2015: Creating Surfaces Volume
02:19:09.4 2/25/2015: Creating Surfaces Arrows
02:19:09.4 2/25/2015: Creating Surfaces GameEXlogo Text
02:19:09.4 2/25/2015: Creating Surfaces Toolbar
02:19:09.4 2/25/2015: Creating Surfaces Toolbar Controls
02:19:09.4 2/25/2015: Creating Surfaces Backgrounds
02:19:09.4 2/25/2015: Creating Surfaces GameEx Logo
02:19:09.4 2/25/2015: Creating Surface Unselected
02:19:09.4 2/25/2015: Creating Surfaces Home & Exit
02:19:09.4 2/25/2015: Creating Surfaces Snaps
02:19:09.4 2/25/2015: Creating Surfaces Menu and List Bars
02:19:09.5 2/25/2015: Creating Fonts
02:19:09.5 2/25/2015: Creating Game Font
02:19:09.5 2/25/2015: Creating Game Font Faded
02:19:09.6 2/25/2015: Creating Title Font
02:19:09.6 2/25/2015: Restoring Title Font From Cache
02:19:09.6 2/25/2015: Creating Menu Font
02:19:09.7 2/25/2015: Creating Font Black
02:19:09.7 2/25/2015: Creating Font Black Small
02:19:09.8 2/25/2015: Fonts Created Succesfully
02:19:09.8 2/25/2015: Attempting to load game list
02:19:09.8 2/25/2015: Running: MAMEUIFX x64 .150 Cave+NoNag+HiScore+NeoGeoXtra&OC+NoBuffer + DirectInput FIXED.exe -help
02:19:09.9 2/25/2015: Running: E: E:\GameEx\EMULATORS\mame\MAMEUIFX x64 .150 Cave+NoNag+HiScore+NeoGeoXtra&OC+NoBuffer + DirectInput FIXED.exe -help > E:\GameEx\EMULATORS\mame\help.txt
02:19:09.9 2/25/2015: MAME CMD options: -nowindow -joy -skip_gameinfo
02:19:09.9 2/25/2015: Cannot Load Play List. Check Path and filename
02:19:09.9 2/25/2015: Initialising DirectInput for Gamepad support
02:19:09.9 2/25/2015: Using Device Controller (Xbox 360 Wireless Receiver for Windows)
02:19:10.0 2/25/2015: Loading Start Page
02:19:10.0 2/25/2015: Initializing MCE Remote
02:19:10.0 2/25/2015: Playing intro sound file
02:19:10.0 2/25/2015: Initialization OK! Starting GameEx!
02:19:10.0 2/25/2015: Testing Main Loop Once: Processing Frame
02:19:10.1 2/25/2015: Testing Main Loop Once: Main Loop ran successfully
02:19:13.6 2/25/2015: Validating: Emulator_1: Snap Path: E:\GameEx\ASSETS\Bandai WonderSwan\Snaps
02:19:13.6 2/25/2015: Validating: Emulator_1: Control Panel Path: E:\GameEx\ASSETS\Bandai WonderSwan\Controls
02:19:13.6 2/25/2015: Validating: Emulator_1: Database: [Handheld] Bandai WonderSwan
02:19:13.6 2/25/2015: Validating: Emulator_1: Title Snap Path: E:\GameEx\ASSETS\Bandai WonderSwan\Titles
02:19:13.6 2/25/2015: Validating: Emulator_1: Box Art Path: E:\GameEx\ASSETS\Bandai WonderSwan\Boxes
02:19:13.6 2/25/2015: Validating: Emulator_1: Cart Art Path: E:\GameEx\ASSETS\Bandai WonderSwan\Cartridges
02:19:13.6 2/25/2015: Validating: Emulator_1: Manual Path: E:\GameEx\ASSETS\Bandai WonderSwan\Manuals
02:19:13.6 2/25/2015: Validating: Emulator_4: Snap Path: E:\GameEx\ASSETS\NEC SuperGrafx\Snaps
02:19:13.6 2/25/2015: Validating: Emulator_4: Control Panel Path: E:\GameEx\ASSETS\NEC SuperGrafx\Controls
02:19:13.6 2/25/2015: Validating: Emulator_4: Database: [Console] NEC SuperGrafx
02:19:13.6 2/25/2015: Validating: Emulator_4: Title Snap Path: E:\GameEx\ASSETS\NEC SuperGrafx\Titles
02:19:13.6 2/25/2015: Validating: Emulator_4: Box Art Path: E:\GameEx\ASSETS\NEC SuperGrafx\Boxes
02:19:13.6 2/25/2015: Validating: Emulator_4: Cart Art Path: E:\GameEx\ASSETS\NEC SuperGrafx\Cartridges
02:19:13.6 2/25/2015: Validating: Emulator_4: Manual Path: E:\GameEx\ASSETS\NEC SuperGrafx\Manuals
02:19:13.6 2/25/2015: Validating: Emulator_5: Snap Path: E:\GameEx\ASSETS\NEC TurboGrafx CD\Snaps
02:19:13.6 2/25/2015: Validating: Emulator_5: Control Panel Path: E:\GameEx\ASSETS\NEC TurboGrafx CD\Controls
02:19:13.6 2/25/2015: Validating: Emulator_5: Database: [Console] NEC TurboGrafx CD
02:19:13.6 2/25/2015: Validating: Emulator_5: Title Snap Path: E:\GameEx\ASSETS\NEC TurboGrafx CD\Titles
02:19:13.6 2/25/2015: Validating: Emulator_5: Box Art Path: E:\GameEx\ASSETS\NEC TurboGrafx CD\Boxes
02:19:13.6 2/25/2015: Validating: Emulator_5: Cart Art Path: E:\GameEx\ASSETS\NEC TurboGrafx CD\Cartridges
02:19:13.6 2/25/2015: Validating: Emulator_5: Manual Path: E:\GameEx\ASSETS\NEC TurboGrafx CD\Manuals
02:19:13.6 2/25/2015: Validating: Emulator_6: Snap Path: E:\GameEx\ASSETS\NEC TurboGrafx-16\Snaps
02:19:13.6 2/25/2015: Validating: Emulator_6: Control Panel Path: E:\GameEx\ASSETS\NEC TurboGrafx-16\Controls
02:19:13.6 2/25/2015: Validating: Emulator_6: Database: [Console] NEC TurboGrafx-16
02:19:13.6 2/25/2015: Validating: Emulator_6: Title Snap Path: E:\GameEx\ASSETS\NEC TurboGrafx-16\Titles
02:19:13.6 2/25/2015: Validating: Emulator_6: Box Art Path: E:\GameEx\ASSETS\NEC TurboGrafx-16\Boxes
02:19:13.6 2/25/2015: Validating: Emulator_6: Cart Art Path: E:\GameEx\ASSETS\NEC TurboGrafx-16\Cartridges
02:19:13.6 2/25/2015: Validating: Emulator_6: Manual Path: E:\GameEx\ASSETS\NEC TurboGrafx-16\Manuals
02:19:13.6 2/25/2015: Validating: Emulator_7: Snap Path: E:\GameEx\ASSETS\Nintendo Game Boy\Snaps
02:19:13.6 2/25/2015: Validating: Emulator_7: Control Panel Path: E:\GameEx\ASSETS\Nintendo Game Boy\Controls
02:19:13.6 2/25/2015: Validating: Emulator_7: Database: [Handheld] Nintendo Game Boy
02:19:13.6 2/25/2015: Validating: Emulator_7: Title Snap Path: E:\GameEx\ASSETS\Nintendo Game Boy\Titles
02:19:13.6 2/25/2015: Validating: Emulator_7: Box Art Path: E:\GameEx\ASSETS\Nintendo Game Boy\Boxes
02:19:13.6 2/25/2015: Validating: Emulator_7: Cart Art Path: E:\GameEx\ASSETS\Nintendo Game Boy\Cartridges
02:19:13.6 2/25/2015: Validating: Emulator_7: Manual Path: E:\GameEx\ASSETS\Nintendo Game Boy\Manuals
02:19:13.6 2/25/2015: Validating: Emulator_8: Snap Path: E:\GameEx\ASSETS\Nintendo Game Boy Color\Snaps
02:19:13.6 2/25/2015: Validating: Emulator_8: Control Panel Path: E:\GameEx\ASSETS\Nintendo Game Boy Color\Controls
02:19:13.6 2/25/2015: Validating: Emulator_8: Database: [Handheld] Nintendo Game Boy Color
02:19:13.6 2/25/2015: Validating: Emulator_8: Title Snap Path: E:\GameEx\ASSETS\Nintendo Game Boy Color\Titles
02:19:13.6 2/25/2015: Validating: Emulator_8: Box Art Path: E:\GameEx\ASSETS\Nintendo Game Boy Color\Boxes
02:19:13.6 2/25/2015: Validating: Emulator_8: Cart Art Path: E:\GameEx\ASSETS\Nintendo Game Boy Color\Cartridges
02:19:13.6 2/25/2015: Validating: Emulator_8: Manual Path: E:\GameEx\ASSETS\Nintendo Game Boy Color\Manuals
02:19:13.6 2/25/2015: Validating: Emulator_9: Snap Path: E:\GameEx\ASSETS\Nintendo Game Boy Advance\Snaps
02:19:13.6 2/25/2015: Validating: Emulator_9: Control Panel Path: E:\GameEx\ASSETS\Nintendo Game Boy Advance\Controls
02:19:13.6 2/25/2015: Validating: Emulator_9: Database: [Handheld] Nintendo Game Boy Advance
02:19:13.6 2/25/2015: Validating: Emulator_9: Title Snap Path: E:\GameEx\ASSETS\Nintendo Game Boy Advance\Titles
02:19:13.6 2/25/2015: Validating: Emulator_9: Box Art Path: E:\GameEx\ASSETS\Nintendo Game Boy Advance\Boxes
02:19:13.6 2/25/2015: Validating: Emulator_9: Cart Art Path: E:\GameEx\ASSETS\Nintendo Game Boy Advance\Cartridges
02:19:13.6 2/25/2015: Validating: Emulator_9: Manual Path: E:\GameEx\ASSETS\Nintendo Game Boy Advance\Manuals
02:19:13.6 2/25/2015: Validating: Emulator_10: Snap Path: E:\GameEx\ASSETS\Nintendo NES\Snaps
02:19:13.6 2/25/2015: Validating: Emulator_10: Control Panel Path: E:\GameEx\ASSETS\Nintendo NES\Controls
02:19:13.6 2/25/2015: Validating: Emulator_10: Database: [Console] Nintendo NES
02:19:13.6 2/25/2015: Validating: Emulator_10: Title Snap Path: E:\GameEx\ASSETS\Nintendo NES\Titles
02:19:13.6 2/25/2015: Validating: Emulator_10: Box Art Path: E:\GameEx\ASSETS\Nintendo NES\Boxes
02:19:13.6 2/25/2015: Validating: Emulator_10: Cart Art Path: E:\GameEx\ASSETS\Nintendo NES\Cartridges
02:19:13.6 2/25/2015: Validating: Emulator_10: Manual Path: E:\GameEx\ASSETS\Nintendo NES\Manuals
02:19:13.6 2/25/2015: Validating: Emulator_11: Snap Path: E:\GameEx\ASSETS\Nintendo SNES\Snaps
02:19:13.6 2/25/2015: Validating: Emulator_11: Control Panel Path: E:\GameEx\ASSETS\Nintendo SNES\Controls
02:19:13.6 2/25/2015: Validating: Emulator_11: Database: [Console] Nintendo SNES
02:19:13.6 2/25/2015: Validating: Emulator_11: Title Snap Path: E:\GameEx\ASSETS\Nintendo SNES\Titles
02:19:13.6 2/25/2015: Validating: Emulator_11: Box Art Path: E:\GameEx\ASSETS\Nintendo SNES\Boxes
02:19:13.6 2/25/2015: Validating: Emulator_11: Cart Art Path: E:\GameEx\ASSETS\Nintendo SNES\Cartridges
02:19:13.6 2/25/2015: Validating: Emulator_11: Manual Path: E:\GameEx\ASSETS\Nintendo SNES\Manuals
02:19:13.6 2/25/2015: Validating: Emulator_12: Snap Path: E:\GameEx\ASSETS\Nintendo N64\Snaps
02:19:13.6 2/25/2015: Validating: Emulator_12: Control Panel Path: E:\GameEx\ASSETS\Nintendo N64\Controls
02:19:13.6 2/25/2015: Validating: Emulator_12: Database: [Console] Nintendo N64
02:19:13.6 2/25/2015: Validating: Emulator_12: Title Snap Path: E:\GameEx\ASSETS\Nintendo N64\Titles
02:19:13.6 2/25/2015: Validating: Emulator_12: Box Art Path: E:\GameEx\ASSETS\Nintendo N64\Boxes
02:19:13.6 2/25/2015: Validating: Emulator_12: Cart Art Path: E:\GameEx\ASSETS\Nintendo N64\Cartridges
02:19:13.6 2/25/2015: Validating: Emulator_12: Manual Path: E:\GameEx\ASSETS\Nintendo N64\Manuals
02:19:13.6 2/25/2015: Validating: Emulator_13: Snap Path: E:\GameEx\ASSETS\Nintendo GameCube\Snaps
02:19:13.6 2/25/2015: Validating: Emulator_13: Control Panel Path: E:\GameEx\ASSETS\Nintendo GameCube\Controls
02:19:13.6 2/25/2015: Validating: Emulator_13: Database: [Console] Nintendo GameCube
02:19:13.6 2/25/2015: Validating: Emulator_13: Title Snap Path: E:\GameEx\ASSETS\Nintendo GameCube\Titles
02:19:13.6 2/25/2015: Validating: Emulator_13: Box Art Path: E:\GameEx\ASSETS\Nintendo GameCube\Boxes
02:19:13.6 2/25/2015: Validating: Emulator_13: Cart Art Path: E:\GameEx\ASSETS\Nintendo GameCube\Cartridges
02:19:13.6 2/25/2015: Validating: Emulator_13: Manual Path: E:\GameEx\ASSETS\Nintendo GameCube\Manuals
02:19:13.6 2/25/2015: Validating: Emulator_14: Snap Path: E:\GameEx\ASSETS\Nintendo Wii\Snaps
02:19:13.6 2/25/2015: Validating: Emulator_14: Control Panel Path: E:\GameEx\ASSETS\Nintendo Wii\Controls
02:19:13.6 2/25/2015: Validating: Emulator_14: Database: [Console] Nintendo Wii
02:19:13.6 2/25/2015: Validating: Emulator_14: Title Snap Path: E:\GameEx\ASSETS\Nintendo Wii\Titles
02:19:13.6 2/25/2015: Validating: Emulator_14: Box Art Path: E:\GameEx\ASSETS\Nintendo Wii\Boxes
02:19:13.6 2/25/2015: Validating: Emulator_14: Cart Art Path: E:\GameEx\ASSETS\Nintendo Wii\Cartridges
02:19:13.6 2/25/2015: Validating: Emulator_14: Manual Path: E:\GameEx\ASSETS\Nintendo Wii\Manuals
02:19:13.6 2/25/2015: Validating: Emulator_15: Snap Path: E:\GameEx\ASSETS\Arcade\DEmul\Snaps
02:19:13.6 2/25/2015: Validating: Emulator_15: Control Panel Path: E:\GameEx\ASSETS\Arcade\DEmul\Controls
02:19:13.6 2/25/2015: Validating: Emulator_15: Database: [Arcade] Sammy Atomiswave
02:19:13.6 2/25/2015: Validating: Emulator_15: Title Snap Path: E:\GameEx\ASSETS\Arcade\DEmul\Titles
02:19:13.6 2/25/2015: Validating: Emulator_15: Box Art Path: E:\GameEx\ASSETS\Arcade\DEmul\Boxes
02:19:13.6 2/25/2015: Validating: Emulator_15: Cart Art Path: E:\GameEx\ASSETS\Arcade\DEmul\Cartridges
02:19:13.6 2/25/2015: Validating: Emulator_15: Manual Path: E:\GameEx\ASSETS\Arcade\DEmul\Manuals
02:19:13.6 2/25/2015: Validating: Emulator_16: Snap Path: E:\GameEx\ASSETS\Sega Game Gear\Snaps
02:19:13.6 2/25/2015: Validating: Emulator_16: Control Panel Path: E:\GameEx\ASSETS\Sega Game Gear\Controls
02:19:13.6 2/25/2015: Validating: Emulator_16: Database: [Handheld] Sega Game Gear
02:19:13.6 2/25/2015: Validating: Emulator_16: Title Snap Path: E:\GameEx\ASSETS\Sega Game Gear\Titles
02:19:13.6 2/25/2015: Validating: Emulator_16: Box Art Path: E:\GameEx\ASSETS\Sega Game Gear\Boxes
02:19:13.6 2/25/2015: Validating: Emulator_16: Cart Art Path: E:\GameEx\ASSETS\Sega Game Gear\Cartridges
02:19:13.6 2/25/2015: Validating: Emulator_16: Manual Path: E:\GameEx\ASSETS\Sega Game Gear\Manuals
02:19:13.6 2/25/2015: Validating: Emulator_17: Snap Path: E:\GameEx\ASSETS\Sega Master System\Snaps
02:19:13.6 2/25/2015: Validating: Emulator_17: Control Panel Path: E:\GameEx\ASSETS\Sega Master System\Controls
02:19:13.6 2/25/2015: Validating: Emulator_17: Database: [Console] Sega Master System
02:19:13.6 2/25/2015: Validating: Emulator_17: Title Snap Path: E:\GameEx\ASSETS\Sega Master System\Titles
02:19:13.6 2/25/2015: Validating: Emulator_17: Box Art Path: E:\GameEx\ASSETS\Sega Master System\Boxes
02:19:13.6 2/25/2015: Validating: Emulator_17: Cart Art Path: E:\GameEx\ASSETS\Sega Master System\Cartridges
02:19:13.6 2/25/2015: Validating: Emulator_17: Manual Path: E:\GameEx\ASSETS\Sega Master System\Manuals
02:19:13.6 2/25/2015: Validating: Emulator_18: Snap Path: E:\GameEx\ASSETS\Sega Genesis\Snaps
02:19:13.6 2/25/2015: Validating: Emulator_18: Control Panel Path: E:\GameEx\ASSETS\Sega Genesis\Controls
02:19:13.6 2/25/2015: Validating: Emulator_18: Database: [Console] Sega Genesis
02:19:13.6 2/25/2015: Validating: Emulator_18: Title Snap Path: E:\GameEx\ASSETS\Sega Genesis\Titles
02:19:13.6 2/25/2015: Validating: Emulator_18: Box Art Path: E:\GameEx\ASSETS\Sega Genesis\Boxes
02:19:13.6 2/25/2015: Validating: Emulator_18: Cart Art Path: E:\GameEx\ASSETS\Sega Genesis\Cartridges
02:19:13.6 2/25/2015: Validating: Emulator_18: Manual Path: E:\GameEx\ASSETS\Sega Genesis\Manuals
02:19:13.6 2/25/2015: Validating: Emulator_19: Snap Path: E:\GameEx\ASSETS\Sega 32X\Snaps
02:19:13.6 2/25/2015: Validating: Emulator_19: Control Panel Path: E:\GameEx\ASSETS\Sega 32X\Controls
02:19:13.6 2/25/2015: Validating: Emulator_19: Database: [Console] Sega 32X
02:19:13.6 2/25/2015: Validating: Emulator_19: Title Snap Path: E:\GameEx\ASSETS\Sega 32X\Titles
02:19:13.6 2/25/2015: Validating: Emulator_19: Box Art Path: E:\GameEx\ASSETS\Sega 32X\Boxes
02:19:13.6 2/25/2015: Validating: Emulator_19: Cart Art Path: E:\GameEx\ASSETS\Sega 32X\Cartridges
02:19:13.6 2/25/2015: Validating: Emulator_19: Manual Path: E:\GameEx\ASSETS\Sega 32X\Manuals
02:19:13.6 2/25/2015: Validating: Emulator_20: Snap Path: E:\GameEx\ASSETS\Sega CD\Snaps
02:19:13.6 2/25/2015: Validating: Emulator_20: Control Panel Path: E:\GameEx\ASSETS\Sega CD\Controls
02:19:13.6 2/25/2015: Validating: Emulator_20: Database: [Console] Sega CD
02:19:13.6 2/25/2015: Validating: Emulator_20: Title Snap Path: E:\GameEx\ASSETS\Sega CD\Titles
02:19:13.6 2/25/2015: Validating: Emulator_20: Box Art Path: E:\GameEx\ASSETS\Sega CD\Boxes
02:19:13.6 2/25/2015: Validating: Emulator_20: Cart Art Path: E:\GameEx\ASSETS\Sega CD\Cartridges
02:19:13.6 2/25/2015: Validating: Emulator_20: Manual Path: E:\GameEx\ASSETS\Sega CD\Manuals
02:19:13.6 2/25/2015: Validating: Emulator_21: Snap Path: E:\GameEx\ASSETS\Sega Saturn\Snaps
02:19:13.6 2/25/2015: Validating: Emulator_21: Control Panel Path: E:\GameEx\ASSETS\Sega Saturn\Controls
02:19:13.6 2/25/2015: Validating: Emulator_21: Database: [Console] Sega Saturn
02:19:13.6 2/25/2015: Validating: Emulator_21: Title Snap Path: E:\GameEx\ASSETS\Sega Saturn\Titles
02:19:13.6 2/25/2015: Validating: Emulator_21: Box Art Path: E:\GameEx\ASSETS\Sega Saturn\Boxes
02:19:13.6 2/25/2015: Validating: Emulator_21: Cart Art Path: E:\GameEx\ASSETS\Sega Saturn\Cartridges
02:19:13.6 2/25/2015: Validating: Emulator_21: Manual Path: E:\GameEx\ASSETS\Sega Saturn\Manuals
02:19:13.6 2/25/2015: Validating: Emulator_22: Snap Path: E:\GameEx\ASSETS\Sega Dreamcast\Snaps
02:19:13.6 2/25/2015: Validating: Emulator_22: Control Panel Path: E:\GameEx\ASSETS\Sega Dreamcast\Controls
02:19:13.6 2/25/2015: Validating: Emulator_22: Database: [Console] Sega Dreamcast
02:19:13.6 2/25/2015: Validating: Emulator_22: Title Snap Path: E:\GameEx\ASSETS\Sega Dreamcast\Titles
02:19:13.6 2/25/2015: Validating: Emulator_22: Box Art Path: E:\GameEx\ASSETS\Sega Dreamcast\Boxes
02:19:13.6 2/25/2015: Validating: Emulator_22: Cart Art Path: E:\GameEx\ASSETS\Sega Dreamcast\Cartridges
02:19:13.6 2/25/2015: Validating: Emulator_22: Manual Path: E:\GameEx\ASSETS\Sega Dreamcast\Manuals
02:19:13.6 2/25/2015: Validating: Emulator_23: Snap Path: E:\GameEx\ASSETS\Arcade\DEmul\Snaps
02:19:13.6 2/25/2015: Validating: Emulator_23: Control Panel Path: E:\GameEx\ASSETS\Arcade\DEmul\Controls
02:19:13.6 2/25/2015: Validating: Emulator_23: Database: [Arcade] Sega Naomi
02:19:13.6 2/25/2015: Validating: Emulator_23: Title Snap Path: E:\GameEx\ASSETS\Arcade\DEmul\Titles
02:19:13.6 2/25/2015: Validating: Emulator_23: Box Art Path: E:\GameEx\ASSETS\Arcade\DEmul\Boxes
02:19:13.6 2/25/2015: Validating: Emulator_23: Cart Art Path: E:\GameEx\ASSETS\Arcade\DEmul\Cartridges
02:19:13.6 2/25/2015: Validating: Emulator_23: Manual Path: E:\GameEx\ASSETS\Arcade\DEmul\Manuals
02:19:13.6 2/25/2015: Validating: Emulator_24: Snap Path: E:\GameEx\ASSETS\SNK Neo Geo CD\Snaps
02:19:13.6 2/25/2015: Validating: Emulator_24: Control Panel Path: E:\GameEx\ASSETS\SNK Neo Geo CD\Controls
02:19:13.6 2/25/2015: Validating: Emulator_24: Database: [Console] SNK Neo Geo CD
02:19:13.6 2/25/2015: Validating: Emulator_24: Title Snap Path: E:\GameEx\ASSETS\SNK Neo Geo CD\Titles
02:19:13.6 2/25/2015: Validating: Emulator_24: Box Art Path: E:\GameEx\ASSETS\SNK Neo Geo CD\Boxes
02:19:13.6 2/25/2015: Validating: Emulator_24: Cart Art Path: E:\GameEx\ASSETS\SNK Neo Geo CD\Cartridges
02:19:13.6 2/25/2015: Validating: Emulator_24: Manual Path: E:\GameEx\ASSETS\SNK Neo Geo CD\Manuals
02:19:13.6 2/25/2015: Validating: Emulator_25: Snap Path: E:\GameEx\ASSETS\SNK Neo Geo Pocket\Snaps
02:19:13.6 2/25/2015: Validating: Emulator_25: Control Panel Path: E:\GameEx\ASSETS\SNK Neo Geo Pocket\Controls
02:19:13.6 2/25/2015: Validating: Emulator_25: Database: [Handheld] SNK Neo Geo Pocket
02:19:13.6 2/25/2015: Validating: Emulator_25: Title Snap Path: E:\GameEx\ASSETS\SNK Neo Geo Pocket\Titles
02:19:13.6 2/25/2015: Validating: Emulator_25: Box Art Path: E:\GameEx\ASSETS\SNK Neo Geo Pocket\Boxes
02:19:13.6 2/25/2015: Validating: Emulator_25: Cart Art Path: E:\GameEx\ASSETS\SNK Neo Geo Pocket\Cartridges
02:19:13.6 2/25/2015: Validating: Emulator_25: Manual Path: E:\GameEx\ASSETS\SNK Neo Geo Pocket\Manuals
02:19:13.6 2/25/2015: Validating: Emulator_26: Snap Path: E:\GameEx\ASSETS\Sony Playstation\Snaps
02:19:13.6 2/25/2015: Validating: Emulator_26: Control Panel Path: E:\GameEx\ASSETS\Sony Playstation\Controls
02:19:13.6 2/25/2015: Validating: Emulator_26: Database: [Console] Sony PlayStation
02:19:13.6 2/25/2015: Validating: Emulator_26: Title Snap Path: E:\GameEx\ASSETS\Sony Playstation\Titles
02:19:13.6 2/25/2015: Validating: Emulator_26: Box Art Path: E:\GameEx\ASSETS\Sony Playstation\Boxes
02:19:13.6 2/25/2015: Validating: Emulator_26: Cart Art Path: E:\GameEx\ASSETS\Sony Playstation\Cartridges
02:19:13.6 2/25/2015: Validating: Emulator_26: Manual Path: E:\GameEx\ASSETS\Sony Playstation\Manuals
02:19:13.6 2/25/2015: Warning: Emulator_26: MAPFile Does Not Exist
02:19:13.6 2/25/2015: Validating: Emulator_27: Snap Path: E:\GameEx\ASSETS\Sony PSP\Snaps
02:19:13.6 2/25/2015: Validating: Emulator_27: Control Panel Path: E:\GameEx\ASSETS\Sony PSP\Controls
02:19:13.6 2/25/2015: Validating: Emulator_27: Database: [Handheld] Sony PSP
02:19:13.6 2/25/2015: Validating: Emulator_27: Title Snap Path: E:\GameEx\ASSETS\Sony PSP\Titles
02:19:13.6 2/25/2015: Validating: Emulator_27: Box Art Path: E:\GameEx\ASSETS\Sony PSP\Boxes
02:19:13.6 2/25/2015: Validating: Emulator_27: Cart Art Path: E:\GameEx\ASSETS\Sony PSP\Cartridges
02:19:13.6 2/25/2015: Validating: Emulator_27: Manual Path: E:\GameEx\ASSETS\Sony PSP\Manuals
02:19:13.6 2/25/2015: Restoring Emulator from Cache: 1
02:19:13.6 2/25/2015: Restoring Emulator Database From Cache: 1
02:19:13.7 2/25/2015: Restoring Emulator from Cache: 4
02:19:13.7 2/25/2015: Restoring Emulator Database From Cache: 4
02:19:13.7 2/25/2015: Restoring Emulator Database From Cache: 6
02:19:13.7 2/25/2015: Restoring Emulator from Cache: 7
02:19:13.8 2/25/2015: Restoring Emulator Database From Cache: 7
02:19:13.8 2/25/2015: Restoring Emulator from Cache: 8
02:19:13.8 2/25/2015: Restoring Emulator Database From Cache: 8
02:19:13.9 2/25/2015: Restoring Emulator from Cache: 9
02:19:13.9 2/25/2015: Restoring Emulator Database From Cache: 9
02:19:13.9 2/25/2015: Restoring Emulator from Cache: 10
02:19:14.0 2/25/2015: Restoring Emulator Database From Cache: 10
02:19:14.1 2/25/2015: Restoring Emulator from Cache: 11
02:19:14.1 2/25/2015: Restoring Emulator Database From Cache: 11
02:19:14.1 2/25/2015: Restoring Emulator from Cache: 12
02:19:14.2 2/25/2015: Restoring Emulator Database From Cache: 12
02:19:14.2 2/25/2015: Restoring Emulator from Cache: 13
02:19:14.2 2/25/2015: No Database Data: 13
02:19:14.2 2/25/2015: Restoring Emulator Database From Cache: 15
02:19:14.2 2/25/2015: Restoring Emulator from Cache: 16
02:19:14.3 2/25/2015: Restoring Emulator Database From Cache: 16
02:19:14.3 2/25/2015: Restoring Emulator from Cache: 17
02:19:14.3 2/25/2015: Restoring Emulator Database From Cache: 17
02:19:14.3 2/25/2015: Restoring Emulator from Cache: 18
02:19:14.4 2/25/2015: Restoring Emulator Database From Cache: 18
02:19:14.4 2/25/2015: Restoring Emulator from Cache: 19
02:19:14.4 2/25/2015: Restoring Emulator Database From Cache: 19
02:19:14.4 2/25/2015: Restoring Emulator Database From Cache: 23
02:19:14.5 2/25/2015: Restoring Emulator from Cache: 25
02:19:14.5 2/25/2015: Restoring Emulator Database From Cache: 25
02:19:14.5 2/25/2015: Restoring Emulator from Cache: 26
02:19:14.5 2/25/2015: No Database Data: 26
02:19:25.6 2/25/2015: Writing Game List to disk
02:19:25.6 2/25/2015: Updating MAME Game List
02:19:25.6 2/25/2015: Running: E: E:\GameEx\EMULATORS\mame\MAMEUIFX x64 .150 Cave+NoNag+HiScore+NeoGeoXtra&OC+NoBuffer + DirectInput FIXED.exe -listxml > E:\GameEx\EMULATORS\mame\listinfo.dat
02:19:25.6 2/25/2015: Opening Listinfo.dat
02:19:27.1 2/25/2015: Reading ListInfo.dat
Edited by tthurman
compressed text
You may need to use a normal MAME build to get the list to update, or it could be the + signs in the filename causing issues.
As for GameEx Online. I suspect one of your game lists is causing an issue with some or too many weird characters. You may have to troubleshoot and see which one is causing the issue.
So I used normal mame build 0.159 and now it does not get stuck on updating gamelist. And the gameex online works too!
But mame is only showing 156 games. I have full 0.159 set and chd's. Tried settings other post suggested and tried many different versions of mame. Still the same result. What could be the issue??
It's most always a setting with the filtering that causes this.
Did you set verify roms to no?
Check Dazzle's post here for more detail
If you've tried all these, and still have issues, please start a new thread.
Since your original issue has been resolved this one will be closed.
