I get this weird crash and its getting annoying and the only way to stop it is to change cfg file
Emulator auto start =1 <--- Crashes at start up
Change it to 0 and it doesn't but obvouisly it makes gameex not boot the image.
The weird thing is I had it working on gameex but it has started all of a sudden was literally exit gameex after playing msr then boot up nulldc to change controls crash on start. Happens outside gameex as well. Using the latest version from github. I've tried a fresh install but same :(
Anyone heard of this?
I don't run this one, but your description sure makes it sound like a problem with nulldc.
I would suggest you post your log.txt in hopes it provides some clues.
Marked as resolved, feel a little stupid but for those who have same issue
LoadDefaultImage=1 deactivate when in windows if you want to mess around with settings and whatnot by putting LoadDefaultImage=0
When sorted put the 1 back, when you run games in GameEx it will be fine
