Hi
Painting is done. 2 primer and 5 black coats. Its not totally perfect but I give up. I hate painting and I don't have the will nor the patience to spend one week on this. I tried to wet sand between coats but that not really worked the way I would.
That's not bad anyway.
So I worked late yesterday to mount the buttons, IT and Audio. Everything's good.
post-27688-0-57030300-1430722701_thumb.j
post-27688-0-89365300-1430722371_thumb.j
post-27688-0-94723100-1430722506_thumb.j
To answer tthurman: the trackball is not steel but illuminated... And I absolutely hate it. I ordered a blue and received this ugly green. I will have to either change their LEDs with blue or remove them.
Drawer Opened/Closed
post-27688-0-21712000-1430722149_thumb.jpost-27688-0-25282700-1430722849_thumb.j
That's the bottom CP when the drawer is opened: everything's accessible so its very convenient for maintenance and 4/8 way switch.
post-27688-0-53223200-1430722782_thumb.j
Somewhat clear wiring wiring
post-27688-0-16504400-1430722068_thumb.j
Tomorrow I'll show you some pictures in darkness with all the blue light fancy things I put everywhere :)
Looking Pucca!
That's trackball's definitely green!!! See you're in europe - where did you buy it from? - just handy to know who to/not to buy parts from!
Oh... and nice shot of yer washing :)
Yesterday evening I placed all the button LEDS and micro switches, then I made a daisy-chain out of power wires that I recuperated on 2 old PSU.
post-27688-0-82124800-1430808167_thumb.j
P1 controls ground is done
post-27688-0-39726800-1430808055_thumb.j
Slowly but surely
A few questions from an IPAC2 noob to pros :D
1. I thought to assign the IPAC SHIFT to the PAUSE key, which is the white on the middle edge. Is that a good idea ? Apparently it is set by default on P1 Start.
2. I have placed 2 buttons on each side for the flipper, where should I plug them? I mean which IPAC2 entry is the more convenient in terms of gameplay, config and usability?
I have never played with your flipper emulators.
3. I absolutely need an efficient and highly responsive combination to control the volume. It should be WINDOWS WIDE, and not MAME/GameEx only.
I thought to SHIFT (Pause) + joystick or trackball up and down. Is this a good idea and as anyone have a good working software/plugging for doing that? Something win7 compatible.
Have you posted this over at BYOAC?
I have an older ipac2, but Jack at Arcades R Fun built my controller (yep, I took the easy way out) so I never delved into the world of initial setup on these.
