[RESOLVED] Houston we have a problem. Neewbie cant even start Gameex
I just did a new install and paid for a years registration. I am completely new to this. I have a pc with 4 Gig RAM and I have a ASUS Micro ATX A88xm-Plus with a AMD A6-5400K APU. So no video card. Ikeep getting this error.
16:49:08.7 9/29/2014: Opening Configuration File
16:49:08.7 9/29/2014: GameEx Lite: Version 13.31: Starting Log
16:49:08.8 9/29/2014: Windows 7 Ultimate Service Pack 1 64-bit
16:49:08.8 9/29/2014: Aero NOT running
16:49:08.8 9/29/2014: Initializing Vista/Windows 7 volume control
16:49:08.8 9/29/2014: Getting CPU and RAM info
16:49:08.8 9/29/2014: AMD A6-5400K APU with Radeon HD Graphics, 3284MB
16:49:08.8 9/29/2014: 3.62Ghz - 2 Cores or CPU's
16:49:08.8 9/29/2014: Running Randomize()
16:49:08.8 9/29/2014: Checking for applications to Launch On Startup
16:49:08.8 9/29/2014: Setting default net connection limit to 15
16:49:08.8 9/29/2014: Running Misc startup tasks
16:49:08.8 9/29/2014: Setting Menu types
16:49:08.8 9/29/2014: Getting Configuration Values
16:49:08.8 9/29/2014: Using Theme: Default - RedEx - MCE1024x768
16:49:08.8 9/29/2014: Checking for alternate Image Directory for Theme: Default - RedEx - MCE1024x768
16:49:08.8 9/29/2014: Launching HideOS.exe
16:49:08.8 9/29/2014: Initialising Video/MNG DLL's
16:49:08.8 9/29/2014: Hiding Taskbar
16:49:08.8 9/29/2014: Is Media Center running?
16:49:08.8 9/29/2014: Checking/Creating LCD Registry values
16:49:08.8 9/29/2014: Check Media Center Exit/Start Mode
16:49:08.8 9/29/2014: Media Center Mode 2
16:49:08.8 9/29/2014: Snap Delay set to: 4
16:49:08.8 9/29/2014: Get other settings
16:49:08.8 9/29/2014: Desktop set to Hide ICONS and set Background to Black
16:49:08.8 9/29/2014: Set: Find emulator artwork on best match basis
16:49:08.8 9/29/2014: Start work for Form
16:49:08.8 9/29/2014: Getting Original Screen Size
16:49:08.8 9/29/2014: Opening Database Connection
16:49:08.9 9/29/2014: Initializing Component
16:49:09.0 9/29/2014: MAME Path is: C:\Emulators\Mame32
16:49:09.0 9/29/2014: Cannot Find MAME Path: MAME Disabled
16:49:09.0 9/29/2014: Loading Controls.ini map file
16:49:09.0 9/29/2014: Applying Language/Text
16:49:09.0 9/29/2014: Text/Language: English
16:49:09.0 9/29/2014: Loading Language/Text
16:49:09.0 9/29/2014: Loading Custom Emulators
16:49:09.0 9/29/2014: Loading Emulator 1: Arcade (MAME)
16:49:09.0 9/29/2014: Loading Emulator 2: Nintendo SNES (Snes9x)
16:49:09.0 9/29/2014: Loading Emulator 3: Sega Master System (Fusion)
16:49:09.0 9/29/2014: Loading Emulator 4: Sony Playstation (ePSXe)
16:49:09.1 9/29/2014: Using 2D Animations
16:49:09.1 9/29/2014: Retrieving resolution setting
16:49:09.1 9/29/2014: Using General Font: Trebuchet MS
16:49:09.1 9/29/2014: Using Title Font: Trebuchet MS
16:49:09.1 9/29/2014: GameEx will try to reduce CPU usage
16:49:09.1 9/29/2014: Initialising Direct3D
16:49:09.2 9/29/2014: Setting Resolution to 1280x720 32 bit color
16:49:09.2 9/29/2014: Creating Surfaces
16:49:09.2 9/29/2014: Warning: Display is running in full screen compatibility mode.
16:49:09.3 9/29/2014: Setting Resolution to 1280x720 32 bit color
16:49:09.3 9/29/2014: Creating Surfaces
16:49:09.3 9/29/2014: --**--
16:49:09.3 9/29/2014: Error: Error in the application.
16:49:09.3 9/29/2014: at Microsoft.DirectX.Direct3D.Manager.GetDeviceCaps(Int32 adapter, DeviceType deviceType)
16:49:09.3 9/29/2014: at Direct2D.Direct2d.Device.a(Form A_0, Int32 A_1, Int32 A_2, Boolean A_3, Boolean A_4, Boolean A_5, Boolean A_6, Int32 A_7)
16:49:09.3 9/29/2014: at Direct2D.Direct2d.Device..ctor(Form FormHandle, Int32 Width, Int32 Height, Boolean Windowed, Boolean VSync, Boolean Display16Bit, Boolean SecondaryDisplay)
16:49:09.3 9/29/2014: at GameEx.GameEx.MainForm.a(Boolean A_0, Boolean A_1, Boolean A_2, Boolean A_3, Int32 A_4, Int32 A_5, Int32 A_6, Boolean A_7, Boolean A_8)
16:49:09.3 9/29/2014: at GameEx.GameEx.MainForm.a(Boolean A_0, Boolean A_1, Boolean A_2, Boolean A_3, Int32 A_4, Int32 A_5, Int32 A_6, Boolean A_7)
16:49:09.3 9/29/2014: at GameEx.GameEx.MainForm.a(Boolean A_0, Boolean A_1, Boolean A_2, Boolean A_3, Int32 A_4, Int32 A_5, Int32 A_6)
16:49:09.3 9/29/2014: at GameEx.GameEx.MainForm.a(Boolean A_0, Boolean A_1, Boolean A_2, Boolean A_3, Int32 A_4)
16:49:09.3 9/29/2014: at GameEx.GameEx.MainForm.d(Boolean A_0, Boolean A_1, Boolean A_2)
16:49:09.3 9/29/2014: at GameEx.GameEx.MainForm.a(Boolean A_0, String A_1, Boolean A_2)
16:49:09.3 9/29/2014: at GameEx.GameEx.MainForm..ctor()
16:49:09.3 9/29/2014: It was detected you experienced a DirectX error.
16:49:09.3 9/29/2014: Please note the following for possible solutions to your problem:
16:49:09.3 9/29/2014: 1. Ensure you have the latest version of DirectX installed.
16:49:09.3 9/29/2014: 2. Ensure you have the latest Manufacturer provided video card drivers.
16:49:09.3 9/29/2014: NOTE: Windows/Microsoft Update does not contain the latest.
16:49:09.3 9/29/2014: NOTE: Manufacturer normally means ATI, NVidia, or Intel. Not the brand.
16:49:09.3 9/29/2014: www.ati.com www.nvidia.com
16:49:09.3 9/29/2014: 3. If you do not have a modern video card try the following. 1. Turn off advanced Graphics. 2. Try a lower resolution. 3. Try turning on and using 16-bit colour
16:49:09.3 9/29/2014: 4. Ensure any required video codecs are installed.
16:49:09.3 9/29/2014: 5. Try a different theme, or try running the theme at the resolution it was designed for
16:49:09.3 9/29/2014: 6. Try the latest version of GameEx. GameEx is updated all the time.
16:49:09.3 9/29/2014: 7. If you performed an auto update to this version. Try performing a manual download and install.
16:49:09.3 9/29/2014: Closing database connection
16:49:09.3 9/29/2014: GameEx is exiting with errors
16:49:09.5 9/29/2014: ERRORS DETECTED: EXITING
16:49:09.6 9/29/2014: Bye
Two things to try:
Don't run GameEx Lite. Does it work now?
Also maybe try a different theme so you can rule that out as well.
You have a GPU (embedded video card if you will) so I would recommend that you ensure that you have the latest video drivers from your mobo's website.
I have a HP laptop with an AMD APU, and have found the drivers at AMD website most beneficial when experiencing issues with the GPU. If the motherboard driver listed is current, albeit dated, I would at least consider trying the AMD reference driver. It has bailed me out on more than one occasion. Also a word of caution, when you use the reference driver, you will note windows update pointing you to a driver update, which is actually an older driver, check this to be sure your situation is the same as mine has been, and if so hide that from your update list or ignore it, else you're going to have more problems.
Thanks all for your help. It was in fact the drivers. TThurman gave the perfect advice as Windows did in fact overwrite the video drivers during an update recently. This place rocks!!
