Please share your videos and snaps of your pincabs and HTPC setups running PinballX here! Thanks in advance for sharing with the PinballX Community!
  • 1 month later...
Has anyone tried using one of the 21:9 monitors for a pincab? It might be a little expensive right now, and I'd much rather have one of these on my desk but just curious.
http://www.newegg.com/Product/Product.aspx?Item=N82E16824005396
:blink: Looks like a really sweet display, and I think that would be a more true aspect ratio for standard-size pinball tables, but yeeeaaah... the price would be a bit hard to swallow.
That's a lovely quality video horseyhorsey
What did you use to film it?
Much better than my poor quality FIRST video.
Where can I get a dmd? Man would I love to try programming something for games that don't actually tap into it... Lots of cool ways one could utilize a real dmd... pincab or arcade cab. Man the things I could buy if I had money! :)
That pincab is absolutely astonishing! I don't know what else I can say about it. Just breathtaking!
I feel like this is one of those radio station commercials........I made the switch.......PinballX rocks the airwaves!!!!
Z
1312157385143776d1257970920-best-8-bit-s
Fleabay....most of the standard pinball parts/machine vendors. -_-
Talk to Brad at vpcabs.com (my recommendation) or virtuapin.com. I would stick with a Vishay Orange dot matrix and a PinDMD v2.
Z
I finally converted to PinballX. It runs so much smoother than HP on my system. Thanks for all the hard work! I usually don't take the time to donate, but I had to after trying your program out. Check out my nearly finished mini pin build thread. I have one on BYOAC and at VPforums. They're very thurough and might help others out.
http://forum.arcadecontrols.com/index.php/topic,120248.0.html'>Signature_zps03cd408c.jpg
Not quite there, but almost.
  • 2 months later...
yes i have tried this screen but it doesn't plays realistic, the 39 inch screens are the ones that are close to the normal wpc95 tables...
but he if you want a 60inch pinball cab,... why not ;)
Also these screens are not that very expensive, my 42inch 3d led with al those extra's costed me 1400 usd ;) ( i use it also for tv and playstation in my cab) so it depands on what you want and how big your wallet is..
cheers.
  • 1 month later...
  • 4 weeks later...
