ROMS work fine in ZincGui but goes to black screen and then back to game list menu in Game Ex.
I had already been to that thread :) - it is what I used to get it working outside of GameEx. I was hoping this was a dedicated "Zinc and Game Ex" Link :)
But I will check out some of the suggestions above to see if these help my issue.
When reporting a possible GameEx bug or error, please ensure you submit a copy of your log.txt and gameex.ini file so we may quickly assist you. Please refer to this link for additional information.
P.S. I split your posts to a new thread as the issue reported by the OP of that thread was resolved and may not be quite the same as what you are experiencing.
I'd still like to try that threads fix first before bothering you guys. If I find that does not help I will get the logs for you.
I would like to suggest finding the 'How to ask for help' thread, and troubleshoot using the runitgame.bat method.
Well any of this would be for naught as they seem to run pretty slow on my Designated MAME PC :) - Work great on my Video Editing PC so maybe I'll get to this in a few years when I upgrade that PC. LOL
