Hi there,
Im pretty new to GameEX and have read through many posts relating to these type of problems but havent been able to sort it out
I can get the snaps to show up by pointing the snaps to the snap directory but when I try point to my videos folder I get nothing.
I have tried combining the snaps and videos and seperating them too.
Could someone please explain exactly how to set up gameex so I can see my snaps AND videos
I have donated to emumovies and have downloaded the hires vids using the download tool
I have the latest ffdshow and the vids play using WMP
thanks
Nat.
Hmm, you sure it's not a codec issue? Are your videos named the same as your ROM set?
I had the same problem when I was first setting up as well - I downloaded Shark007's codecs (from his website and separately to the GameEx download), and the videos then worked fine. Someone on here suggested that I shouldn't have had to do that (because the codecs come with the GameEx download), but I did and it fixed the problem.
Because your picture snaps are working i wouldnt say its a codec issue but do make sure you have sharks codec installed just to be safe,and as Adultery said the naming does need to be the same as your roms for example if you have a game/rom called "test" then the snap would be "test" and the video would also be "test", and they both need to be in the snap draw, the reason being GameEx will search the draw for the snap/video and match it with the rom and show it.
SM
Just to clarify, the codecs do not come installed with GameEx. Uninstall FFDShow and go get Shark007's Vista Codec Pack instead. :)
Ok
All my roms and snaps and videos are named the same
I have uninstalled FFDshow and installed the shark codecs for win7
I have put all my png and avi snaps into the snap folder in the assests directory
I have pointed the gameex config to look for the snaps in the same snap folder
AND I STILL DONT HAVE ANY VIDEOS!!! ARGGG!!
There is something I dont understand: in the gameex config there is the option to point to snaps and video snaps. If I only point to the snaps folder I get the snaps (images). If I point to the snaps and videos folder I get nothing, it like they cancel each other out. So why is there the option to point to a video folder when it doesnt work? Its very confusing and to be honest Im getting a little stressed considering I have shelled out the money and registered both this software and emumovies.
I must be doing something wrong, obviously, but I dont know what? Could it be the themes Im using? Do I have all the right options enabled in the config? I dont know!
Hmm... You shouldn't be having this issue. Try not pointing to snaps and pointing to videos and report back. Also try using the default theme, and please post your GameEx log/INI.
Hi,
Ive already tried poitning to videos and if I do that I get no snaps or videos, nothing!
Heres my log, as you can see the vidoes are found but are not running:
15:57:21.7 13/04/2011: GameEx: Version 11.69: Starting Log
15:57:21.7 13/04/2011: Operating System Platform: Win32NT
15:57:21.7 13/04/2011: Operating System Name: Windows Vista
15:57:21.7 13/04/2011: Operating System Version: 6.1.7601
15:57:21.8 13/04/2011: Aero running
15:57:21.8 13/04/2011: Initializing Vista/Windows 7 volume control
15:57:21.8 13/04/2011: Checking for versions of .net Framework installed
15:57:21.8 13/04/2011: .net Framework 2.0 Installed
15:57:21.8 13/04/2011: .net Framework 3.0 Installed
15:57:21.8 13/04/2011: .net Framework 3.5 Installed
15:57:21.8 13/04/2011: Pentium® Dual-Core CPU E6500 @ 2.93GHz, 2047MB
15:57:21.8 13/04/2011: 2.93Ghz - 2 Cores or CPU's
15:57:21.8 13/04/2011: Running Randomize()
15:57:21.8 13/04/2011: Loading PlugIns
15:57:21.8 13/04/2011: Checking for applications to Launch On Startup
15:57:21.8 13/04/2011: Running Misc startup tasks
15:57:21.8 13/04/2011: Setting Menu types
15:57:21.8 13/04/2011: Opening Configuration File
15:57:21.8 13/04/2011: Getting Configuration Values
15:57:21.8 13/04/2011: Using Theme: Default - Default
15:57:21.8 13/04/2011: Checking for alternate Image Directory for Theme: Default - Default
15:57:21.8 13/04/2011: Launching HideOS.exe
15:57:21.8 13/04/2011: Initialising Video/MNG DLL's
15:57:21.8 13/04/2011: GameEx will check for media insertion (may affect performance)
15:57:21.8 13/04/2011: Hiding Taskbar
15:57:21.8 13/04/2011: Is Media Center running?
15:57:21.8 13/04/2011: Checking/Creating LCD Registry values
15:57:21.8 13/04/2011: Check Media Center Exit/Start Mode
15:57:21.8 13/04/2011: Media Center Mode 2
15:57:21.8 13/04/2011: Video previews on. Warning: Only recommended on modern systems
15:57:21.8 13/04/2011: Snap Delay set to: 2
15:57:21.8 13/04/2011: Get other settings
15:57:21.8 13/04/2011: Desktop set to Hide ICONS and set Background to Black
15:57:21.8 13/04/2011: Set: Find emulator artwork on best match basis
15:57:21.8 13/04/2011: Start work for Form
15:57:21.8 13/04/2011: Getting Original Screen Size
15:57:21.8 13/04/2011: Opening Database Connection
15:57:21.8 13/04/2011: Initializing Component
15:57:21.9 13/04/2011: Retrieving resolution setting
15:57:21.9 13/04/2011: MAME Path is: D:\Games\Emulators\MAME
15:57:21.9 13/04/2011: MAME EXE file is: mame.exe
15:57:21.9 13/04/2011: ROM Path is: D:\Games\Roms\MAME\Roms
15:57:21.9 13/04/2011: Catver.ini is located at: D:\Games\GameEx\DATA\catver.ini
15:57:21.9 13/04/2011: controls.ini is located at: D:\Games\GameEx\data\controls.ini
15:57:21.9 13/04/2011: History.dat is located at: D:\Games\GameEx\DATA\history.dat
15:57:21.9 13/04/2011: nplayers.ini is located at: D:\Games\GameEx\DATA\nplayers.ini
15:57:21.9 13/04/2011: command.dat is located at: D:\Games\GameEx\DATA\command.dat
15:57:21.9 13/04/2011: MAMEinfo.dat is located at: D:\Games\GameEx\DATA\mameinfo.dat
15:57:21.9 13/04/2011: Loading Controls.ini map file
15:57:21.9 13/04/2011: Snap Path is: D:\Games\Assets\MAME\Snap
15:57:21.9 13/04/2011: AVI Snap Path: Not Found
15:57:21.9 13/04/2011: Flyer Path is: D:\Games\Assets\MAME\Advert
15:57:21.9 13/04/2011: Cabinet Path is: D:\Games\Assets\MAME\Cabinet
15:57:21.9 13/04/2011: Cabinet 3D Path: Not Found
15:57:21.9 13/04/2011: Title Path is: D:\Games\Assets\MAME\Title
15:57:21.9 13/04/2011: PCB Path is: D:\Games\Assets\MAME\PCB
15:57:21.9 13/04/2011: Artwork Preview Path is: D:\Games\Assets\MAME\Artwork
15:57:21.9 13/04/2011: Panel Path is: D:\Games\Assets\MAME\CP
15:57:21.9 13/04/2011: Manual Path: Not Found
15:57:21.9 13/04/2011: Icon Path is: D:\Games\Assets\MAME\Icon
15:57:21.9 13/04/2011: Marquee Path is: D:\Games\Assets\MAME\Marquee
15:57:21.9 13/04/2011: Loading Custom Emulators
15:57:21.9 13/04/2011: Using 2D Animations
15:57:21.9 13/04/2011: Using General Font: Trebuchet MS
15:57:21.9 13/04/2011: Using Title Font: Trebuchet MS
15:57:22.0 13/04/2011: Initialising Direct3D
15:57:22.0 13/04/2011: Applying GameEx is Loading Image
15:57:22.0 13/04/2011: Setting Resolution to 1280x720 32 bit color
15:57:22.0 13/04/2011: Creating Surfaces
15:57:22.3 13/04/2011: Creating Primary Surface - Full Screen Mode
15:57:22.4 13/04/2011: Creating Back Buffer
15:57:22.4 13/04/2011: Loading graphic Surfaces
15:57:22.4 13/04/2011: Display is running at: 1280x720 32bit color, 50hz
15:57:22.4 13/04/2011: Creating Surfaces Misc and Dialogs
15:57:22.5 13/04/2011: Creating Surfaces Volume
15:57:22.5 13/04/2011: Creating Surfaces Arrows
15:57:22.5 13/04/2011: Creating Surfaces GameEXlogo Text
15:57:22.5 13/04/2011: Creating Surfaces Toolbar
15:57:22.5 13/04/2011: Creating Surfaces Backgrounds
15:57:22.5 13/04/2011: Creating Surfaces Toolbar Controls
15:57:22.5 13/04/2011: Creating Surfaces GameEx Logo
15:57:22.5 13/04/2011: Creating Surface Unselected
15:57:22.5 13/04/2011: Creating Surfaces Home & Exit
15:57:22.5 13/04/2011: Creating Surfaces Snaps
15:57:22.5 13/04/2011: Creating Surfaces Menu and List Bars
15:57:22.7 13/04/2011: Creating Fonts
15:57:22.7 13/04/2011: Creating Game Font
15:57:22.8 13/04/2011: Creating Game Font Faded
15:57:22.9 13/04/2011: Creating Title Font
15:57:22.9 13/04/2011: Restoring Title Font From Cache
15:57:23.1 13/04/2011: Creating Menu Font
15:57:23.2 13/04/2011: Creating Font Black
15:57:23.2 13/04/2011: Creating Font Black Small
15:57:23.2 13/04/2011: Fonts Created Succesfully
15:57:23.2 13/04/2011: 3MB Video Memory Used
15:57:23.2 13/04/2011: Initialising Bass Audio Library
15:57:23.2 13/04/2011: Creating instance of global keyboard hook
15:57:23.5 13/04/2011: Attempting to load game list
15:57:23.7 13/04/2011: Applying Language/Text
15:57:23.7 13/04/2011: Text/Language: English
15:57:23.7 13/04/2011: MAME CMD options: -nowindow -joy -skip_gameinfo
15:57:23.7 13/04/2011: Loading last used Game List
15:57:23.7 13/04/2011: Cannot Load Play List. Check Path and filename
15:57:23.7 13/04/2011: Creating DirectSound Device
15:57:23.7 13/04/2011: Trying: Primary Sound Driver
15:57:23.7 13/04/2011: Loading Sound Files
15:57:23.7 13/04/2011: DirectSound Device Created Successfully
15:57:23.7 13/04/2011: Initialising DirectInput for Gamepad support
15:57:23.9 13/04/2011: Unable to create a joystick device
15:57:23.9 13/04/2011: Initializing MCE Remote
15:57:23.9 13/04/2011: Initialization OK! Starting GameEx!
15:57:23.9 13/04/2011: Testing Main Loop Once: Processing Frame
15:57:24.2 13/04/2011: Testing Main Loop Once: Main Loop ran successfully
15:57:30.5 13/04/2011: Restoring Cached ICONS from File
15:57:31.0 13/04/2011: Failed Opening Video: d:\games\assets\mame\snap\yumefuda.avi
15:57:36.6 13/04/2011: Failed Opening Video: d:\games\assets\mame\snap\005.avi
15:57:38.2 13/04/2011: Exiting GameEx!
15:57:38.2 13/04/2011: Saving Settings
15:57:39.9 13/04/2011: Disposing Plugins
15:57:39.9 13/04/2011: Closing database connection
15:57:39.9 13/04/2011: Checking for applications to Launch On Exit
15:57:39.9 13/04/2011: Media Center was not open when starting GameEx, so not launching
Also Im having problems when downloading certain themes, bubblebobble and soulcaliber both download, install but then the download screen just hangs and doesnt download the next themes in the list.
I noticed that the file you posted shows the following:
Please go into the Advanced Configuration utility Under Basic MAME Settings on the first page and set the path to your video snaps (AVI or FLV format - does not matter). Likely the path will be D:\Games\Assets\MAME\AVISnap or at least thats is how I have mine setup separate from the Snaps directory and it works just fine keeping them separated for MAME. You will mix them under the other emulators in the same directory path.
No, this does not work.
If I do this then I get no videos and no images, nothing at all.
It seems to me that I have something very seriously wrong with my setup, Im half tempted just to reinstall Windows and start again to be honest.
Anyway heres a new log with the avisnap path included:
11:44:58.2 14/04/2011: GameEx: Version 11.69: Starting Log
11:44:58.2 14/04/2011: Operating System Platform: Win32NT
11:44:58.2 14/04/2011: Operating System Name: Windows Vista
11:44:58.2 14/04/2011: Operating System Version: 6.1.7601
11:44:58.2 14/04/2011: Aero running
11:44:58.2 14/04/2011: Initializing Vista/Windows 7 volume control
11:44:58.2 14/04/2011: Checking for versions of .net Framework installed
11:44:58.2 14/04/2011: .net Framework 2.0 Installed
11:44:58.2 14/04/2011: .net Framework 3.0 Installed
11:44:58.2 14/04/2011: .net Framework 3.5 Installed
11:44:58.2 14/04/2011: Pentium® Dual-Core CPU E6500 @ 2.93GHz, 2047MB
11:44:58.2 14/04/2011: 2.93Ghz - 2 Cores or CPU's
11:44:58.2 14/04/2011: Running Randomize()
11:44:58.2 14/04/2011: Loading PlugIns
11:44:58.3 14/04/2011: Checking for applications to Launch On Startup
11:44:58.3 14/04/2011: Running Misc startup tasks
11:44:58.3 14/04/2011: Setting Menu types
11:44:58.3 14/04/2011: Opening Configuration File
11:44:58.3 14/04/2011: Getting Configuration Values
11:44:58.3 14/04/2011: Using Theme: Default - Default
11:44:58.3 14/04/2011: Checking for alternate Image Directory for Theme: Default - Default
11:44:58.3 14/04/2011: Launching HideOS.exe
11:44:58.3 14/04/2011: Initialising Video/MNG DLL's
11:44:58.3 14/04/2011: GameEx will check for media insertion (may affect performance)
11:44:58.3 14/04/2011: Hiding Taskbar
11:44:58.3 14/04/2011: Is Media Center running?
11:44:58.3 14/04/2011: Checking/Creating LCD Registry values
11:44:58.4 14/04/2011: Check Media Center Exit/Start Mode
11:44:58.4 14/04/2011: Media Center Mode 2
11:44:58.4 14/04/2011: Video previews on. Warning: Only recommended on modern systems
11:44:58.4 14/04/2011: Snap Delay set to: 2
11:44:58.4 14/04/2011: Get other settings
11:44:58.4 14/04/2011: Desktop set to Hide ICONS and set Background to Black
11:44:58.4 14/04/2011: Set: Find emulator artwork on best match basis
11:44:58.4 14/04/2011: Start work for Form
11:44:58.4 14/04/2011: Getting Original Screen Size
11:44:58.4 14/04/2011: Opening Database Connection
11:44:58.5 14/04/2011: Initializing Component
11:44:58.6 14/04/2011: Retrieving resolution setting
11:44:58.6 14/04/2011: MAME Path is: D:\Games\Emulators\MAME
11:44:58.6 14/04/2011: MAME EXE file is: mame.exe
11:44:58.6 14/04/2011: ROM Path is: D:\Games\Roms\MAME\Roms
11:44:58.6 14/04/2011: Catver.ini is located at: D:\Games\GameEx\DATA\catver.ini
11:44:58.6 14/04/2011: controls.ini is located at: D:\Games\GameEx\data\controls.ini
11:44:58.6 14/04/2011: History.dat is located at: D:\Games\GameEx\DATA\history.dat
11:44:58.6 14/04/2011: nplayers.ini is located at: D:\Games\GameEx\DATA\nplayers.ini
11:44:58.6 14/04/2011: command.dat is located at: D:\Games\GameEx\DATA\command.dat
11:44:58.6 14/04/2011: MAMEinfo.dat is located at: D:\Games\GameEx\DATA\mameinfo.dat
11:44:58.6 14/04/2011: Loading Controls.ini map file
11:44:58.7 14/04/2011: Snap Path is: D:\Games\Assets\MAME\Snap
11:44:58.7 14/04/2011: AVI Snap Path is: D:\Games\Assets\MAME\Avisnap
11:44:58.7 14/04/2011: Flyer Path is: D:\Games\Assets\MAME\Advert
11:44:58.7 14/04/2011: Cabinet Path is: D:\Games\Assets\MAME\Cabinet
11:44:58.7 14/04/2011: Cabinet 3D Path: Not Found
11:44:58.7 14/04/2011: Title Path is: D:\Games\Assets\MAME\Title
11:44:58.7 14/04/2011: PCB Path is: D:\Games\Assets\MAME\PCB
11:44:58.7 14/04/2011: Artwork Preview Path is: D:\Games\Assets\MAME\Artwork
11:44:58.7 14/04/2011: Panel Path is: D:\Games\Assets\MAME\CP
11:44:58.7 14/04/2011: Manual Path: Not Found
11:44:58.7 14/04/2011: Icon Path is: D:\Games\Assets\MAME\Icon
11:44:58.7 14/04/2011: Marquee Path is: D:\Games\Assets\MAME\Marquee
11:44:58.7 14/04/2011: Loading Custom Emulators
11:44:58.7 14/04/2011: Using 2D Animations
11:44:58.7 14/04/2011: Using General Font: Trebuchet MS
11:44:58.7 14/04/2011: Using Title Font: Trebuchet MS
11:44:58.8 14/04/2011: Initialising Direct3D
11:44:58.8 14/04/2011: Applying GameEx is Loading Image
11:44:58.8 14/04/2011: Setting Resolution to 1280x720 32 bit color
11:44:58.8 14/04/2011: Creating Surfaces
11:44:59.1 14/04/2011: Creating Primary Surface - Full Screen Mode
11:44:59.1 14/04/2011: Creating Back Buffer
11:44:59.1 14/04/2011: Loading graphic Surfaces
11:44:59.1 14/04/2011: Display is running at: 1280x720 32bit color, 50hz
11:44:59.2 14/04/2011: Creating Surfaces Misc and Dialogs
11:44:59.3 14/04/2011: Creating Surfaces Volume
11:44:59.3 14/04/2011: Creating Surfaces Arrows
11:44:59.3 14/04/2011: Creating Surfaces GameEXlogo Text
11:44:59.3 14/04/2011: Creating Surfaces Toolbar
11:44:59.4 14/04/2011: Creating Surfaces Backgrounds
11:44:59.4 14/04/2011: Creating Surfaces Toolbar Controls
11:44:59.4 14/04/2011: Creating Surfaces GameEx Logo
11:44:59.4 14/04/2011: Creating Surface Unselected
11:44:59.4 14/04/2011: Creating Surfaces Home & Exit
11:44:59.5 14/04/2011: Creating Surfaces Snaps
11:44:59.5 14/04/2011: Creating Surfaces Menu and List Bars
11:44:59.8 14/04/2011: Creating Fonts
11:44:59.8 14/04/2011: Creating Game Font
11:44:59.9 14/04/2011: Creating Game Font Faded
11:45:00.0 14/04/2011: Creating Title Font
11:45:00.0 14/04/2011: Restoring Title Font From Cache
11:45:00.2 14/04/2011: Creating Menu Font
11:45:00.3 14/04/2011: Creating Font Black
11:45:00.3 14/04/2011: Creating Font Black Small
11:45:00.4 14/04/2011: Fonts Created Succesfully
11:45:00.4 14/04/2011: 3MB Video Memory Used
11:45:00.4 14/04/2011: Initialising Bass Audio Library
11:45:00.4 14/04/2011: Creating instance of global keyboard hook
11:45:00.7 14/04/2011: Attempting to load game list
11:45:00.9 14/04/2011: Applying Language/Text
11:45:00.9 14/04/2011: Text/Language: English
11:45:01.0 14/04/2011: MAME CMD options: -nowindow -joy -skip_gameinfo
11:45:01.0 14/04/2011: Loading last used Game List
11:45:01.0 14/04/2011: Cannot Load Play List. Check Path and filename
11:45:01.0 14/04/2011: Creating DirectSound Device
11:45:01.0 14/04/2011: Trying: Primary Sound Driver
11:45:01.0 14/04/2011: Loading Sound Files
11:45:01.1 14/04/2011: DirectSound Device Created Successfully
11:45:01.1 14/04/2011: Initialising DirectInput for Gamepad support
11:45:01.2 14/04/2011: Unable to create a joystick device
11:45:01.2 14/04/2011: Initializing MCE Remote
11:45:01.2 14/04/2011: Initialization OK! Starting GameEx!
11:45:01.2 14/04/2011: Testing Main Loop Once: Processing Frame
11:45:01.5 14/04/2011: Testing Main Loop Once: Main Loop ran successfully
11:45:08.4 14/04/2011: Restoring Cached ICONS from File
11:45:10.4 14/04/2011: Failed Opening Video: d:\games\assets\mame\avisnap\yumefuda.avi
11:45:11.6 14/04/2011: Failed Opening Video: d:\games\assets\mame\avisnap\005.avi
11:45:13.0 14/04/2011: Failed Opening Video: d:\games\assets\mame\avisnap\gtmr.avi
11:45:13.8 14/04/2011: Failed Opening Video: d:\games\assets\mame\avisnap\1942.avi
11:45:24.1 14/04/2011: Exiting GameEx!
11:45:24.1 14/04/2011: Saving Settings
11:45:25.8 14/04/2011: Disposing Plugins
11:45:25.8 14/04/2011: Closing database connection
11:45:25.8 14/04/2011: Checking for applications to Launch On Exit
11:45:25.8 14/04/2011: Media Center was not open when starting GameEx, so not launching
Please provide a copy o f your gameex.ini file (will need to open in Notepad and Save As txt file to post to the forum) Don't do anything as drastic as reinstalling Windows unless you are having other issues outside of GameEx regarding.
Ok Ive got it working.
Im not exactly sure how though!
Here's what I did:
Originally I had FFDshow installed and all videos worked prefectly in WMC and WMP etc but none of the avisnaps were showing up in GameEx.
I unistalled FFDshow and installed the Shark Codec pack but still no avisnaps in GameEx.
Last night I went to watch an MKV movie and it wouldnt play so I fiddled about with the settings in the Shark Codec pack and also noticed that my Haali splitter was unistalled (must have been uninstalled when removing FFDshow I guess).
So, I reinstalled Haali and now everything works perfectly.
Strange, becuase I didnt think that the emumovies avisnaps needed a matroska splitter, but then again I did fiddle about a bit with the settings in shark so that may have done it, I dont know!
thanks for all your help and suggestions guys! :)
You're welcome Traffik! We'll mark this as resolved then and Welcome to the Forum!
If you're going to install the Shark codec pack we recommend you remove ALL codecs on your system before installing it. The Shark codec pack includes the Haali Splitter so there must have been some conflict with a previous install. Glad you got it sorted in the end! B)
