Different sound volumes with microphones...
Hello, me again...
Yesterday I made some tests with the microphone and falled into a problem, where I am not sure if there exists a solution :
On our parties, girls love to sing caraoke, so I installed 2 microphones for singing their favorite songs, BUT :
Problem is the sound volume :
1. The microphones do have their own sound volume (which is set to maximum)
2. You can only change the MASTER sound volume in gameex
3. On my boxes, I also have a separate volume controler
So, what we would like to have is that the sound volume of the songs must be lower than the microphone sound volume so that we can hear the voices, but how to accomplish that ?? I can only influence the master sound volume in gameex, meaning that BOTH volumes (Sound and microphone) will get louder or vise versa.
The solution would be that in gameex, I should only be able to control the sound volume of the SONG an NOT the master volume. Is there a chance to accomplish that ?
Bye and greetz !
André
I have not used the Karaoke app with GameEx so cannot speak to it entirely. I would think that there may be some settings you will need to adjust with your sound card as well. By default, Windows tends to behave as the master to all controls and will slide them all unless you intervene. You may find yourself limited by your PC/Windows if you are using onboard (on the motherboard) sound vs. an add-on soundcard (Creative, etc.).
Isn't there a way to configure the Karaoke plugin in the Programs menu in Windows? I have it installed and I'm pretty sure it's in there but admittedly I don't do karaoke (trust me it's better that way).
I trust ya! :lol: To be honest I don't have much knowledge of it as I do not use that feature myself and the neighbors with dogs thank me for it! I haven't seen much talk about it in the forums, but maybe Tom or someone that has can shed a little light our way.
Hey guies, dont misunderstand me, I do NOT use the caraoke function of gameex...I start a normal DVD, which itself contain smusic videos with the text and then the girls are doing the caraoke... :)
Surrrrre pal! ;)
Nothing wrong with it. There's a few of us here that are actually into karaoke. I myself use to KJ at my local bar. It's fun.
I can't carry a tune in a bucket. You guys have fun! Not that there is anything wrong with it... B)
