Best way to Setup CPS1, 2,as Seperate Gamelist on GaeEX
I'm looking for the best way to setup FB Alpha but I would like to separate the CPS 1, 2 on the gameEX menu. I will use CPS3 Emulator for CPS3 games. Any tips?
Is there any way to View Arcade Emulations under the main START page of GameEX? I would like to see MAME--->CPS 1/2--->Zinc--->SeGA Model---->Daphne--->Then Emulated Games such as consoles?
The first thought that comes to mind is to setup the emulator twice in the emulator list. You can then have it installed on two distinct paths (i.e. C:\emulators\CPS1\FB Alpha\...) with the ROMs under the ROMs directory for the CPS1 and 2 games respectively and the same for any snaps, etc.
Another option, although I am not sure if it would work, but worth a shot, is to have one emulator path, but ROMs, snaps, etc under a different path (say C:\emulators\FB Alpha\CPS1ROMS..., C:\emulators\FB Alpha\CPS1Snaps... C:\emulators\FB Alpha\CPS2ROMS..., C:\emulators\FB Alpha\CPS2Snaps... ).
Either way, GameEx will be launching the emulators usig the paths you define within it for the ROMs, Snaps, Video Snaps, Artwork, etc.
As for having the emus on the start page, I am not certain you can do it that way but I can't speak to that from experience.
I use Winkawaks for all CPS1, CPS2 and Neo Geo games and I use Nebula's CPS3 emulator for CPS3 games. Both I have set up as emulators. They can be separate if you like too.
Thanks Draco... I was sorta thinking the same but wanted to see who has it setup and what their config is....
Celly - now I was thinking maybe I'll just use FB Alpha for CPS1,2/Neo-Geo and use that map file that comes with GameEX. That mapfile lists 387 games total...now how many games do you view with WinKawaks? For all them 3 Emus? I just didn't want any games missing that is not on that list.
Does FB Alpha play BatRider, I tried to play it and it said not supported?
