What method does everyone use for GameEx on startup of the computer? I did the most basic method of adding it to the Startup folder but when that happens, GameEx loads and then minimizes, and needs to be alt+ctrl+deleted out.
Any ideas?
Any ideas?
well, that should work fine. People taht do not place a shortcut in the startup folder SHELL gameex, so explorer does not load. Is gameex running at the same resolution your desktop is? Perhaps there is a resolution switching issue, or a try app is stealing focus.
yeah, i was just about to reference that thread. windows 7 (or vista) has a nasty habit of over complicating the desktop. best to just take the desktop rendering out of the equation.
I had the same problem and fixed it by using a free program called Startup Delayer. Delay GameEx's startup by 30 seconds or so and it may solve the issue.
