getting this error on startup in version 4.89. Will upgrading fix this? (still unable to download after clearing cahe so will try on another computer tomorrow)
23:46:34.9  30/08/2005:  GameEx: Version 4.89: Starting Log
23:46:34.9  30/08/2005:  Operating System Platform: Win32NT
23:46:34.9  30/08/2005:  Operating System Name: Windows XP
23:46:34.9  30/08/2005:  Operating System Version: 5.1.2600
23:46:34.9  30/08/2005:  Checking Registration
23:46:34.9  30/08/2005:  Running Randomize()
23:46:34.9  30/08/2005:  Running Misc startup tasks
23:46:34.9  30/08/2005:  Setting Menu types
23:46:34.9  30/08/2005:  Opening Configuration File
23:46:34.9  30/08/2005:  Getting Configuration Values
23:46:34.9  30/08/2005:  Using Theme: Default - Default
23:46:34.9  30/08/2005:  Checking for alternate Image Directory for Theme: Default - Default
23:46:35.0  30/08/2005:  Text/Language: English
23:46:35.0  30/08/2005:  Applying Language/Text
23:46:35.1  30/08/2005:  Creating Scancodes.txt (List of DirectInput scan codes)
23:46:35.1  30/08/2005:  Snap Delay set to: 1
23:46:35.1  30/08/2005:  Is Media Center running?
23:46:35.1  30/08/2005:  Check Media Center Exit/Start Mode
23:46:35.1  30/08/2005:  Media Center Mode 2
23:46:35.1  30/08/2005:  Checking for applications to Launch On Startup
23:46:35.1  30/08/2005:  Get other settings
23:46:35.1  30/08/2005:  Using 3D Animations
23:46:35.2  30/08/2005:  SlikStik support enabled
23:46:35.2  30/08/2005:  Using DirectInput for keyboard input
23:46:35.2  30/08/2005:  Launching HideOS.exe
23:46:36.8  30/08/2005:  Hiding Taskbar
23:46:37.3  30/08/2005:  Start work for Form
23:46:37.3  30/08/2005:  Getting Original Screen Size
23:46:37.3  30/08/2005:  Loading ICON
23:46:37.3  30/08/2005:  Initializing Component
23:46:37.5  30/08/2005:  Initialising Bass Audio Library
23:46:41.6  30/08/2005:  ERRORS DETECTED: EXITING
You should be able to download now, but no that error has no relation to fixes in the latest version. Check your sound card, and drivers are good, and enabled. This is purely to do with you sound card, as far as I can see.
[it would still be a good idea to download the latest version BTW]
I get the same error as the user above. As soon as I can get it working again. I will donate :)
  DannyH said:
hmm its an onboard sound card.
I just upgraded to the latest version and all is working without issue now.
Cheers mate
I only get the crash when i try to update my rom list.
