As the title said, i would like to download a previous version, namely 4.86 or .87 can anyone point me to the archived downloads?
I dont personally keep archived downloads, but hey if theres something you don't like about the latest version just let me know, and Ill certainly try and address. That's pretty much how the project works, and most people (I think) are happy with that.
I'm keeping backups of them from 4.87 onwards now.
I dont really see the need to do it, as I address bugs almost daily sometimes, and implement practically everything that is asked for. It realy should not be required.
I can't stop anyone doing that, but please understand, I will only support the latest version.
thanks,
Tom.
Its alright i was worried because the latest version corrupted my Snaps somehow.
Its all good now, I just recreated them
I very much doubt it was GameEx that caused the corruption. It uses the .net framework which is more secure, stable and creates less bugs than applications coded without. GameEx does nothing low level with files or folders. Unless possibly your talking about Video snaps.
I cant think of anyway how Gameex directly could do that. You should probably check out other things on your PC.
You are welcome to your conclusion though, and sharing you thoughts.
Thanks.
Tom.
