Ok....so whenever I try to load up a Visual Pinball table all that happens is the screen goes black and nothing seems to load except for the pinball score screen. Tables do run fine from the launcher and if I try to the run last script they manage to run (with the error). Also, it usually shows the desktop even though show desktop is off. Either way I get an error message with the header AutoIt Error that says,
"Line-1:
Error: Unable to execute the external program.
The system cannot find the file specified."
below is my log
14:09:57.4 4/18/2008: GameEx: Version 9.19: Starting Log
14:09:57.4 4/18/2008: Operating System Platform: Win32NT
14:09:57.5 4/18/2008: Operating System Name: Windows XP
14:09:57.5 4/18/2008: Operating System Version: 5.1.2600
14:09:57.5 4/18/2008: Checking for versions of .net Framework installed
14:09:57.5 4/18/2008: .net Framework 1.0 Installed
14:09:57.5 4/18/2008: .net Framework 2.0 Installed
14:09:57.5 4/18/2008: Intel® Pentium® 4 CPU 2.80GHz, 511MB
14:09:57.5 4/18/2008: 2.79Ghz - 2 Cores or CPU's
14:09:57.5 4/18/2008: Running Randomize()
14:09:57.5 4/18/2008: Loading PlugIns
14:09:57.6 4/18/2008: Checking for applications to Launch On Startup
14:09:57.6 4/18/2008: Running Misc startup tasks
14:09:57.7 4/18/2008: Setting Menu types
14:09:57.7 4/18/2008: Opening Configuration File
14:09:57.7 4/18/2008: Getting Configuration Values
14:09:57.7 4/18/2008: Using Theme: Default - Awesome Theme
14:09:57.7 4/18/2008: Checking for alternate Image Directory for Theme: Default - Awesome Theme
14:09:57.7 4/18/2008: Launching HideOS.exe
14:09:57.7 4/18/2008: Initialising Video/MNG DLL's
14:09:57.7 4/18/2008: Hiding Taskbar
14:09:57.8 4/18/2008: Is Media Center running?
14:09:57.8 4/18/2008: Checking/Creating LCD Registry values
14:09:57.8 4/18/2008: Check Media Center Exit/Start Mode
14:09:57.8 4/18/2008: Media Center Mode 2
14:09:57.8 4/18/2008: Video previews on. Warning: Only recommended on modern systems
14:09:57.9 4/18/2008: Snap Delay set to: 2
14:09:57.9 4/18/2008: Get other settings
14:09:57.9 4/18/2008: Reading MAME hall of fame
14:09:58.0 4/18/2008: Set: Find emulator artwork on best match basis
14:09:58.1 4/18/2008: Start work for Form
14:09:58.1 4/18/2008: Getting Original Screen Size
14:09:58.2 4/18/2008: Opening Database Connection
14:09:58.6 4/18/2008: Initializing Component
14:09:58.7 4/18/2008: Retrieving resolution setting
14:09:58.7 4/18/2008: Creating Radio Station Genres
14:09:58.8 4/18/2008: Succesfully created station genres
14:09:58.8 4/18/2008: Initialising Windows Media Player Component
14:09:58.9 4/18/2008: MAME Path is: F:\Mame
14:09:58.9 4/18/2008: daphne Path is: F:\Daphne
14:09:58.9 4/18/2008: daphne EXE file is: Daphne.exe
14:09:58.9 4/18/2008: Use daphne on. Daphne.exe will launch games
14:09:58.9 4/18/2008: MAME EXE file is: mame.exe
14:09:58.9 4/18/2008: ROM Path is: F:\Mame\roms
14:09:58.9 4/18/2008: Catver.ini is located at: C:\Program Files\GameEx\DATA\catver.ini
14:09:58.9 4/18/2008: controls.ini is located at: C:\Program Files\GameEx\data\controls.ini
14:09:58.9 4/18/2008: History.dat is located at: C:\Program Files\GameEx\DATA\history.dat
14:09:58.9 4/18/2008: nplayers.ini is located at: C:\Program Files\GameEx\DATA\nplayers.ini
14:09:58.9 4/18/2008: MAMEinfo.dat is located at: C:\Program Files\GameEx\DATA\mameinfo.dat
14:09:59.0 4/18/2008: Loading Controls.ini map file
14:09:59.0 4/18/2008: Snap Path is: F:\Mame\mame Extras\snap
14:09:59.0 4/18/2008: AVI Snap Path is: F:\Mame\previews
14:09:59.0 4/18/2008: Flyer Path is: F:\Mame\mame Extras\flyers
14:09:59.0 4/18/2008: Cabinet Path is: F:\Mame\mame Extras\cabinets
14:09:59.0 4/18/2008: Title Path is: F:\Mame\mame Extras\titles
14:09:59.0 4/18/2008: PCB Path: Not Found
14:09:59.0 4/18/2008: Artwork Preview Path is: F:\Mame\mame Extras\artwork
14:09:59.0 4/18/2008: Panel Path is: F:\Mame\mame Extras\cpanel
14:09:59.0 4/18/2008: Manual Path: Not Found
14:09:59.0 4/18/2008: Icon Path is: F:\Mame\mame Extras\mamuicons
14:09:59.0 4/18/2008: Marquee Path is: F:\Mame\mame Extras\marquees
14:09:59.0 4/18/2008: Loading Custom Emulators
14:09:59.0 4/18/2008: Loading Emulator 2: Atari Jaguar
14:09:59.1 4/18/2008: Loading Emulator 3: Atari Lynx
14:09:59.2 4/18/2008: Loading Emulator 5: Neo-Geo Pocket
14:09:59.2 4/18/2008: Loading Emulator 6: Nintendo 64
14:09:59.3 4/18/2008: Loading Emulator 7: Nintendo Entertainment System
14:09:59.4 4/18/2008: Loading Emulator 8: Nintendo GameBoy
14:09:59.5 4/18/2008: Loading Emulator 9: Nintendo GameBoy Advance
14:09:59.5 4/18/2008: Loading Emulator 10: Nintendo GameBoy Color
14:09:59.6 4/18/2008: Loading Emulator 12: Pinball Games
14:09:59.7 4/18/2008: Loading Emulator 13: Sega 32x
14:09:59.8 4/18/2008: Loading Emulator 14: Sega CD
14:09:59.8 4/18/2008: Loading Emulator 15: Sega Game Gear
14:09:59.9 4/18/2008: Loading Emulator 16: Sega Genesis
14:10:00.0 4/18/2008: Loading Emulator 17: Sega Master System
14:10:00.1 4/18/2008: Loading Emulator 18: Super Nintendo
14:10:00.1 4/18/2008: Loading Emulator 20: TurboGrafx 16
14:10:00.2 4/18/2008: Loading Emulator 21: [Pinball] Visual Pinball
14:10:00.7 4/18/2008: Using 2D Animations
14:10:00.7 4/18/2008: Using General Font: Trebuchet MS
14:10:00.7 4/18/2008: Using Title Font: Trebuchet MS
14:10:00.7 4/18/2008: Attempting to load game list
14:10:01.6 4/18/2008: Initialising DirectDraw
14:10:01.6 4/18/2008: Applying GameEx is Loading Image
14:10:01.7 4/18/2008: Creating DirectDraw Device
14:10:01.7 4/18/2008: Using Device: NVIDIA GeForce FX Go5200
14:10:01.8 4/18/2008: 59mb video memory available
14:10:01.8 4/18/2008: Setting Resolution to 800x600 32 bit color
14:10:02.9 4/18/2008: Creating DirectDraw Surfaces
14:10:02.9 4/18/2008: Creating Primary Surface - Full Screen Mode
14:10:03.2 4/18/2008: Creating Back Buffer
14:10:03.2 4/18/2008: Loading graphic Surfaces
14:10:03.3 4/18/2008: Display is running at: 800x600 32bit color, 60hz
14:10:03.4 4/18/2008: Creating Surfaces Misc and Dialogs
14:10:03.5 4/18/2008: Creating Surfaces Volume
14:10:03.5 4/18/2008: Creating Surfaces Arrows
14:10:03.5 4/18/2008: Creating Surfaces GameEXlogo Text
14:10:03.5 4/18/2008: Creating Surfaces Toolbar
14:10:03.6 4/18/2008: Creating Surfaces Backgrounds
14:10:03.8 4/18/2008: Creating Surfaces Toolbar Controls
14:10:03.9 4/18/2008: Creating Surfaces GameEx Logo
14:10:03.9 4/18/2008: Creating Surface Unselected
14:10:03.9 4/18/2008: Creating Surfaces Home & Exit
14:10:03.9 4/18/2008: Creating Surfaces Snaps
14:10:03.9 4/18/2008: Creating Surfaces Menu and List Bars
14:10:04.2 4/18/2008: Creating Fonts
14:10:04.2 4/18/2008: Creating Game Font
14:10:04.6 4/18/2008: Creating Menu Font
14:10:04.7 4/18/2008: Restoring Menu Font From Cache
14:10:04.7 4/18/2008: Creating Font Black
14:10:04.8 4/18/2008: Creating Font Black Small
14:10:04.9 4/18/2008: Creating Game Font Faded
14:10:05.5 4/18/2008: Creating Title Font
14:10:05.5 4/18/2008: Restoring Title Font From Cache
14:10:05.6 4/18/2008: Fonts Created Succesfully
14:10:05.6 4/18/2008: 19mb video memory left available
14:10:05.6 4/18/2008: Creating instance of global keyboard hook
14:10:05.6 4/18/2008: Text/Language: English
14:10:05.6 4/18/2008: Applying Language/Text
14:10:05.7 4/18/2008: Initialising Bass Audio Library
14:10:05.9 4/18/2008: MAME CMD options: -triplebuffer -nowindow -joy -skip_gameinfo
14:10:05.9 4/18/2008: Loading last used Game List
14:10:06.0 4/18/2008: Setting Music Volume
14:10:06.0 4/18/2008: Creating DirectSound Device
14:10:06.0 4/18/2008: Trying: Primary Sound Driver
14:10:06.0 4/18/2008: Loading Sound Files
14:10:06.0 4/18/2008: DirectSound Device Created Successfully
14:10:06.0 4/18/2008: Creating ICONS
14:10:06.0 4/18/2008: Recreating ICONS
14:10:07.4 4/18/2008: Initialising DirectInput for Gamepad support
14:10:07.4 4/18/2008: Unable to create a joystick device
14:10:07.4 4/18/2008: Playing intro sound file
14:10:07.4 4/18/2008: Initializing MCE Remote
14:10:07.5 4/18/2008: Initialization OK! Starting GameEx!
14:10:07.5 4/18/2008: Testing Main Loop Once: Processing Frame
14:10:08.0 4/18/2008: Testing Main Loop Once: Main Loop ran successfully
14:10:25.0 4/18/2008: Validating: Emulator_2: Custom Background: F:\Jaguar\Videos
14:10:25.0 4/18/2008: Warning: Emulator_2: Custom Background Does not exist
14:10:25.0 4/18/2008: Validating: Emulator_2: Snap Path: F:\Jaguar\Videos
14:10:25.0 4/18/2008: Validating: Emulator_2: Control Panel Path:
14:10:25.0 4/18/2008: Warning: Emulator_2: Control Panel Path Does not exist
14:10:25.0 4/18/2008: Validating: Emulator_2: Instructions Path:
14:10:25.0 4/18/2008: Warning: Emulator_2: Instructions Path Does not exist
14:10:25.0 4/18/2008: Validating: Emulator_2: Database: [Console] Atari Jaguar
14:10:25.0 4/18/2008: Validating: Emulator_2: Title Snap Path:
14:10:25.0 4/18/2008: Warning: Emulator_2: Title Snap Path Does not exist
14:10:25.0 4/18/2008: Validating: Emulator_2: Box Art Path:
14:10:25.0 4/18/2008: Warning: Emulator_2: Box Art Path Does not exist
14:10:25.0 4/18/2008: Validating: Emulator_2: Cart Art Path:
14:10:25.0 4/18/2008: Warning: Emulator_2: Cart Art Path Does not exist
14:10:25.0 4/18/2008: Validating: Emulator_2: Manual Path: C:\Emulation\Assets\Console\Atari Jaguar\Manuals
14:10:25.0 4/18/2008: Warning: Emulator_2: Manual Path Does not exist
14:10:25.0 4/18/2008: Validating: Emulator_3: Custom Background: F:\Lynxx\videos
14:10:25.0 4/18/2008: Validating: Emulator_3: Snap Path: F:\Lynxx\videos
14:10:25.0 4/18/2008: Validating: Emulator_3: Control Panel Path: C:\Emulation\Assets\HandHeld\Atari Lynx\Controls
14:10:25.0 4/18/2008: Warning: Emulator_3: Control Panel Path Does not exist
14:10:25.0 4/18/2008: Validating: Emulator_3: Instructions Path:
14:10:25.0 4/18/2008: Warning: Emulator_3: Instructions Path Does not exist
14:10:25.0 4/18/2008: Validating: Emulator_3: Database: [Handheld] Atari Lynx
14:10:25.0 4/18/2008: Validating: Emulator_3: Title Snap Path:
14:10:25.0 4/18/2008: Warning: Emulator_3: Title Snap Path Does not exist
14:10:25.0 4/18/2008: Validating: Emulator_3: Box Art Path:
14:10:25.0 4/18/2008: Warning: Emulator_3: Box Art Path Does not exist
14:10:25.0 4/18/2008: Validating: Emulator_3: Cart Art Path:
14:10:25.0 4/18/2008: Warning: Emulator_3: Cart Art Path Does not exist
14:10:25.0 4/18/2008: Validating: Emulator_3: Manual Path:
14:10:25.0 4/18/2008: Warning: Emulator_3: Manual Path Does not exist
14:10:25.0 4/18/2008: Validating: Emulator_5: Custom Background: C:\Emulation\Assets\HandHeld\SNK Neo-Geo Pocket\Snaps
14:10:25.0 4/18/2008: Warning: Emulator_5: Custom Background Does not exist
14:10:25.0 4/18/2008: Validating: Emulator_5: Snap Path: C:\Emulation\Assets\HandHeld\SNK Neo-Geo Pocket\Snaps
14:10:25.0 4/18/2008: Warning: Emulator_5: Snap Path Does not exist
14:10:25.0 4/18/2008: Validating: Emulator_5: Control Panel Path: C:\Emulation\Assets\HandHeld\SNK Neo-Geo Pocket\Controls
14:10:25.0 4/18/2008: Warning: Emulator_5: Control Panel Path Does not exist
14:10:25.0 4/18/2008: Validating: Emulator_5: Instructions Path:
14:10:25.0 4/18/2008: Warning: Emulator_5: Instructions Path Does not exist
14:10:25.0 4/18/2008: Validating: Emulator_5: Database: [Handheld] SNK Neo-Geo Pocket
14:10:25.0 4/18/2008: Validating: Emulator_5: Title Snap Path: C:\Emulation\Assets\HandHeld\SNK Neo-Geo Pocket\Titles
14:10:25.0 4/18/2008: Warning: Emulator_5: Title Snap Path Does not exist
14:10:25.0 4/18/2008: Validating: Emulator_5: Box Art Path: C:\Emulation\Assets\HandHeld\SNK Neo-Geo Pocket\Boxes
14:10:25.0 4/18/2008: Warning: Emulator_5: Box Art Path Does not exist
14:10:25.0 4/18/2008: Validating: Emulator_5: Cart Art Path: C:\Emulation\Assets\HandHeld\SNK Neo-Geo Pocket\Cartridges
14:10:25.0 4/18/2008: Warning: Emulator_5: Cart Art Path Does not exist
14:10:25.0 4/18/2008: Validating: Emulator_5: Manual Path: C:\Emulation\Assets\HandHeld\SNK Neo-Geo Pocket\Manuals
14:10:25.0 4/18/2008: Warning: Emulator_5: Manual Path Does not exist
14:10:25.1 4/18/2008: Validating: Emulator_6: Custom Background: F:\N64\Videos
14:10:25.1 4/18/2008: Validating: Emulator_6: Snap Path: F:\N64\Videos
14:10:25.1 4/18/2008: Validating: Emulator_6: Control Panel Path:
14:10:25.1 4/18/2008: Warning: Emulator_6: Control Panel Path Does not exist
14:10:25.1 4/18/2008: Validating: Emulator_6: Instructions Path:
14:10:25.1 4/18/2008: Warning: Emulator_6: Instructions Path Does not exist
14:10:25.1 4/18/2008: Validating: Emulator_6: Database: [Console] Nintendo N64
14:10:25.1 4/18/2008: Validating: Emulator_6: Title Snap Path: F:\N64\Roms\snaps
14:10:25.1 4/18/2008: Validating: Emulator_6: Box Art Path:
14:10:25.1 4/18/2008: Warning: Emulator_6: Box Art Path Does not exist
14:10:25.1 4/18/2008: Validating: Emulator_6: Cart Art Path:
14:10:25.1 4/18/2008: Warning: Emulator_6: Cart Art Path Does not exist
14:10:25.1 4/18/2008: Validating: Emulator_6: Manual Path: F:\N64\Manuals
14:10:25.1 4/18/2008: Loading OfflineList Dat File for emulator: 6
14:10:25.1 4/18/2008: Cannot Find Offline List Dat File
14:10:25.1 4/18/2008: Validating: Emulator_7: Custom Background: F:\NES\Videos
14:10:25.1 4/18/2008: Validating: Emulator_7: Snap Path: F:\NES\Videos
14:10:25.1 4/18/2008: Validating: Emulator_7: Control Panel Path: C:\Emulation\Assets\Console\Nintendo NES\Controls
14:10:25.1 4/18/2008: Warning: Emulator_7: Control Panel Path Does not exist
14:10:25.1 4/18/2008: Validating: Emulator_7: Instructions Path:
14:10:25.1 4/18/2008: Warning: Emulator_7: Instructions Path Does not exist
14:10:25.1 4/18/2008: Validating: Emulator_7: Database: [Console] Nintendo NES
14:10:25.1 4/18/2008: Validating: Emulator_7: Title Snap Path: F:\NES\screenshots\snaps
14:10:25.1 4/18/2008: Validating: Emulator_7: Box Art Path: F:\NES\screenshots\BoxartUSA
14:10:25.1 4/18/2008: Validating: Emulator_7: Cart Art Path:
14:10:25.1 4/18/2008: Warning: Emulator_7: Cart Art Path Does not exist
14:10:25.1 4/18/2008: Validating: Emulator_7: Manual Path:
14:10:25.1 4/18/2008: Warning: Emulator_7: Manual Path Does not exist
14:10:25.1 4/18/2008: Validating: Emulator_8: Custom Background: F:\Gameboy\black\snaps
14:10:25.1 4/18/2008: Validating: Emulator_8: Snap Path: F:\Gameboy\black\snaps
14:10:25.1 4/18/2008: Validating: Emulator_8: Control Panel Path: C:\Emulation\Assets\HandHeld\Nintendo GameBoy\Controls
14:10:25.1 4/18/2008: Warning: Emulator_8: Control Panel Path Does not exist
14:10:25.1 4/18/2008: Validating: Emulator_8: Instructions Path:
14:10:25.1 4/18/2008: Warning: Emulator_8: Instructions Path Does not exist
14:10:25.1 4/18/2008: Validating: Emulator_8: Database:
14:10:25.1 4/18/2008: Warning: Emulator_8: Database Does not exist
14:10:25.1 4/18/2008: Validating: Emulator_8: Title Snap Path:
14:10:25.1 4/18/2008: Warning: Emulator_8: Title Snap Path Does not exist
14:10:25.1 4/18/2008: Validating: Emulator_8: Box Art Path:
14:10:25.1 4/18/2008: Warning: Emulator_8: Box Art Path Does not exist
14:10:25.1 4/18/2008: Validating: Emulator_8: Cart Art Path:
14:10:25.1 4/18/2008: Warning: Emulator_8: Cart Art Path Does not exist
14:10:25.1 4/18/2008: Validating: Emulator_8: Manual Path: F:\Gameboy\black\manuals
14:10:25.1 4/18/2008: Validating: Emulator_9: Custom Background: F:\GBA\Boxes
14:10:25.1 4/18/2008: Validating: Emulator_9: Snap Path: F:\GBA\Boxes
14:10:25.1 4/18/2008: Validating: Emulator_9: Control Panel Path: C:\Emulation\Assets\HandHeld\Nintendo GameBoy Advance\Controls
14:10:25.1 4/18/2008: Warning: Emulator_9: Control Panel Path Does not exist
14:10:25.1 4/18/2008: Validating: Emulator_9: Instructions Path:
14:10:25.1 4/18/2008: Warning: Emulator_9: Instructions Path Does not exist
14:10:25.1 4/18/2008: Validating: Emulator_9: Database:
14:10:25.1 4/18/2008: Warning: Emulator_9: Database Does not exist
14:10:25.1 4/18/2008: Validating: Emulator_9: Title Snap Path:
14:10:25.1 4/18/2008: Warning: Emulator_9: Title Snap Path Does not exist
14:10:25.1 4/18/2008: Validating: Emulator_9: Box Art Path: F:\GBA\Boxes
14:10:25.1 4/18/2008: Validating: Emulator_9: Cart Art Path:
14:10:25.1 4/18/2008: Warning: Emulator_9: Cart Art Path Does not exist
14:10:25.1 4/18/2008: Validating: Emulator_9: Manual Path: C:\Emulation\Assets\HandHeld\Nintendo GameBoy Advance\Manuals
14:10:25.1 4/18/2008: Warning: Emulator_9: Manual Path Does not exist
14:10:25.1 4/18/2008: Validating: Emulator_10: Custom Background: F:\Gameboy\GBColor\Snaps
14:10:25.2 4/18/2008: Validating: Emulator_10: Snap Path: F:\Gameboy\GBColor\Snaps
14:10:25.2 4/18/2008: Validating: Emulator_10: Control Panel Path: C:\Emulation\Assets\HandHeld\Nintendo GameBoy Color\Controls
14:10:25.2 4/18/2008: Warning: Emulator_10: Control Panel Path Does not exist
14:10:25.2 4/18/2008: Validating: Emulator_10: Instructions Path:
14:10:25.2 4/18/2008: Warning: Emulator_10: Instructions Path Does not exist
14:10:25.2 4/18/2008: Validating: Emulator_10: Database:
14:10:25.2 4/18/2008: Warning: Emulator_10: Database Does not exist
14:10:25.2 4/18/2008: Validating: Emulator_10: Title Snap Path:
14:10:25.2 4/18/2008: Warning: Emulator_10: Title Snap Path Does not exist
14:10:25.2 4/18/2008: Validating: Emulator_10: Box Art Path:
14:10:25.2 4/18/2008: Warning: Emulator_10: Box Art Path Does not exist
14:10:25.2 4/18/2008: Validating: Emulator_10: Cart Art Path:
14:10:25.2 4/18/2008: Warning: Emulator_10: Cart Art Path Does not exist
14:10:25.2 4/18/2008: Validating: Emulator_10: Manual Path: F:\Gameboy\GBColor\Manuals
14:10:25.2 4/18/2008: Validating: Emulator_12: Custom Background:
14:10:25.2 4/18/2008: Warning: Emulator_12: Custom Background Does not exist
14:10:25.2 4/18/2008: Validating: Emulator_12: Snap Path:
14:10:25.2 4/18/2008: Warning: Emulator_12: Snap Path Does not exist
14:10:25.2 4/18/2008: Validating: Emulator_12: Control Panel Path:
14:10:25.2 4/18/2008: Warning: Emulator_12: Control Panel Path Does not exist
14:10:25.2 4/18/2008: Validating: Emulator_12: Instructions Path:
14:10:25.2 4/18/2008: Warning: Emulator_12: Instructions Path Does not exist
14:10:25.2 4/18/2008: Validating: Emulator_12: Database: VISUALPINBALL
14:10:25.2 4/18/2008: Validating: Emulator_12: Title Snap Path:
14:10:25.2 4/18/2008: Warning: Emulator_12: Title Snap Path Does not exist
14:10:25.2 4/18/2008: Validating: Emulator_12: Box Art Path:
14:10:25.2 4/18/2008: Warning: Emulator_12: Box Art Path Does not exist
14:10:25.2 4/18/2008: Validating: Emulator_12: Cart Art Path:
14:10:25.2 4/18/2008: Warning: Emulator_12: Cart Art Path Does not exist
14:10:25.2 4/18/2008: Validating: Emulator_12: Manual Path:
14:10:25.2 4/18/2008: Warning: Emulator_12: Manual Path Does not exist
14:10:25.2 4/18/2008: Validating: Emulator_13: Custom Background: F:\32x\VIDS
14:10:25.2 4/18/2008: Warning: Emulator_13: Custom Background Does not exist
14:10:25.2 4/18/2008: Validating: Emulator_13: Snap Path: F:\32x\VIDS
14:10:25.2 4/18/2008: Validating: Emulator_13: Control Panel Path: C:\Emulation\Assets\Console\Sega 32x\Controls
14:10:25.2 4/18/2008: Warning: Emulator_13: Control Panel Path Does not exist
14:10:25.2 4/18/2008: Validating: Emulator_13: Instructions Path:
14:10:25.2 4/18/2008: Warning: Emulator_13: Instructions Path Does not exist
14:10:25.2 4/18/2008: Validating: Emulator_13: Database: [Console] Sega 32X
14:10:25.2 4/18/2008: Validating: Emulator_13: Title Snap Path:
14:10:25.2 4/18/2008: Warning: Emulator_13: Title Snap Path Does not exist
14:10:25.2 4/18/2008: Validating: Emulator_13: Box Art Path:
14:10:25.2 4/18/2008: Warning: Emulator_13: Box Art Path Does not exist
14:10:25.2 4/18/2008: Validating: Emulator_13: Cart Art Path:
14:10:25.2 4/18/2008: Warning: Emulator_13: Cart Art Path Does not exist
14:10:25.2 4/18/2008: Validating: Emulator_13: Manual Path:
14:10:25.2 4/18/2008: Warning: Emulator_13: Manual Path Does not exist
14:10:25.2 4/18/2008: Validating: Emulator_14: Custom Background: F:\Sega CD
14:10:25.2 4/18/2008: Warning: Emulator_14: Custom Background Does not exist
14:10:25.2 4/18/2008: Validating: Emulator_14: Snap Path: F:\Sega CD
14:10:25.2 4/18/2008: Validating: Emulator_14: Control Panel Path: C:\Emulation\Assets\Console\Sega CD\Controls
14:10:25.2 4/18/2008: Warning: Emulator_14: Control Panel Path Does not exist
14:10:25.2 4/18/2008: Validating: Emulator_14: Instructions Path:
14:10:25.2 4/18/2008: Warning: Emulator_14: Instructions Path Does not exist
14:10:25.2 4/18/2008: Validating: Emulator_14: Database: [Console] Sega CD
14:10:25.2 4/18/2008: Validating: Emulator_14: Title Snap Path: F:\Sega CD\Artwork\Snaps
14:10:25.2 4/18/2008: Validating: Emulator_14: Box Art Path: F:\Sega CD\Artwork\Box Art
14:10:25.2 4/18/2008: Validating: Emulator_14: Cart Art Path:
14:10:25.2 4/18/2008: Warning: Emulator_14: Cart Art Path Does not exist
14:10:25.2 4/18/2008: Validating: Emulator_14: Manual Path: C:\Emulation\Assets\Console\Sega CD\Manuals
14:10:25.2 4/18/2008: Warning: Emulator_14: Manual Path Does not exist
14:10:25.2 4/18/2008: Validating: Emulator_15: Custom Background: F:\Sega GameGear
14:10:25.2 4/18/2008: Validating: Emulator_15: Snap Path: F:\Sega GameGear
14:10:25.2 4/18/2008: Validating: Emulator_15: Control Panel Path: C:\Emulation\Assets\HandHeld\Sega Game Gear\Controls
14:10:25.2 4/18/2008: Warning: Emulator_15: Control Panel Path Does not exist
14:10:25.2 4/18/2008: Validating: Emulator_15: Instructions Path:
14:10:25.2 4/18/2008: Warning: Emulator_15: Instructions Path Does not exist
14:10:25.2 4/18/2008: Validating: Emulator_15: Database: [Handheld] Sega Game Gear
14:10:25.2 4/18/2008: Validating: Emulator_15: Title Snap Path:
14:10:25.2 4/18/2008: Warning: Emulator_15: Title Snap Path Does not exist
14:10:25.2 4/18/2008: Validating: Emulator_15: Box Art Path:
14:10:25.2 4/18/2008: Warning: Emulator_15: Box Art Path Does not exist
14:10:25.2 4/18/2008: Validating: Emulator_15: Cart Art Path:
14:10:25.2 4/18/2008: Warning: Emulator_15: Cart Art Path Does not exist
14:10:25.2 4/18/2008: Validating: Emulator_15: Manual Path: C:\Emulation\Assets\HandHeld\Sega Game Gear\Manuals
14:10:25.2 4/18/2008: Warning: Emulator_15: Manual Path Does not exist
14:10:25.3 4/18/2008: Validating: Emulator_16: Custom Background: F:\Sega Genesis\Videos
14:10:25.3 4/18/2008: Validating: Emulator_16: Snap Path: F:\Sega Genesis\Videos
14:10:25.3 4/18/2008: Validating: Emulator_16: Control Panel Path: C:\Emulation\Assets\Console\Sega Genesis\Controls
14:10:25.3 4/18/2008: Warning: Emulator_16: Control Panel Path Does not exist
14:10:25.3 4/18/2008: Validating: Emulator_16: Instructions Path:
14:10:25.3 4/18/2008: Warning: Emulator_16: Instructions Path Does not exist
14:10:25.3 4/18/2008: Validating: Emulator_16: Database: [Console] Sega Genesis
14:10:25.3 4/18/2008: Validating: Emulator_16: Title Snap Path:
14:10:25.3 4/18/2008: Warning: Emulator_16: Title Snap Path Does not exist
14:10:25.3 4/18/2008: Validating: Emulator_16: Box Art Path:
14:10:25.3 4/18/2008: Warning: Emulator_16: Box Art Path Does not exist
14:10:25.3 4/18/2008: Validating: Emulator_16: Cart Art Path:
14:10:25.3 4/18/2008: Warning: Emulator_16: Cart Art Path Does not exist
14:10:25.3 4/18/2008: Validating: Emulator_16: Manual Path: C:\Emulation\Assets\Console\Sega Genesis\Manuals
14:10:25.3 4/18/2008: Warning: Emulator_16: Manual Path Does not exist
14:10:25.3 4/18/2008: Validating: Emulator_17: Custom Background: F:\Sega Master System
14:10:25.3 4/18/2008: Validating: Emulator_17: Snap Path: F:\Sega Master System
14:10:25.3 4/18/2008: Validating: Emulator_17: Control Panel Path: C:\Emulation\Assets\Console\Sega Master System\Controls
14:10:25.3 4/18/2008: Warning: Emulator_17: Control Panel Path Does not exist
14:10:25.3 4/18/2008: Validating: Emulator_17: Instructions Path:
14:10:25.3 4/18/2008: Warning: Emulator_17: Instructions Path Does not exist
14:10:25.3 4/18/2008: Validating: Emulator_17: Database: [Console] Sega Master System
14:10:25.3 4/18/2008: Validating: Emulator_17: Title Snap Path:
14:10:25.3 4/18/2008: Warning: Emulator_17: Title Snap Path Does not exist
14:10:25.3 4/18/2008: Validating: Emulator_17: Box Art Path:
14:10:25.3 4/18/2008: Warning: Emulator_17: Box Art Path Does not exist
14:10:25.3 4/18/2008: Validating: Emulator_17: Cart Art Path:
14:10:25.3 4/18/2008: Warning: Emulator_17: Cart Art Path Does not exist
14:10:25.3 4/18/2008: Validating: Emulator_17: Manual Path:
14:10:25.3 4/18/2008: Warning: Emulator_17: Manual Path Does not exist
14:10:25.3 4/18/2008: Validating: Emulator_18: Custom Background: F:\SNES\Snaps
14:10:25.3 4/18/2008: Validating: Emulator_18: Snap Path: F:\SNES\Snaps
14:10:25.3 4/18/2008: Validating: Emulator_18: Control Panel Path:
14:10:25.3 4/18/2008: Warning: Emulator_18: Control Panel Path Does not exist
14:10:25.3 4/18/2008: Validating: Emulator_18: Instructions Path:
14:10:25.3 4/18/2008: Warning: Emulator_18: Instructions Path Does not exist
14:10:25.3 4/18/2008: Validating: Emulator_18: Database: [Console] Nintendo SNES
14:10:25.3 4/18/2008: Validating: Emulator_18: Title Snap Path: F:\SNES\ART
14:10:25.3 4/18/2008: Validating: Emulator_18: Box Art Path:
14:10:25.3 4/18/2008: Warning: Emulator_18: Box Art Path Does not exist
14:10:25.3 4/18/2008: Validating: Emulator_18: Cart Art Path:
14:10:25.3 4/18/2008: Warning: Emulator_18: Cart Art Path Does not exist
14:10:25.3 4/18/2008: Validating: Emulator_18: Manual Path: F:\SNES\Manuals
14:10:25.3 4/18/2008: Loading OfflineList Dat File for emulator: 18
14:10:25.3 4/18/2008: Cannot Find Offline List Dat File
14:10:25.3 4/18/2008: Validating: Emulator_20: Custom Background: F:\Turbo\snaps
14:10:25.3 4/18/2008: Warning: Emulator_20: Custom Background Does not exist
14:10:25.3 4/18/2008: Validating: Emulator_20: Snap Path: F:\Turbo\snaps
14:10:25.3 4/18/2008: Validating: Emulator_20: Control Panel Path: C:\Emulation\Assets\Console\NEC TurboGrafx 16\Controls
14:10:25.3 4/18/2008: Warning: Emulator_20: Control Panel Path Does not exist
14:10:25.3 4/18/2008: Validating: Emulator_20: Instructions Path:
14:10:25.3 4/18/2008: Warning: Emulator_20: Instructions Path Does not exist
14:10:25.3 4/18/2008: Validating: Emulator_20: Database:
14:10:25.3 4/18/2008: Warning: Emulator_20: Database Does not exist
14:10:25.3 4/18/2008: Validating: Emulator_20: Title Snap Path:
14:10:25.3 4/18/2008: Warning: Emulator_20: Title Snap Path Does not exist
14:10:25.3 4/18/2008: Validating: Emulator_20: Box Art Path:
14:10:25.3 4/18/2008: Warning: Emulator_20: Box Art Path Does not exist
14:10:25.3 4/18/2008: Validating: Emulator_20: Cart Art Path:
14:10:25.3 4/18/2008: Warning: Emulator_20: Cart Art Path Does not exist
14:10:25.3 4/18/2008: Validating: Emulator_20: Manual Path:
14:10:25.4 4/18/2008: Warning: Emulator_20: Manual Path Does not exist
14:10:25.4 4/18/2008: Validating: Emulator_21: Custom Background: C:\Emulation\Assets\Pinball\Visual Pinball\Snaps
14:10:25.4 4/18/2008: Warning: Emulator_21: Custom Background Does not exist
14:10:25.4 4/18/2008: Validating: Emulator_21: Snap Path: C:\Emulation\Assets\Pinball\Visual Pinball\Snaps
14:10:25.4 4/18/2008: Warning: Emulator_21: Snap Path Does not exist
14:10:25.4 4/18/2008: Validating: Emulator_21: Control Panel Path: C:\Emulation\Assets\Pinball\Visual Pinball\Controls
14:10:25.4 4/18/2008: Warning: Emulator_21: Control Panel Path Does not exist
14:10:25.4 4/18/2008: Validating: Emulator_21: Instructions Path:
14:10:25.4 4/18/2008: Warning: Emulator_21: Instructions Path Does not exist
14:10:25.4 4/18/2008: Validating: Emulator_21: Database: [Pinball] Pinball
14:10:25.4 4/18/2008: Warning: Emulator_21: Database Does not exist
14:10:25.4 4/18/2008: Validating: Emulator_21: Title Snap Path: C:\Emulation\Assets\Pinball\Visual Pinball\Titles
14:10:25.4 4/18/2008: Warning: Emulator_21: Title Snap Path Does not exist
14:10:25.4 4/18/2008: Validating: Emulator_21: Box Art Path: C:\Emulation\Assets\Pinball\Visual Pinball\Boxes
14:10:25.4 4/18/2008: Warning: Emulator_21: Box Art Path Does not exist
14:10:25.4 4/18/2008: Validating: Emulator_21: Cart Art Path: C:\Emulation\Assets\Pinball\Visual Pinball\Cartridges
14:10:25.4 4/18/2008: Warning: Emulator_21: Cart Art Path Does not exist
14:10:25.4 4/18/2008: Validating: Emulator_21: Manual Path: C:\Emulation\Assets\Pinball\Visual Pinball\Manuals
14:10:25.4 4/18/2008: Warning: Emulator_21: Manual Path Does not exist
14:10:25.6 4/18/2008: Restoring Emulator from Cache
14:10:30.5 4/18/2008: Running: cmd.exe /c C: vpinball_loader.exe "C:\Pinball\Tables\Baywatch (Sega) (1995) (Joe Kaminkow) (4.5a).vpt"
14:11:12.5 4/18/2008: Exiting GameEx!
14:11:12.5 4/18/2008: Saving Settings
14:11:15.3 4/18/2008: Disposing Plugins
14:11:15.3 4/18/2008: Closing database connection
14:11:15.4 4/18/2008: Checking for applications to Launch On Exit
14:11:15.4 4/18/2008: Media Center was not open when starting GameEx, so not launching
Thanks again!
Ok, We need something a little different this time.
Use the Gameex Configuration, and go to the section where it shows your emulator setup. At the top of the page is a button that says "export Emulator" Click on that, save the file, then post the contents.
Actually, within the last week, Brian posted his working config. (I'm pretty sure it was Monday)
You could search for that, or when you see Brians Avatar in a post, there is a drop down menu (point at his user name, and left click) that you can select "view all members post" (or something like that) you should be able to find it pretty quick that way.
Let us know if you get it working, or need more help.
Ok, so it turns out that was the config I was using so here is the config I have now....My problem before was a simple " " space error...Now it doesn't just go to black it actually loads the pinball file but not the table. I hear sounds and can push buttons but only the score screen shows up. Speaking of the score screen is there a way to set it to lock in a certain place not in the way of the table? Below is my pinball config. Thanks for all your help. Oh and when I run it from the run last game.bat the score screen and the table load just fine....
[Emulator_12]
STARTPAGENAME=Pinball Games
TITLETEXT=Pinball
StartPageLogo=pinball
ROMFilter=*.vpt
RomPath=C:\Pinball\Tables
SnapPath=
TitlePath=
BoxPath=
CartPath=
ManualPath=
ControlPanelPath=
InstructionsPath=
WorkingPath=C:\Pinball
MapKeys=True
WaitBeforeKeys=
SendKeys=
ReplaceDash=True
ReplaceUnder=True
Capitals=True
RemoveBrackets=False
ShowDesktop=False
Debug=False
MAPFile=
AlsoLaunch=[apppath]\vpauto.exe
Command=VPinball.exe -play -"[RomPath]\[RomFile]"
OLDatZip=
LaunchBefore=
LaunchAfter=
configFile=Project 64 V2
ExcludedFiles=
CustomBackground=
PlayMusic=
DontShowInfo=
PlaySelectionMusic=
SelectionMusicFolder=
PCGame=
DATABASE=VISUALPINBALL
GamesIn7Zips=
PlayInScreenSaver=True
ShowMostPlayed=
RandomMostPlayed=
CDCheck=
CDCheckFile=
[GENERAL]
DumbyValue=
[Emulator_12]
TITLETEXT=Pinball
ROMFilter=*.vpt
SnapPath=
TitlePath=
BoxPath=
CartPath=
ManualPath=
ControlPanelPath=
InstructionsPath=
MapKeys=True
WaitBeforeKeys=
SendKeys=
ReplaceDash=True
ReplaceUnder=True
Capitals=True
ShowDesktop=False
Debug=False
MAPFile=
OLDatZip=
LaunchBefore=
LaunchAfter=
ExcludedFiles=
CustomBackground=
PlayMusic=
DontShowInfo=
PlaySelectionMusic=
PCGame=
GamesIn7Zips=
ShowMostPlayed=
RandomMostPlayed=
CDCheck=
CDCheckFile=
[GENERAL]
DumbyValue=
The part in bold isn't right....I've seen this before....
I imported VP just to see what the standard import would say (in case there was an error) it says:
That's using vpinball_loader.exe which your not.
I'm not saying use the one I show, I'm just saying yours doesn't look right...
I'm setting up Visual pinball / Pinmame Using Brian's files...I figured out where the project 64 reference is coming from... :o
Brian, is that right?
BTW: If nobody has played "Haunted House", give it a try... There was one on campus back in '82, the only pinball game I liked. It has 3 levels, with flippers on all levels. The "Basement" level is sloped away from you, so when you hit the ball with the flipper, it comes back at you. If you lose the ball on this or the "2nd floor", you just keep playing on the main floor. So you get alot of play even if you are not very good (like me).
Nice Setup Package Brian! I set it up in about ten minutes, all by myself :blink: !
