Boys, before opening a post I have already tried the main things
Mame, mame32, all builds, all gameex version, 0.120, 0.121, 0.122 clrmame pro (logix dat and my dat created), romcenter, new mameinfo, i have deleted all data-files of gameex, I have tried with all gameex options, i have played all games from driving force to drummmania 3, i have downloaded new romset, i have buyed a new hard disk, i have created mame list with other frontend and works fine with all games
With Drummania the list and the icons stop to driving force
Without drummania everything works fine
I got the roms from various parties and the problem does not change, perhaps will be the chd I always fetched from the same place because it is not others
My problem exist only with gameex
I suspect it's because you have a broken rom. When GameEx creates the list, it uses the verify roms function of MAME to make sure it's valid. I'm guessing that the rom it stops on is broken bad enough that it breaks the function and doesn't finish creating the list. I recall someone having a similar problem 6-12 months ago and I think the resolution was getting a new rom set. I don't think you have to go that route, just run clrMAME or one of the other check programs to make sure your set is good.
