Serious problem - URGENT
I update the MAME list because not only saw zigzag but I have not changed anything compared to last time with the version 8.95
With 8.96 now I see only 1472 games over 6000, the list will stop at D (DRUMMANIA)
I tried with different versions of mame
This problem exist for other my friends to
I take it you tried restarting?
Yes, windows restart but problem persist
Now I physically removed zip files (roms) drummania and neighbors.
Rescan list and now gameex displays 6000 games but the previous problem of zigzag and other not resolved, even on 365 favorites displays 354.
Filters are not running
In my data.mdb no problem, these games are like any other show
:blink:
I don't see why it would be the problem, but did you upgrade MAME without upgrading your ROMS? It may be possible that MAME choked on an old ROM for some reason. Just make sure you are using the same version of MAME and ROMS and you should be good.
Tom, Bkenobi I think that I have trouble trail from old times, for example, every time I update the list mame I always go to change manually BezelVersion = 2 in the gameex.ini.
I have serious problems with the DB database categories: with microsoft access is ok but in gameex strange things happen.
Same thing for mame list, I have no problems with other frontend and clrmame pro. What happens?
i have deleted all new files windows create today in the gameex\data directory except gameex.ini and data.mdb
update list but problem not resolved
Not only zigzag but other games not in list
I use mame 0.120
I use mame 0.120
This is probably because you have verify roms turned on, and MAME does cant verify the roms, or you have only existing turned on and your roms are merged. Or you have only working turned on and the games are not fully working.
Ben Kenobi was pretty spot on in what he said.
If you want to list all games then basically turn off verify roms, only existing, only working and turn off the rom filter. Otherwise GameEx will do its best to give a list of only "decent" games. Which to be honest, is what I want it to do.
I think the list issue was some other kind of unrelated issue.
I'm sure, my mame32 and clrmame pro works fine
Just because they work in MAME32 does not mean the games are 100% correct, and MAME will verify them as such when building the list in GameEx. If you want to show every single game whether "working" or "verified" or not then read what I said before.
I use mame 0.120
Alot of time there are Re-Dumps of a particular game... or several to make them more accurate..
Perhaps getting the rom set for this version.... Which is now out of date because mame is up to 121 U1 now.
Could fix the issue.
Bian familiar with the issue but I do not believe that that is inherent to me go here :
I re-tried now with these settings
OnlyWorking=False
AllowImperfect=
VerifyRoms=False
OnlyRoms=False
NoGameInfo=False
GameFilter=
GameFilterOn=False
NoAdult=False
NoClones=False
I see only 1492 games over 6000, the list will stop at D (DRUMMANIA)
:huh::wacko::blink::angry:<_<:huh::huh:
I re-re-tried removing the zip of drummania
Now i see 6822 games but all are 6823 with drummania :angry:
Strange things really happen that I can not explain.
Now you know what happens? I see all the games but not all the icons? Towards D jump to the letter O, then a hole and then resume
Up to yesterday, there were not these things! Uff
Do you believe has importance that uses a usb hard disk with all games and gameex ?
So your gameex installation and roms..etc are all on an external disk?
That should be fine... As long as gameex config is pointed to the correct drive letter..
I would use these settings
OnlyWorking=True
AllowImperfect=True
VerifyRoms=True
OnlyRoms=True
NoGameInfo=False
GameFilter=
GameFilterOn=False
NoAdult=False
NoClones=False
I would also create a new roms folder callled ROMS2 and I would copy a few known good roms like sf2 and such in the folder..
Then id update my gameex config to point to the new roms folder... Then Id update my list again and see if only the FEW roms exitst..
Brian until this morning everything worked regularly, I have not changed anything then gameex config is pointed to the correct drive letter as usual.
Now works but I can not display icons from D to O and from S to Z. Probably happened a power outage during the rebuilding of icons.
There is a command to restore icons without having to make a full update of list ? I do not want something happens again...
Not that Im aware of... Sorry :(
the icons works fine in windows and mame32, in gameex i have this problem...mystery
Nothing is not working, configure anything wrong, Tom please look my gameex.ini. In my opinion there is something wrong
Many functions enabled or disabled does not change anything,
If I able or disable mahjong or other does not change anything
I do not speak only of updating list but also other function,
Example :
Hide Create snaps does not work
Hide Update List does not work
Example :
Post it then.
My betting is your usb hard drive is on the way out. Or your gameex install got corrupted.
A lot of those options regarding the list, require another update to take affect.
Tom, I discovered this:
If I delete this range of information from gamelist.txt gameex works with all roms (except this) :
drmn|DrumMania (GQ881 VER. JAD)|Konami|1999|True|Ritmo / Strumenti|False|H|640|480||[-LF-][-LF-][-LF-]DrumMania e' un gioco dove delle note colorate scendono lungo lo schermo in corrispondenza di colori associati a parti di una batteria elettronica. Il giocatore deve colpire i pezzi della batteria quando le note arrivano in basso nello schermo, in modo da completare la parte di batteria mancante dalla canzone.[-LF-][-LF-][-LF-]- DATI TECNICI -[-LF-][-LF-][-LF-]Konami Bemani 573 Analog hardware.[-LF-][-LF-][-LF-]Processore Principale: PSX (@ 16.9344 Mhz)[-LF-][-LF-]Chip Audio: SPU (@ 16.9344 Mhz), CD/DA (@ 16.9344 Mhz)[-LF-][-LF-][-LF-]Colori palette: 65536[-LF-][-LF-][-LF-]Giocatori: 1[-LF-][-LF-]Pulsanti: 6[-LF-][-LF-][-LF-]- CURIOSITA' -[-LF-][-LF-][-LF-]Il gioco e' conosciuto anche come "Percussion Freaks".[-LF-][-LF-][-LF-]Konami Music Entertainment ha pubblicato la colonna sonora in edizione limitata per questo gioco (DrumMania Original Soundtracks - KMCA-18) il 06/08/1999.[-LF-][-LF-][-LF-]- CONSIGLI E TRUCCHI -[-LF-][-LF-][-LF-]*Modalita' Speed: Colpisci |Charleston| |Rullante| |Charleston| |Charleston| |Rullante| |Charleston| |Cassa| alla schermata di selezione della modalita'.[-LF-][-LF-][-LF-]*Modalita' Nascosta (Hidden) : colpisci |Tom Alto| |Tom Basso| |Tom Alto| |Tom Basso| |Tom Alto| |Cassa| alla schermata di selezione della modalita'.[-LF-][-LF-][-LF-]*Modalita' speculare (Mirror): colpisci |Rullante| |Rullante| |Tom Alto| |Tom Basso| |Tom Alto| |Cassa| alla schermata di selezione della modalita'.[-LF-][-LF-][-LF-]*Difficolta' Esperto Reale (Expert Real) : colpisci |Charleston| |Charleston| |Rullante| |Rullante| |Tom Alto| |Tom Basso| |Tom Alto| |Tom Basso| |Cassa| |Cassa| alla schermata di selezione della modalita'. Premi Destra sull'impostazione di difficolta' Real.[-LF-][-LF-][-LF-]- SERIE -[-LF-][-LF-][-LF-]1. DrumMania (2000)[-LF-][-LF-]2. DrumMania 2nd Mix (2000)[-LF-][-LF-]3. DrumMania 3rd Mix (2000)[-LF-][-LF-]4. DrumMania 4th Mix (2001)[-LF-][-LF-]5. DrumMania 5th Mix (2001)[-LF-][-LF-]6. DrumMania 6th Mix (2002)[-LF-][-LF-]7. DrumMania 7th Mix (2002)[-LF-][-LF-]8. DrumMania 8th Mix (2003)[-LF-][-LF-]9. DrumMania 9th Mix (2003)[-LF-][-LF-]10. DrumMania 10th Mix (2004)[-LF-][-LF-]11. Drummania V (2005)[-LF-][-LF-]12. Drummania V2 (2005)[-LF-][-LF-]13. DrumMania V4 (2007)[-LF-][-LF-]||1P|-1|False|False|joy2way|
drmn2m|DrumMania 2nd Mix (GE912 VER. JAA)|Konami|1999|True|Ritmo / Strumenti|False|H|640|480||[-LF-][-LF-][-LF-]DrumMania e' un gioco dove delle note colorate scendono lungo lo schermo in corrispondenza di colori associati a parti di una batteria elettronica. Il giocatore deve colpire i pezzi della batteria quando le note arrivano in basso nello schermo, in modo da completare la parte di batteria mancante dalla canzone.[-LF-][-LF-][-LF-]- DATI TECNICI -[-LF-][-LF-][-LF-]Konami Bemani 573 Digital hardware[-LF-][-LF-][-LF-]Processore Principale: PSX[-LF-][-LF-]Chip Audio: SPU, CD/DA[-LF-][-LF-][-LF-]Colori palette: 65536[-LF-][-LF-][-LF-]Giocatori: 1[-LF-][-LF-]Pulsanti: 6[-LF-][-LF-][-LF-]- CURIOSITA' -[-LF-][-LF-][-LF-]Questo gioco e' anche conosciuto come "Percussion Freaks 2nd Mix".[-LF-][-LF-][-LF-]Konami Music Entertainment ha pubblicato la colonna sonora in edizione limitata per questo gioco (Guitar Freaks 3rd Mix & DrumMania 3rd Mix Soundtracks - KMCA-23) il 22/11/2000.[-LF-][-LF-][-LF-]- CONSIGLI E TRUCCHI -[-LF-][-LF-][-LF-]*Menu' opzioni: inserisci le monete, quindi tieni premuto Sinistra e Destra e premi Start.[-LF-][-LF-][-LF-]*Modalita' Nascosta e rapida: inserisci i crediti, quindi colpisci |Tom Alto| |Tom Basso| |Tom Alto| |Tom Basso| |Tom Alto| |Cassa| e premi Start. Le modalita' nascosta (Hidden) e rapida (Sudden) verranno sbloccate nel menu' opzioni.[-LF-][-LF-][-LF-]*Modalita' Tight: Inserisci i crediti, quindi tieni premuto |Cassa| e colpisci |Charleston| |Rullante| |Tom Alto| |Tom Basso|. Lascia andare |Cassa| e colpisci |Charleston| |Rullante| |Tom Alto| |Tom Basso|, |Cassa| + |Rullante|. La modalita' Tight verra' sbloccata dal menu' opzioni.[-LF-][-LF-][-LF-]*Modalita' Piccolo e Silenzioso: Inserisci i crediti, quindi colpisci |Tom Alto| + |Tom Basso|, |Rullante| |Rullante|, |Charleston| + |Tom Alto|, |Rullante| |Rullante|, |Charleston| + |Tom Basso|. Le modalita' Piccolo (Small) e Silenzioso (Silent) verranno sbloccati nel menu' opzioni.[-LF-][-LF-][-LF-]*Modalita' Reale Esperto: evidenzia l'impostazione di difficolta' Real quindi premi |Tom Basso| |Tom Basso| |Tom Basso| |Tom Basso| |Tom Basso| nella schermata di selezione della modalita'.[-LF-][-LF-][-LF-]*Cambia difficolta' in modalita' sessione: Seleziona la modalita' sessione. Quindi colpisci |Charleston| |Charleston| alla schermata della selezione della canzone per cambiare dalla modalita' normale a quella extreme.[-LF-][-LF-][-LF-]*New song speed: colpisci |Cassa| |Cassa| entro un secondo alla schermata di selezione della velocita' della canzone. Questo deve essere fatto fino a sette volte di fila prima che la canzone torni alla velocita' iniziale. In alternativa premete Start + Sinistra + Destra durante il gioco anche in questo caso deve essere fatto fino a sette volte di fila prima che la canzone torni alla velocita' iniziale.[-LF-][-LF-][-LF-]- SERIE -[-LF-][-LF-][-LF-]1. DrumMania (2000)[-LF-][-LF-]2. DrumMania 2nd Mix (2000)[-LF-][-LF-]3. DrumMania 3rd Mix (2000)[-LF-][-LF-]4. DrumMania 4th Mix (2001)[-LF-][-LF-]5. DrumMania 5th Mix (2001)[-LF-][-LF-]6. DrumMania 6th Mix (2002)[-LF-][-LF-]7. DrumMania 7th Mix (2002)[-LF-][-LF-]8. DrumMania 8th Mix (2003)[-LF-][-LF-]9. DrumMania 9th Mix (2003)[-LF-][-LF-]10. DrumMania 10th Mix (2004)[-LF-][-LF-]11. Drummania V (2005)[-LF-][-LF-]12. Drummania V2 (2005)[-LF-][-LF-]13. DrumMania V4 (2007)[-LF-][-LF-]||1P|-1|False|False|joy2way|
drmn3m|DrumMania 3rd Mix (G*A23 VER. JAA)|Konami|2000|True|Ritmo / Strumenti|False|H|640|480|pcnfrk3m|[-LF-][-LF-][-LF-]DrumMania e' un gioco dove delle note colorate scendono lungo lo schermo in corrispondenza di colori associati a parti di una batteria elettronica. Il giocatore deve colpire i pezzi della batteria quando le note arrivano in basso nello schermo, in modo da completare la parte di batteria mancante dalla canzone.[-LF-][-LF-][-LF-]- DATI TECNICI -[-LF-][-LF-][-LF-]Konami Bemani 573 Digital hardware[-LF-][-LF-][-LF-]Processore Principale: PSX (@ 16.9344 Mhz)[-LF-][-LF-]Chip Audio: SPU (@ 16.9344 Mhz), CD/DA[-LF-][-LF-][-LF-]Colori palette: 65536[-LF-][-LF-][-LF-]Giocatori: 1[-LF-][-LF-]Pulsanti: 6[-LF-][-LF-][-LF-]- CURIOSITA' -[-LF-][-LF-][-LF-]DrumMania 3rd Mix puo' essere collegato con "GuitarFreaks 4th Mix".[-LF-][-LF-][-LF-]Questo gioco e' conosciuto nei paesi asiatici come "Percussion Freaks 3rd Mix".[-LF-][-LF-][-LF-]Konami Music Entertainment ha pubblicato la colonna sonora in edizione limitata per questo gioco (Guitar Freaks 4th Mix & DrumMania 3rd Mix Soundtracks - KMCA-111) il 06/06/2001.[-LF-][-LF-][-LF-]- CONSIGLI E TRUCCHI -[-LF-][-LF-][-LF-]*Menu' opzioni: inserisci le monete, quindi tieni premuto Sinistra e Destra e premi Start.[-LF-][-LF-][-LF-]*Modalita' Nascosta e rapida: inserisci i crediti, quindi colpisci |Tom Alto| |Tom Basso| |Tom Alto| |Tom Basso| |Tom Alto| |Cassa| e premi Start. Le modalita' nascosta (Hidden) e rapida (Sudden) verranno sbloccate nel menu' opzioni.[-LF-][-LF-][-LF-]*Modalita' Tight: Inserisci i crediti, quindi tieni premuto |Cassa| e colpisci |Charleston| |Rullante| |Tom Alto| |Tom Basso|. Lascia andare |Cassa| e colpisci |Charleston| |Rullante| |Tom Alto| |Tom Basso|, |Cassa| + |Rullante|. La modalita' Tight verra' sbloccata dal menu' opzioni.[-LF-][-LF-][-LF-]*Modalita' Piccolo e Silenzioso: Inserisci i crediti, quindi colpisci |Tom Alto| + |Tom Basso|, |Rullante| |Rullante|, |Charleston| + |Tom Alto|, |Rullante| |Rullante|, |Charleston| + |Tom Basso|. Le modalita' Piccolo (Small) e Silenzioso (Silent) verranno sbloccati nel menu' opzioni.[-LF-][-LF-][-LF-]*Modalita' Reale Esperto: evidenzia l'impostazione di difficolta' Real quindi premi |Tom Basso| |Tom Basso| |Tom Basso| |Tom Basso| |Tom Basso| nella schermata di selezione della modalita'.[-LF-][-LF-][-LF-]*Cambia difficolta' in modalita' sessione: Seleziona la modalita' sessione. Quindi colpisci |Charleston| |Charleston| alla schermata della selezione della canzone per cambiare dalla modalita' normale a quella extreme.[-LF-][-LF-][-LF-]*New song speed: colpisci |Cassa| |Cassa| entro un secondo alla schermata di selezione della velocita' della canzone. Questo deve essere fatto fino a sette volte di fila prima che la canzone torni alla velocita' iniziale. In alternativa premete Start + Sinistra + Destra durante il gioco anche in questo caso deve essere fatto fino a sette volte di fila prima che la canzone torni alla velocita' iniziale.[-LF-][-LF-][-LF-]- SERIE -[-LF-][-LF-][-LF-]1. DrumMania (2000)[-LF-][-LF-]2. DrumMania 2nd Mix (2000)[-LF-][-LF-]3. DrumMania 3rd Mix (2000)[-LF-][-LF-]4. DrumMania 4th Mix (2001)[-LF-][-LF-]5. DrumMania 5th Mix (2001)[-LF-][-LF-]6. DrumMania 6th Mix (2002)[-LF-][-LF-]7. DrumMania 7th Mix (2002)[-LF-][-LF-]8. DrumMania 8th Mix (2003)[-LF-][-LF-]9. DrumMania 9th Mix (2003)[-LF-][-LF-]10. DrumMania 10th Mix (2004)[-LF-][-LF-]11. Drummania V (2005)[-LF-][-LF-]12. Drummania V2 (2005)[-LF-][-LF-]13. DrumMania V4 (2007)[-LF-][-LF-]||1P|-1|False|False|joy2way|
:mellow:
I tried with all new versions of mame and different mameinfo.dat but the problem is still there, updating games and gameeex displays only until drummania if i remove the string gameex works with all remaining roms then there is some problem in writing in gamelist.txt.
Unfortunately I can not understand where the problem is, help me otherwise I can not do update roms and icons just stick to the D
  • 1 month later...
After more than a month I changed several versions of gameex and mame,
important is that I changed hard disk but does not change the problem.
I have to move temporarily drummania roms in another folder before upgrade gameex-list, another method is that I must edit gamelist.txt as the previous post
Certainly not change my life not play drummania but the problem is strange , do you not believe?
Call me a noob for not reading the thread, but...
Did you use clrMAMEpro to verify your sets? I'm willing to place a wager on this being a CHD problem as opposed to a ROM set problem.
