Just received laserdisc roms. Everything works outside of GameEx in Daphne. All games play great, however; when I try to run Daphne via GameEx, the screen goes to black and when I pull up Windows Task Manager it tells me Daphne has encountered an error.
In a previous thread, Brian Hoffman suggested that the person has the latest codecs installed like k-lite codecpack. I have the Ace Mega codec professional pack installed. Is that really the issue or am I doing something else wrong? I tried following the video tutorial on the website but I'm not sure the rom path is correct. I'm a little confused about renaming it and adding an underscore followed by a number from 0-60. Not sure what that means.
FYI- I enabled Daphne in GameEx and enabled the individual game(s).
Any help would be greatly appreciated.
Thanks.
Thanks.
Can you get daphne to work via the command line... There a quite a few threads here on daphne.. I suggest reading them all as they cover everything... If you are still stumped I dont mind helping...
Fist thing is first.. What version are you using. Can you get it to work via the command line.. Post your config(gameex snaps)... Post your daphne log(in daphne folder) Both when it works through the loader and then when it errors through gameex..
This shouldnt be too bad.
