I have a copy of the DVD set of the Digital Leisure Dragon's
Lair DVDROM. This has already been converted to Mpeg using the DVD2DAPHNE utility. The problem is I do not have the framefile. Does anyone have the file? It should start:
150 dl-slates.m2v
323 dls00.vob.m2v
and have a bunch of entries after that.
Thanks to all who can help.
Ratmonkey
I have to converted files and no longer have the DVD or the text file.
Can anyone help?
The daphne loader will help you create the framefiles. not everyone has the same images / files / iso etc so the frames will be off slightly from version to version. Creating the framefile is not a big deal though with the daphne loader.
Using the Digital Leisure Dragon's Lair DVDROM creates almost 200 mpeg files. The framerate text is what daphne reads to put them all together. If someone has this set I should be able to use thier file.
