Has anyone got any Atari Jaguar emus working through GameEx?
Preferably 'Project Tempest', or if not, 'Virtual Jaguar'???
Cheers.
Yes I have Virtual Jaguar working on the following config:
[Emulator_8]
STARTPAGENAME=Atari Jaguar Games
TITLETEXT=Atari Jaguar
StartPageLogo=
ROMFilter=*.zip
RomsInFolders=False
RomPath=C:\ROMs\Atari\Jaguar
SnapPath=
WorkingPath=C:\ROMs\Atari\Jaguar\virtualjaguar-1.0.7
MapKeys=False
WaitBeforeKeys=
SendKeys=
ReplaceDash=False
ReplaceUnder=True
Capitals=False
RemoveBrackets=False
ShowDesktop=False
Debug=False
MAPFile=
AlsoLaunch=
Command=vj.exe "[ROMPath]\[RomFile]"
OLDatZip=
Just dont forget that you need to set vj's config file so that it starts in fullscreen mode (open the config file, you will see what to do)
It will not exit correctly though, pressing esc just pauses VJ. Will update if I find a way around.
Cheers and have fun.
To exit, try setting MAP keys to true. That should do it.
awesome - cheers mate
Got Project Tempest working, but it only works with version 0.82. (and maybe earlier version)
I think versions 0.9 - 0.95 may not have the command line functions anymore. Unfortunately .82 is not as good as .95 for the game I've been testing (Alien Vs Predator). I've not tried any others, so don't how it compare to Virtual Jaguar with them - AVP is a bit slow in Virtual Jaguar too, when compared to the latest Project Tempest.
It'll only work with unzipped roms (.jag). And the filenames can't use any spaces in them - couldn't get it to work with the full path name in the command line.
[Emulator_1]
StartPageLogo=
ROMFilter=*.jag
RomsInFolders=False
RomPath=C:\Emulation\System\Atari\Jaguar\ROMs\Games
SnapPath=C:\Emulation\System\Atari\Jaguar\Pictures\Front Cover
WorkingPath=C:\Emulation\System\Atari\Jaguar\Emulators\PTv0.82
MapKeys=False
WaitBeforeKeys=
SendKeys=
ReplaceDash=False
ReplaceUnder=True
Capitals=False
ShowDesktop=False
Debug=False
MAPFile=
AlsoLaunch=
Command=pt.exe [RomFile]
OLDatZip=
The Project Tempest homepage for some reason doesn't have some of the older version to download, but you could try either of these links for v0.82...
link 1 (auto downloads - if it doesn't, press "pobierz plik" button)
link 2 (auto downloads)
