Can the red exit cross in upper right corner be turned off?
is it possible to turn off the red cross in the upper right corner of the gameex display...
if it can be turned off, can you still exit gameex somehow, via another option?
yes this can be turned off by setting "Show Buttons" to "No" in "Display Settings"
they're are a few other options to exit GameEx in "Enable/Disable Features" you can have it as a menu option on the start page by turning off "Disable Ext" or if you set "Disable Escape Key" to no then you can simply press escape on the start page to exit
you can also use the rather handy "Exit GameEx" plugin by Ben Baker in the plugin manager which will allow you to set up a custom key combination to exit, the only problem with it is that everytime you update GameEx you have to go back in and reset your custom keys
i want to disable the exit X in the upper corner, but i want to keep the home key, is there a way to do this? often i hit the escape by accident when going to push the home key.
You could always redraw the image and make 1x1 black dot. It wouldn't show up then.
