Fresh install of GameEx on arcade and can’t get Mame to run!
- Version: 0.255
- I have one game in the Roms folder to start: Puc Man
Couple things going on.
1. When I load the game, it immediately kicks me back to the GameEx menu
2. I am now getting a pop up that says “New Game Ex Version Update?  Select to continue”
 - When ai select it and try the update, it doesn’t appear to work.  I reload the GameEx and get the same pop-up.
I know it’s a simple fix, but it has been alluding me for two full days!
When reporting an issue, please attach copies of your gameex.ini and log.txt files for review.
Thanks!
P.S. Regarding the update loop issue -  Sometimes the update from within the frontend doesn't properly, so I have found downloading GameEx directly and running the installer fixes the issue.
I got a bunch of my games loaded and everything is running great, but I can’t seem to get PAC-MAN (puck man) to show up.
anyone else run I to this?
I thought puckman was the original that I needed.
Thanks!
This helps me help you by providing these files - thanks!
you are correct in that puck man is the master original rom and pac man is the English speaking clone. I would rather play pac man than puck man but I don't know why it is not showing up. I only ever checked and put big effort into pac man always showing up correctly! Sorry. i will take a look at some point.
Likely a setting that is off but hard to know without the requested support files. 🫥
Did you ever get the Puck Man issue sorted? If not please attach copies of your gameex.ini and log.txt files and we'll be glad to take a look and advise accordingly.
