Hi all,
If I use DOF linx with pinballX it launches VPX but not the table. If I remove the three directoutput files in the "plugin" folder (.dll, .Lnk, .xml) no worries it launches the table.
Please attach copies of your pinballx.ini and log.txt files when reporting an error.
Also, please note what version and release candidate of VPX you are using and if the error is occurring with one or more tables.
Thanks.
Thanks.
Technicly the DirectOutput plugin is just 1 file. The dll no lnk or xml is needed.
Did you get the issue after  updating DOFlinx ?
In the download section there is a newer version of the DirectOutput plugin. Which have some improvements.
Try to remove your doflinx during pinballx start and check if that helps.
I have an issue with DOF plugin when I launch doflinx during load. I found it was a timing issue, so what I do is launching doflinx before pinballx is started, I wait 3 seconds and launch pinballx
The following is part of my startup. This is not the script assigned in pinballx, but this is launched before I launch pinballx.exe
  Quote
@echo off
setlocal
Set mydrive=C:
Set MyPinballPath=Pinball
tasklist /FI "IMAGENAME eq DOFLinx.exe" 2>NUL | find /I /N "DOFLinx.exe">NUL
if "%ERRORLEVEL%"=="0" goto SKIPDofLinx
cd %mydrive%\%MyPinballPath%\DirectOutput
start %mydrive%\%MyPinballPath%\DirectOutput\DOFLinx.exe PINSCAPE=NO
timeout 3
:SKIPDofLinx
Hope it will help you to find your issue
  On 1/28/2025 at 3:53 PM, Benoit33 said:
i try but same issue
What did you try ?
Disabling doflinx ? Or updating directoutput plugin or delay of doflinx ?
If you say table doesn't load, what do you see happening ? As the logfile you posted, launch visual pinball and also fx3
  On 1/29/2025 at 1:04 PM, Benoit33 said:
not only VPX with PFX3 it's the same.
Regardless of whether or not the issue is occurring with Pinball FX3 in addition to VPx, the point is that we have seen some issues with specific VPX versions and release candidates.
It is recommended that users indicate which versions of applications when reporting issues to assist the community in proper identification and triage.
Thank you.
