[RESOLVED] PinballX 6.23 Not showing main menu media
Hi All,
Upgraded to the latest PinballX v6.23 today and my main (systems) screen is no longer showing backglass and table videos/images for some of the system categories. There does not seem to be any logic to the missing stuff, for example Pinball FX2 and Mame are fine but Pinball FX3 and Virtual Pinball are blank if matching is off in setup and default if matching is on.
I've not attached the usual files as everything has been A1 up until this point.
The in table select menus are all fine.
And while I'm here Merry Christmas All 🙂
Please attach copies of your pinballx.ini and log.txt files when reporting an issue.
Thanks and Merry Christmas!
  • Thanks 1
  On 12/11/2024 at 12:50 AM, Tom Speirs said:
i think i figured it out.
Im uploading 6.24 in a second.
Hi Tom,
Loaded 6.25, after running twice (first occasion there were a couple of wrong table loading issues in one system) all confirmed as working. Many thanks for your work 👍
  • Draco1962 changed the title to [RESOLVED] PinballX 6.23 Not showing main menu media
