After I exit GameEx normally with the exit button or choosing "exit GameEx" from the menu, a GameEx process is still running. It does not terminate, but stays on forever eating processor time and about 60 megs of memory. I use InstantSheller and therefore spawn explorer after GameEx exits in my "run on exit" line. Anyone have this same problem or have a suggestion for a fix? It really isn't a problem--more of an annoyance than anything. As always, wonderful program Tom! Thanks for being so pro-user with it.
Will
There are two options LaunchOnExit and LaunchOnExitNoWait. If you place explorer.exe on the latter it shouldn't hang GameEx.
Alternatively, you could try my launchshell program that will kill explorer upon launching GameEx and restore it back afterwards.
