[RESOLVED] Update from PinballX 6.11 to 6.16 : DMD and backglass have disappeared
Hi,
When I update to 6.16 : I can't see the DMD and the backglass windows when I navigate to tables. Other thing : the software seems to be slower.
Remark : the topper is displayed while it's in the same screen of the DMD.
If I reinstall the version 6.11 : it's ok I see DMD and backglass.
PinballX.zip
i expect you have a bad video but please try the next version, available in a few minutes.
I had attempted to do some video fallback code for incompatibilities with vmr 9.
I can update DirectX or my graphic card drivers if this is the problem. I'm on Windows 10 and I avoid update for the virtual cabinet.
16 minutes ago, Tom Speirs said:
i dont know. i reversed the change. Please try 6.17. if I've broken something else i will test with multiple displays.
Thank you, but the result is the same with 6.17 : no DMD, no backglass.
It works with the version 6.18 ! Thank you.
When you say maybe I have a 'bad video', what do you mean ? Can I change something for a better compatibility in the future ?
  • Draco1962 changed the title to [RESOLVED] Update from PinballX 6.11 to 6.16 : DMD and backglass have disappeared
