You have enabled full Screen exsluive mode hack
Is this enabled in  VPX as well ?
also the auto configure setting above, if you set that to No, will that works better ?
not a big deal, but you can skip the "-" before the table as well :
I have it like this :
-play "[TABLEPATH]\[TABLEFILE]"
Which version of VPX you use ? 10.7.x ?
Looks like the main delay is before VPX is launched, after Set Plugin data;
22:04:19.50  03/09/2024:  Launch System
22:04:19.50  03/09/2024:  Hide Backglass
22:04:19.50  03/09/2024:  Waiting for threads
22:04:19.60  03/09/2024:  Disposing display
22:04:19.68  03/09/2024:  Set Plugin data
22:05:20.36  03/09/2024:  Writing ScreenRes.txt
22:05:20.37  03/09/2024:  C:\Visual Pinball\VPinballX.exe /play -"C:\Visual Pinball\Tables\Spider_man.vpx"
22:05:20.42  03/09/2024:  C:\PinballX\vpauto.exe
22:05:28.74  03/09/2024:  Visual Pinball Player window foreground: 8
22:05:29.47  03/09/2024:  Found PinMAME ROM: sman_261
As no plugins are enabled it could be loading media or playfield image creation related with some sort of timeout in PinballX(?)
Make sure LAV codecs are installed as a first step - https://forums.gameex.com/forums/files/file/2451-lav-video-codecs/
Let us know if that helps.
Please try with the VPX 'Force exclusive fullscreen mode' checked
Please attach new copies of the log.txt & poinballx.ini files if the problem persists after that
Edit  - one further thing to try, in PinballX\Settings.exe under General Settings -> Table Loading Media Mode try changing to 'Use Loading Folders' (this will prevent PinballX from trying to take a screenshot of the playfield video to use as a loading image if that is the cause of the delay)
I think you missed my edit..
Can you try that too
  • Draco1962 changed the title to [RESOLVED] Delay when loading pinballX
  • Draco1962 locked this topic
