GameEX Arcade Edition 18.74 prompts for Update after launch
So there is another annoying issue that just started happening. GameEX Arcade prompts to update after launching, but will pause and exit if I try to run the update. The update seems to fail and just re-launches back to the splash screen. I am using Windows 11 it used to actually update but now it fails , same thing that has been happening on my cabinet
Please attach current copies of your gameex.ini and log.txt files when reporting an annoying issue. Thanks.
Thanks, a bit more than needed initally.
You left out the log.txt file from after the install error occured. Much needed.
BTW, I am able to replicate issues with the automated update, but was not aware of the issue as I normally download and perform an over the top installation. Old habit from back when update notifications were not a thing.
As noted previously, as a workaround to keep up-to-date, you can download the fole directly and perform an "over the top" installation until @Tom Speirs can address the issue.
  • Draco1962 changed the title to GameEX Arcade Edition 18.74 prompts for Update after launch
