Vorrei sapere i requisiti MINIMI di un PC per fare girare questi tavoli flipper in modo fluido
Premetto non ho molte disponibilità grazie a chi mi risponde
Translated:
I would like to know the MINIMUM requirements for a PC to run these pinball tables smoothly
Let me start by saying I don't have many availability thanks to those who answer me
Please post in English and within the correct subforum.
You may wis to use Google translate.
Thank you.
__________________
Si prega di postare in inglese e nel sottoforum corretto.
Potresti voler utilizzare Google Translate.
Grazie.
This forum is focused off the front-end programs of GameEx (GameEx/PinballX & Touch-Play) , not gaming tables. The front end doesn't demand extensive CPU/GPU resources, but it won't run on very outdated hardware.
If the front-end performance is lagging, you might consider using the Lite versions. When installing on Windows XP or Vista, you will encounter an option to select the Lite version.
Tables :
The frontend supports a variety of systems, depending on the hardware capabilities. Zen Pinball FX2 and FX3 may be playable with reduced settings. However, Zen Pinball FX should not be attempted on older hardware as it requires a newer GPU.
The Pinball Arcade is also playable, and the resolution can be lowered if the gameplay is not smooth.
Visual Pinball 9 is compatible as well. Most tables created for Visual Pinball 10 (up to version 10.7.4) should run smoothly.
Tables created in version 10.8 or newer generally demand a more powerful CPU and GPU.
 I hope this helps (and that you can translate it)
