Hi people.
I'm changing my cabinet from old ArcadeOS to Gameex (nice piece of software).
The problem I have is when I try to start a Project 64 rom. If I click the rom with the mouse, everything works OK, but when I hit the "select" key to start the rom nothing happends (rom names move to the right and then come back to their initial position). Even with debug mode activated, no DOS windows appears (seems lime Gameex doesn't even try to start the ROM).
Everything works OK with MAME (starting roms using keyboard or mouse).
Tried to activate/deactivate directInput , change the "select" key ..etc...
I've been looking for the solution in this forum, but couldn't find any... I've installed GameEx in two different machines with the same behaviour.
Any suggestion ?
Thanks in advance.
Roman
Also, depending on the version make sure your command line arguments are correct.
The last official PJ64 release needs this command line set up in GameEx:
Project64.exe [ROMPath]\[RomFile]
However if you are using the new WIP that you have to 'pay' for, it should look like this:
Project64.exe "[ROMPath]\[RomFile]"
Hope that helps! :)
Yeah but he said when he clicks with the mouse in GameEx it works, but not when he "selects" the game. That's just plain weird. In your GameEx directory, find your log file and paste it for us. This sure sounds like a GameEx issue, so that will help. Also, try turning off the "map keys" option in the N64 settings in the GameEx config. You could be getting a double hit that is returning you to the menu. Try those two things to get the ball rolling.
Hi people. Back again (3 days out).
I will try to send you a Log (now I'm working), but I remember there was nothing written in the log (like nothing happends) when I "select" a game. I will try to turn off map keys too. Will report tomorrow.
Thank you all.
ROman
Thank you all.
ROman
Another Possible Solution:
In your Gameex Project 64 folder: Show Desktop to YES
Somewhere else in Gameex, you need to check HIDE DESKTOP and ICONS.
Hello again.
Here you have the log. I started Super Mario 64 using the mouse (it worked fine) and then tried to start it using the "select" key 5 times (nothing in the log...). Roms list just moved right and then left again. The "select" sample sounds...
I have the complete gamex.ini file too, but it's 57 K size, and I thing it's too much to post it here.
As Lurker suggested, I will try to change show desktop settings...
Can any of you run N64 games using keyboard ? I tried it using another PC with the same result...
21:30:38.4 02/01/2007: GameEx: Version 7.09: Starting Log
21:30:38.5 02/01/2007: Operating System Platform: Win32NT
21:30:38.5 02/01/2007: Operating System Name: Windows XP
21:30:38.5 02/01/2007: Operating System Version: 5.1.2600
21:30:38.5 02/01/2007: Checking for versions of .net Framework installed
21:30:38.5 02/01/2007: .net Framework 1.1 Installed
21:30:38.5 02/01/2007: Intel® Celeron® D CPU 3.20GHz
21:30:38.5 02/01/2007: 3,2Ghz
21:30:38.5 02/01/2007: Running Randomize()
21:30:38.5 02/01/2007: Loading PlugIns
21:30:38.6 02/01/2007: Checking for applications to Launch On Startup
21:30:38.6 02/01/2007: Initialising Video/MNG DLL's
21:30:38.6 02/01/2007: Running Misc startup tasks
21:30:38.6 02/01/2007: Setting Menu types
21:30:38.6 02/01/2007: Opening Configuration File
21:30:38.6 02/01/2007: Getting Configuration Values
21:30:38.6 02/01/2007: Using Theme: Default - Custom V2 Default 640x480
21:30:38.6 02/01/2007: Checking for alternate Image Directory for Theme: Default - Custom V2 Default 640x480
21:30:38.6 02/01/2007: Launching HideOS.exe
21:30:38.6 02/01/2007: Hiding Taskbar
21:30:38.7 02/01/2007: Using Cabinet Friendly Control System
21:30:38.7 02/01/2007: Is Media Center running?
21:30:38.7 02/01/2007: Checking/Creating LCD Registry values
21:30:38.7 02/01/2007: Check Media Center Exit/Start Mode
21:30:38.7 02/01/2007: Media Center Mode 2
21:30:38.8 02/01/2007: Text/Language: Spanish
21:30:38.8 02/01/2007: Applying Language/Text
21:30:38.9 02/01/2007: Custom Keyboard Input enabled: Getting custom codes
21:30:38.9 02/01/2007: Snap Delay set to: 2
21:30:38.9 02/01/2007: Get other settings
21:30:38.9 02/01/2007: Set: Find emulator artwork on best match basis
21:30:38.9 02/01/2007: Using DirectInput for keyboard input
21:30:38.9 02/01/2007: Start work for Form
21:30:38.9 02/01/2007: Getting Original Screen Size
21:30:39.0 02/01/2007: Loading ICON
21:30:39.1 02/01/2007: Initializing Component
21:30:39.2 02/01/2007: Initialising Bass Audio Library
21:30:39.4 02/01/2007: Loading default loading screen
21:30:39.5 02/01/2007: Loading Custom Emulators
21:30:39.5 02/01/2007: Loading Emulator 1: Nintendo 64 Games
21:30:39.6 02/01/2007: Using 2D Animations
21:30:39.6 02/01/2007: Using General Font: Trebuchet MS
21:30:39.6 02/01/2007: Using Title Font: Trebuchet MS
21:30:39.6 02/01/2007: Initialising DirectDraw
21:30:45.0 02/01/2007: Creating DirectDraw Device
21:30:45.0 02/01/2007: Using Device: Ultimarc ArcadeVGA
21:30:45.0 02/01/2007: Setting Resolution to 640x480 32 bit color
21:30:45.0 02/01/2007: Creating DirectDraw Surfaces
21:30:45.0 02/01/2007: Creating Primary Surface - Full Screen Mode
21:30:45.0 02/01/2007: Creating Back Buffer
21:30:45.0 02/01/2007: Version 2 Theme being used. Loading.
21:30:45.0 02/01/2007: Loading Button Data
21:30:45.0 02/01/2007: Loading Font Data
21:30:45.0 02/01/2007: Loading Layout Data
21:30:45.0 02/01/2007: Loading Taskbar Data
21:30:45.0 02/01/2007: Loading graphic surfaces
21:30:45.1 02/01/2007: Creating Surfaces Misc and Dialogs
21:30:45.2 02/01/2007: Creating Surface Volume
21:30:45.2 02/01/2007: Creating Surfaces Arrows
21:30:45.2 02/01/2007: Creating Surfaces GameEXlogo Text
21:30:45.2 02/01/2007: Creating Surfaces Toolbar
21:30:45.2 02/01/2007: Creating Surfaces Backgrounds
21:30:45.3 02/01/2007: Creating Surfaces Toolbar Controls
21:30:45.3 02/01/2007: Creating Surfaces GameEx Logo
21:30:45.3 02/01/2007: Creating Surfaces Home & Exit
21:30:45.3 02/01/2007: Creating Surfaces Snaps
21:30:45.3 02/01/2007: Creating Surfaces Menu and List Bars
21:30:45.4 02/01/2007: Creating Fonts
21:30:45.4 02/01/2007: Creating Menu Font
21:30:45.5 02/01/2007: Creating Game Font
21:30:45.6 02/01/2007: Creating Font Black
21:30:45.7 02/01/2007: Creating Font Black Small
21:30:45.8 02/01/2007: Creating Game Font Faded
21:30:45.8 02/01/2007: Creating Title Font
21:30:45.8 02/01/2007: Restoring Title Font From Cache
21:30:45.9 02/01/2007: Fonts Created Succesfully
21:31:11.0 02/01/2007: Initialising Windows Media Player Component
21:31:11.1 02/01/2007: MAME Path is: C:\Emulators\Mame32
21:31:11.1 02/01/2007: daphne Path is: C:\Emulators\Daphne
21:31:11.1 02/01/2007: daphne EXE file is: Daphne.exe
21:31:11.1 02/01/2007: Use daphne on. Daphne.exe will launch games
21:31:11.1 02/01/2007: Model 2 Path Path is: C:\Emulators\Model2
21:31:11.1 02/01/2007: Model 2 EXE file is: emulator.exe
21:31:11.1 02/01/2007: Use Model 2 on. m2launcher.exe will launch Sega Model 2 games
21:31:11.1 02/01/2007: ZiNc Path is: C:\Emulators\ZiNc
21:31:11.1 02/01/2007: ZiNc EXE file is: zinc.exe
21:31:11.1 02/01/2007: Use ZiNc on. zinc.exe will launch PSX games
21:31:11.1 02/01/2007: MAME EXE file is: Mame32.exe
21:31:11.1 02/01/2007: ROM Path is: C:\Emulators\Mame32\roms
21:31:11.1 02/01/2007: Catver.ini is located at: C:\Archivos de programa\GameEx\DATA\catver.ini
21:31:11.1 02/01/2007: controls.ini is located at: C:\Archivos de programa\GameEx\data\controls.ini
21:31:11.1 02/01/2007: History.dat is located at: C:\Archivos de programa\GameEx\DATA\history.dat
21:31:11.1 02/01/2007: nplayers.ini is located at: C:\Archivos de programa\GameEx\DATA\nplayers.ini
21:31:11.1 02/01/2007: MAMEinfo.dat is located at: C:\Archivos de programa\GameEx\DATA\mameinfo.dat
21:31:11.1 02/01/2007: Loading Controls.ini map file
21:31:11.1 02/01/2007: Snap Path is: C:\Emulators\Mame32\snap
21:31:11.1 02/01/2007: AVI Snap Path is: C:\Emulators\Mame32\avisnap
21:31:11.1 02/01/2007: Flyer Path is: C:\Emulators\Mame32\flyers
21:31:11.1 02/01/2007: Cabinet Path is: C:\Emulators\Mame32\cabinets
21:31:11.1 02/01/2007: Title Path is: C:\Emulators\Mame32\titles
21:31:11.1 02/01/2007: Panel Path is: C:\Emulators\Mame32\cpanel
21:31:11.1 02/01/2007: Icon Path is: C:\Emulators\Mame32\icons
21:31:11.1 02/01/2007: Marquee Path is: C:\Emulators\Mame32\marquees
21:31:11.1 02/01/2007: Using Ultimarc AradeVGA
21:31:11.1 02/01/2007: MAME CMD options: -triplebuffer -nowindow -joy
21:31:11.1 02/01/2007: Attempting to load game list
21:31:11.3 02/01/2007: Loading last used Game List
21:31:11.3 02/01/2007: Loading Start Page
21:31:11.4 02/01/2007: Setting Music Volume
21:31:11.4 02/01/2007: Creating DirectSound Device
21:31:11.4 02/01/2007: Trying: Controlador primario de sonido
21:31:11.4 02/01/2007: Loading Sound Files
21:31:11.4 02/01/2007: DirectSound Device Created Successfully
21:31:11.4 02/01/2007: Creating ICONS
21:31:11.4 02/01/2007: Recreating ICONS
21:31:12.0 02/01/2007: Gamepad/Joystick disabled
21:31:12.0 02/01/2007: Initialising DirectInput for Keyboard support
21:31:12.1 02/01/2007: Playing intro sound file
21:31:12.1 02/01/2007: Initializing MCE Remote
21:31:12.1 02/01/2007: Initialization OK! Starting GameEx!
21:31:12.2 02/01/2007: Testing Main Loop Once: Processing Frame
21:31:12.4 02/01/2007: Testing Main Loop Once: Main Loop ran successfully
21:31:20.4 02/01/2007: Validating: Emulator_1: Custom Background: C:\Emulators\Project64\snaps
21:31:20.4 02/01/2007: Warning: Emulator_1: Custom Background Does not exist
21:31:20.4 02/01/2007: Validating: Emulator_1: Snap Path: C:\Emulators\Project64\snaps
21:31:20.4 02/01/2007: Validating: Emulator_1: Database: N64
21:31:20.4 02/01/2007: Validating: Emulator_1: Title Snap Path: C:\Emulators\Project64\snaps
21:31:20.4 02/01/2007: Validating: Emulator_1: Box Art Path:
21:31:20.4 02/01/2007: Warning: Emulator_1: Box Art Path Does not exist
21:31:20.4 02/01/2007: Validating: Emulator_1: Cart Art Path:
21:31:20.4 02/01/2007: Warning: Emulator_1: Cart Art Path Does not exist
21:31:20.4 02/01/2007: Restoring Emulator from Cache
21:31:20.5 02/01/2007: Restoring Emulator Database From Cache
21:31:23.8 02/01/2007: Running: cmd.exe /c C: project64.exe C:\Emulators\Project64\roms\Super Mario 64 (Rev. 0) (JAP).v64
21:32:17.4 02/01/2007: Exiting GameEx!
21:32:17.4 02/01/2007: Saving Settings
21:32:24.8 02/01/2007: Disposing Plugins
21:32:24.8 02/01/2007: Checking for applications to Launch On Exit
Thank you
Roman
Have you tried to reinstall GameEx maybe? Reinstalling over your current installation is perfectly fine and will not hurt any of your settings, but it can fix corrupted program files. Try it if you haven't cause this sure is WEIRD.
this is going to sound weird, but I have the same problem on 7.09 and this fixed it. If you have the database set on the last screen of the setup for pj64 remove it. Set the database file to blank. I actually experienced the problem with a few emulators and this was the common denominator. After I set the database to blank everything is working fine again.
YES !!!!!!!!!!!!!
That solved the problem! Everything works fine now . There is a extrange connection between Database and keyboard input. Seems like a little bug.
Thank you all for your support.
Best regards.
Roman
