Hi I'm trying to install instantsheller on windows 10 enterprise LTSC.
I have framework 4.8.
When I go into install instantsheller it's wanting .net framework 2.0 or higher.
It won't install. Any suggestions would be highly appreciated!!@
Yeah, The Microsoft .net framework does not work like that. A newer version is not necessarily that but a different version altogether.
So trust the guy that wrote it and not question it and do what it is asking!
If .net 3.5 won't install I am guessing you have a hacked or lite windows iso. Not a question for here, sorry.
Is that what you are saying, or are you upset about installing it?
Where do you get upset??I asked a question and was looking for support.
I have a lite version of windows. As I stated windows 10 LTSC.
I looked through the forums and saw nothing in regards to instantsheller. You have it available for download so I thought I would inquire here about it.
Hi,
Sorry, I didn't intend to be off with you if I was.
Hopefully it was helpful info anyway.
Cheers,
Tom.
PS: Lite is fine by me, it can cause issues though. Sometimes .net 3.5 is removed entirely.
A standard windows 10 LTSC is not an issue. I know what it is. It has no issue with .net 2/3.5 That is not what i meant by a lite version.
A lite version is a modified iso where components have been removed by a tool to improve performance and remove bloat. A "standard' Windows 10 LTSC is not a lite version and should work fine with everything here. Although I realise these days people refer it to as a lite Windows.
For info to all, last time I tried to use a "lte" (not LTSC) (that I created myself) I got ransomware as it weakened security in windows. Not doing it again..
  • Draco1962 changed the title to [RESOLVED] Instantsheller
