I can't get it to work, nothing happens when I press the pinvol volume button, does anyone here have PinVol working with PinballX?
EDIT: Found the issue, PinVol does not work if you launch PinballX as administrator.
  On 4/24/2024 at 6:58 PM, Draco1962 said:
Have you seen this setup video?
Yes, but he is not using PinballX there.
I forgot to mention that PinVol is working fine here if I launch the table direct from Visual Pinball, it's not working if I launch it from PinballX.
Glad you were able to get this sorted. Thanks for writing back with your solution! It will be of help to others!
  • Draco1962 changed the title to [RESOLVED] Does PinVol works with PinballX?
It's an old habit to use PinballX as an administrator, but there's definitely no need to run PinballX, Visual Pinball, or any other pinball-related program as admin.
