I have LEDBlinky configured and installed and the plugin is working in GameEx. The only issue is after the intro, my player 1 coin and start buttons and my trackball stay lit until I go into a game. Any ideas what could be causing this? I am using a Pac64 LED if that helps. Thanks!
You may want to attach copies of your gameex.ini and log.txt files. Also there should be a log file within the LEDBlinky folder - LEDBlinky.log that may also be helpful.
You may find a configuration that was missed at LEDBlinky Support
Additionally, you may also want to reach out to Arzoo directly at the ArcadeControls.com forums or via email at [email protected]
