I do not recall that ever being an option in Arcade Edition.
Are you maybe thinking of the options under Display > Interface Mode, of whic there are Normal, GameLauncher, and GameLauncher - MAME available?
Hello, thanks for answering. I have discovered those options you mention, thank you. I have Gameex on another PC, where the "use flat menu" option appears, I think it is Arcade edition. I will confirm it.
Check your log.txt file on that PC for the Arcade Edition version. It may be a deprecated setting of it ever was an option.
I take this opportunity to ask why some games are seen with video and without a background (lower image) and others with snap and with the background of the logos (upper image) Can it be configured so that they all appear with background and snap? Thank you!!
  On 2/15/2024 at 7:00 PM, Misote said:
Thank you!! I have already managed to get Mame to come out directly
How? This helps others with the same issue. Thanks!
I have simply eliminated the snap videos, and automatically those games that used videos are now seen with snap and background. Thank you for your excellent disposition.
  • Draco1962 changed the title to [RESOLVED] Missing "use flat menu"
  • Draco1962 locked this topic
