Hello everyone,
I started updating some of my VisualPinball 9 tables up to the VPX version of the tables. I am in the middle of setting up SurroundSoundFeedback and VPX tables are needed for this feature to work.  I am finding the directb2s is loading a little slower in VPX for some of the tables and when it finally loads the BG shows up in front of the DMD.  It is using the same directb2s file I used with VP9 version of the table.  My DMD and BG on same display.
So I tweaked a setting on the directb2s to not have "Bring BG Form to top" it allows loads correctly in VPX now.  But when I open the table in PinballX the BG never loads.
  What in the world am I missing.
Thanks,
Rich
Best to attach your pinballx.ini & log.txt, but at a guess you either have 'auto position directb2s' set to yes (under display settings) and that is somehow messing up the screenres.txt file used by directb2s server, or you have something set to run in a windows compatibility mode.
Good move getting SSF btw - it makes a huge difference!
I thought once I updated to Win10 and setup fresh the issue would go away.  But still having this issue.  Just checked the display settings and see I did have "auto position directb2s" set to yes...changed to no and at first glance looks like it is ok.  Will update after some more testing.
