Hello,
I am having a problem displaying Pinballx startup videos.
I created 2 videos Intro_Tron_Backglass.mp4 and Intro_Tron_Playfield.mp4. The backglass video, no problem.
On the other hand, the playfield video is displayed on 10% of the screen. Is there a setting in the Pinballx settings to modify?
Does the Pinballx program have a screen saver, if so how do I activate it?
THANKS
 	PinballX.iniFetching info...  	log.txtFetching info...
Yes, screensaver is called attract mode. Its not to save your screen, bit jumps to other table.
I even think you can add screensaver sounds, but check pinballx pdf documentation for it
Hello,
no solution for my screen display problem?
"I am having a problem displaying Pinballx startup videos.
On the other hand, the playfield video is displayed on 10% of the screen. Is there a setting in the Pinballx settings to modify?"
How large is the playfield video, can you zip it and attach it to a post?
Please also try updating PinballX to the latest version, there were some changes in 6.02 for videos that might have also affected intro videos.
  • Draco1962 changed the title to [RESOLVED] display orientation issue
  • Draco1962 locked this topic
